Question about Cameras
I have bought a SONY DCR-SX50 I have not been able to load the PMB program because when I connect the USB line to my PC (Windows XP)I am told that it does not recognise the connection and to make sure that the camera is the one with which the CD was provided... I use Pinnacle Studio 12 and cannot lod my film... Any idea ? Thanks
  • 2 more comments
  • ahardy586 May 06, 2010
    To late to night... I will try and revert
  • ahardy586 May 07, 2010
    I have tried to swap to the 3 other ports without success.
    Yes, of course I have the original disk !
    When I connect the USB plug, the camera screen displays "Preparing..." and does not move further. If I press on "Continue" on the PC screen I have "Cannot confirm a connection with the camera"
    Back to suquare one...
    I have swapped the 3 ports without success.
  • ahardy586 May 08, 2010
    The problem has been solved…
    Connecting the camera and going to “add new equipment” which suggested to insert the provided disk, Windows finally found the USB driver and all is now OK!
    Thanks
  • 15,935 Answers
You will need the drivers loaded on the PC for your camera - or it won't be recognized.
Do you have the original driver disc?
Thanks!
Posted on May 07, 2010
  • 668 Answers
It tends to be the problem of the usb port ,try in different port and you won't face these problem . If you still face the problem let me know .
Posted on May 06, 2010
Sony Handycam DCR-TRV30E driver
Well Windows 7 has no camera drivers at all built-in, Sony are developing them I am told, if you use a Firewall cable to PC then no drivers are needed.
Jun 14, 2010 | Sony Handycam DCR-TRV30E Mini DV Digital...
Sony Handycam DCR-HC42 Mini DV not recognized by Windows 7
win vista and win 7doesn't support usb streaming. the usb driver for this model would not be compatible with your computer's OS. although, you were able to download PMB still this wouldn't work, it's basically an alternative software that you can use with the newer OS. still the device driver would not be installed. and you would get a message that "ilink connection is not detected". the reason you get that is bec the camcorder and the software is intended for use with the dv (ilink or ieee1394) connection. so if your computer has an ieee1394 card and you have a compatible ilink cable,then your good to go,it should be a plug-and-play connection (no drivers required). all you need then would be a video capturing software (like win moviemaker) to transfer videos from tape to PC. hope this helps. thanks :)
Mar 28, 2010 | Sony Handycam DCR-HC42 Mini DV Digital...
Sony dcr-hc32e vista driver ,
Go to camcorder Menu and enable USB Stream.
Windows will recognize camcorder.
Aug 12, 2009 | Sony DCR-HC32E DV Digital Camcorder
I rty to connect my DCR-HC18E to the computor via usb but it doesn't work
What Windows (XP or Vista) your are running in PC?
Is there any error message comes when you connect Sony DCR-HC18E with PC?
Does PC sounds Ding when you connect camera at USB port?
Reply on above will help me to provide you assistance.
Oct 27, 2008 | Sony Handycam DCR-HC21 Mini DV Digital...
DCR SR 85 - Unable to Retrieve Management Information: I get the message " Unable to Retrieve Management Information" when I try to download the video on my computer . What do I do ? Help me
When you turn on your connected Handycam, you are prompted to select a connection from the touch screen. Make sure you select the USB-HDD connection, and not the flash memory.
Hope this helps.
Aug 10, 2008 | Video Cameras
Compatibility of Sony DCR-HC19E with Windows Vista
a firewire cable works but i have this from sony that might help others with vista as i contacted them direct and they sent me this for vista, http://support.sony-europe.com/dime/downloads/pmb/pmb.aspx?site=odw_en_GB&m=DCR-HC19E.
hope it helps you out
Aug 24, 2007 | Sony DCR-HC19E Mini DV Digital Camcorder
Cameras Logo
77 people viewed this question
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
