Question about Sony KP-57WS500 57" Rear Projection Television
The red bulb and the green bulb fade out completely after a couple of minutes leaving only the blue illuminated. If I turn the TV off and then back on, the process repeats itself. Is this a matter of changing those two bulbs out, or is this a symptom of a different porblem?
  • 1 more comment
  • fiestatoad May 10, 2010
    Thanks so much! The knobs were a little trickier to access than I anticipated, but there they were and a minor adjustment seems to have corrected the issue.
    A simple solution to my problem that I never would have thought of! Very nice and completely without cost. All I needed was a screwdriver.
  • fiestatoad May 11, 2010
    looks as good as it ever did before, and better than it has for the last couple of years.
  • 10,594 Answers
This problem can be fix by adjusting/ increasing Screen Volts of Red and Green tube/ bulb.
There is Focus Control block that has 6 control knobs, 3 knobs for focus adjustment of each tube and 3 control knobs for Screen Volt adjustment of each tube. Locate R and G screen knobs and slightly increase screen volts to fix the issue.
Focus control box can be accessed by removing front speaker grille.
Hope this info will help you.
Thanks.
Posted on May 06, 2010
  • Shahid Electronics
    Shahid Electronics May 10, 2010
    Great. Hows picture result?
    Thanks.
Samsung dlp hl61a650c1fxza turned off in the middle of the nfl playoff game. Turned it back on and the blue on/off button stays lit but the three lights (red, green, green) blinks constantly with no...
Hey dsfrank6088, i have the same issue right now. I called tech support and they are telling me that i need to change the light bulb which i did less than 3 months ago. Please let me know if you did find a solution!!
Jan 19, 2011 | Samsung HL61A650 TV
The screen turns blue after about 2 minutes of turning on the TV
Sony TVs has an Optical Block issue. If there is an issue with the optical block, then there will be green, blue patches or tint on the TV display. Try resetting the TV to the factory settings and try Power resetting the TV. Turn Off the TV and remove the power plug from the wall outlet for 1 minute and reconnect it and check the operation. If the issue still persists, then TV may require service. You can contact the Customer relations team and check for the available options. Sony had repaired free of cost for such issues. Hence, contact the customer relations.
Jul 25, 2010 | Sony KP-57HW40 57" Rear Projection...
Tv comes on for 10 seconds then fades to a green tint then turns completely green for a few seconds than turns off
Symptom shows tv got problem with green picture tube that need to be replaced.
Rear projection tv has 3 picture tubes, red-green-blue to make color picture.
Since its an old model so spare parts would hardly be available and local tv repair shop will help you to arrange required part, if they can.
Thanks.
Apr 16, 2010 | Sony KP-57HW40 57" Rear Projection...
KP-51HW40 Sony 51" Fades to blue screen
The service manual on page 8 shows how to adjust the Red/Blue/Green screen voltages. To get to the adjustment board, take the front speaker grill off (two screws at the bottom left and right) and set it aside. No need to disconnect any wires. Then remove the plywood board with 4 screws that exposes the screen/focus adjustments. The top 3 adjustments are for focus, and you need not mess with these. The bottom 3 adjustments are for Red/Blue/Green screen voltage rough adjustments. My screen showed red lines, so I had to turn the bottom right adjustment with a philips head screwdriver just slightly until the red gun retrace lines where no longer visible.
Aug 26, 2008 | Sony KP-51HW40 51" Rear Projection...
KP-51HW-40 FLASES BLUE ,RED, GREEN
Your picture tubes are trying to short out you have 3 red, green ,blue.
Mar 26, 2008 | Sony KP-51HW40 51" Rear Projection...
Blue screen
convergence ic and resistors require replacement and that you need to check for cracked solder.
http://home.earthlink.net/~oleg.filippov/ConvergenceFix.htm
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 28, 2007 | JVC AV-56WP74 56" Rear Projection...
SONY KP-57HW40
you are experiencing one or more of three things
1.the crt itself is damaged
2. the vertical ic on blue crt board is bad
3. the focus block is bad
if you hire a sony authorized technician they should be well aware of this problem.
Oct 22, 2007 | Sony KP-57HW40 57" Rear Projection...
Sony KP-51WS500
does it have blue video image?
Sep 29, 2007 | Sony KP-51WS500 51" Rear Projection...
Green picture
you might wanna look into the "flicker issue" with your set...If you've had it for a while a could be that it's just worsened over time and developed into a voltage leak. I have the same set and it went undetected for a couple of years due to poor quality cable signal..once I went to a clear signal (ie. directv) the issue was very noticeable, but by that time it had progressed. Eventually one of your guns will fail and the set will stop working all together (mine did just under 4yrs from purchase) and unless you have Sears warranty that WILL try to stick it to you. TRUST ME!!! Good luck.
Apr 01, 2007 | Sony KP-57WS500 57" Rear Projection...
FADING TO BLUE SCREEN
Sounds like you have a problem with the blue gun in your picture tube or its drive circuit. You might remove the back cover and gently tap on the neck of the picture tube using a plastic screwdriver handle while watching the screen in a mirrow. If the picture flashes back on or on and off then the picture tube is the problem. If this is a projection tv you have three separate tubes : red, green & blue. you'd need to tap the blut one.Gently!!!! Stargazer
Feb 13, 2007 | Sony KP-53HS20 TV
Sony KP-57WS500 57" Rear Projection Television Logo
54 people viewed this question
Top Sony Televison & Video Experts
Jerry Greenberg
Jerry Greenberg
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
