Question about Kenwood KDC-X591 CD Player
I enter my code how come my stereo is not working Keenwood KDCX 591
  • myson75 May 07, 2010
    So once I enter my CODE...How do long do I have to turn on the radio, or does it turn on by it's self once you put in the right CODE??
    What is a car audio passport??
    President:
  • 2,923 Answers
You stated that you entered the code for your car stereo, but still, your Kenwood won't work.
If the code won't work, you need to verify the code, to see if you have the correct stereo code. You actually need to take the stereo out, get the serial number on the side, then contact the car dealer or the manufacturer to verify the code that you have.
This code is also called the "anti-theft" code. It is unique with every car stereo, so that the stereo will be disabled once stolen.
Only the dealer or the manufacturer can give you the correct code, or can verify the code that you have. Contacting them would be the best thing to do.
Thank you and good luck!
Posted on May 08, 2010
  • Kenwood Master
  • 3,247 Answers
You may need to refer to page 21 on the user manual.
http://www.kenwoodusa.com/UserFiles/File/Global/Consumer/Manuals/KDC-MP535U.pdf
It depends on the situation in which you are required to enter the code.
In case the car battery had died then you have to reset the code and chose a new one.
If you had taken the CD player out of the car and are putting it back in, then you have to use the code that you setup previously.
Hope it makes sense.
Posted on May 07, 2010
  • 17,970 Answers
I suggest check your Kenwood KDCX 591 - User Guide (page 22) for right installation and "register activation code"...
Hope this help.
Posted on May 06, 2010
  • ZJ Limited
    ZJ Limited May 07, 2010
    For other details on how to obtain the 4-digit security code for your car
    stereo please please go to Kenwood Security Codes.
    * You did not enter the security code immediately
    after first start-up.
    Put the equipment back into the original operating conditions by
    pressing RESET key. Then enter the code, which is printed on your Car
    Audio Passport.
    * Security
    Code is not accepted or the code number is incorrect.
    Please enter the four-digit code number, which is
    printed on your Car Audio Passport.
    - If you have entered the correct code number and followed the code
    input procedure from your instruction manual, and the unit does still
    not work. Please check that the serial number starting KE0???? Etc on
    the Car Audio Passport is the same as the serial number on the stereo
    itself. (The serial number is located on the top or bottom panel of the
    stereo, therefore, you will need to remove the stereo from the
    dashboard)
    - If the serial number is the same on the car audio passport as on the
    stereo itself, then unfortunately it would appear that there is a fault.
    The product will need to be inspected by a Car Audio Service Agent. For
    details of your nearest one please go to Kenwood Service Agents.
    - If the serial number on the stereo is different to the one on the Car
    Audio Passport then you have been given the wrong code for your
    particular stereo. To obtain the correct code number, contact your
    Kenwood Dealer.
    * The
    radio no longer operates and just shows “TRANSMIT 1”
    - If the radio loses power, or is reset, then it
    will require the security code to be transmitted from the MASK key. The
    MASK key is a small blue remote control with one button which came with
    the unit when new.
    - Hold this MASK key about 4 – 5 inches from the front of the stereo
    and press and hold the button. You will need to repeat this procedure
    once more when prompted and then the display will show “APPROVED”.
    Good luck.
  • ZJ Limited
    The "passport" is a
    label that is given to you when making the purchase, sometimes is in the user guide.
What is EC code in kenwood a.c ?
  1. If your car battery died, your Kenwood stereo will ask you for a code. There are various ways to enter the security code; this depends on the model of your Kenwood stereo.
  2. Look in your manual and see what the security code is for your particular Kenwood stereo. There are common security codes on many Kenwood stereos. Kenwood claims security, but its stereos have many of the same security codes. Here are three common security codes: 1-2-3-4 (a code many Kenwood owners use), 3-0-5-1 (a common security code in Kenwood manuals) and KCAR (works on some Kenwood stereo models). You should have a code within the pages of your manual. Luckily, many Kenwood stereos have the same security codes.
  3. Enter the security code into your Kenwood radio. Method #1: During the code request mode, while holding the DISP key depressed, press and hold the "Volume UP" or "DOWN" key for three seconds until the " ... " display disappears. Enter the security code using your Kenwood remote. Method #2: Press the "Auto" and "Track Up" button on the face of radio at the same time until the four dash lines disappear. Enter the security code using your Kenwood remote. Method #3: Press and hold the "One" then the "Six" preset keys until the display shows the letter "C." Enter the security code using your Kenwood remote.
  4. Tips:
  • If you did not have your manual, try the most common codes for Kenwood stereos. If those codes don't work, you can also buy your Kenwood stereo code online. There are places online that will sell you the security code to your Kenwood stereo.
  • Keep your security code and this information in a safe place.
Here is a link to a more detailed site Good Luck
May 18, 2016 | Kenwood Car Audio & Video
Secruity code for keenwood ddx 512
When you disconnect your battery and then reconnect it again, it disables the radio. This is an anti-theft protection for your car radio.
The enable your radio the activation code is in your vehicle owner's manual. If you do not have this code you need to go to your vehicle manufacturer's service centre and get them to enter this code for you.
Feb 06, 2013 | Car Audio & Video
Code entrance BECAUSE I LOST THE NUMBER
Kenwood I am afraid ask you to activate a code of your choice after purchase. The code you or the original keeper entered is NOT retrievable unless noted somewhere in your manual. This means the unit has to be taken/sent to a dealer for a "bench" re-coding
Mar 27, 2011 | Kenwood KRC-591 Cassette Player
Need three digit tv code for dish satilite system?
We would be happy to help you with getting your DISH Networkremote to control your TV. We're going to start by pressing and holding the TVbutton located on the top of your remote until all mode button back lights comeon, and then release. Use the number buttons to enter the codes for your Polaroid TV; here some of the codes we currently have: 627, 688, 591, 669, 627and 591. Press the pound (#) button. To check that the code works try severaldifferent functions on the remote to make sure it will properly operate the TV.Remember that some codes may not be compatible with your equipment. If this isthe case, try the other codes listed for that device until you find one that iscompatible with your equipment.
We hope this helps and thank you for being a valued DISH Network customer!
Phillip Chang
DISH Network Customer Service Representative
Jan 01, 2011 | Polaroid TLA-01911C TV
Cannot program my dish remote control need program numbers
Try this numbers 542, 589, 590, 591, 592,
609. I do believe you hold down the tv button on your dish network remote and wait until it flash and the light will remain on. Then enter the codes above. If the first code continue to the next code
Oct 12, 2009 | Soyo DYLT032D 32 in. LCD Television
Kenwood ddx-6019 password
Contact Keenwood, they may make you send it in and charge a fee. Goodluck.
Feb 28, 2008 | Kenwood DDX8017 6.5" Wide Dual DIN Indash...
Kenwood KDC-X591 CD Player Logo
99 people viewed this question
Top Kenwood Car Audio & Video Experts
xxxxxx xxx
Are you a Kenwood Car Audio and Video Expert? Answer questions, earn points and help others
