Question about Garden
Snapper Zero Turn mower. Blade will not engage. Any suggestions?
Mower is about 7 years old. Belt is ok, but blade will not engage
    Problem Solver:
  • 16 Answers
I am not sure what type of blade engagement mechanism you have (ex. clutch, tensioner/idler pulley, etc...) but make sure that the blades can spin freely with the belt taken off of their pulleys. It could very well be that one of the pulley bearings is seized.
Posted on May 07, 2010
On the Zero turn mower , how do you relieve the air in the pump lines after replacing a bad pump . Please advise.
How To Release Pressure From Fuel Lines - YouTube
? 0:51
www.youtube.com/watch?v=6oo9zlTMPOQ
Oct 15, 2009 - Uploaded by YeechBlitz
See a demonstration on how to release the pressure from fuellines of a 1997-2000 ... in the tank, but do not let the air out, so pressure can build up in there. ... Diesels is where you want to be extra careful, the injector pump to ...
5900748 Snapper Zero Turn Mower - Hammerwall
www.hammerwall.com/.../Snapper/.../5900748/Snapper%20Zero%20Tur...
Back To Snapper Tractors-Riding-Lawnmowers Model: 5900748 Snapper Zero ......Reinstall each mower blade with the air lifts pointing up towards the mower deck ... The fuel filter is located in the fuel line betweenthe fuel tank and fuel pump . .....TROUBLESHOOTINGTHE RIDER PROBLEM CAUSE REMEDY Enginewill ...
Sep 25, 2015 | Briggs & Stratton Snapper 5900748 355Z...
Snapper 1028
I would check the blade for balance and straightness. Also check if it has a piece out of it. The deck looks ok? No dents and is not damaged. Deck sits level? Front to back and side to side? Make sure all the bolts holding the spindle are tight. If the mower was set up by a dealer, make a good trip around the mower,look for anything that looks out of place.
Jul 14, 2014 | Garden
Snapper 23 series mower blade will not engage
sounds like you belt is disengaged or just wore out, these type belts look good just to look at them, but they can stretch and get rounded a little bit of can mean a lot
Apr 05, 2014 | Snapper Garden
Mower blade not engaging
Check your belt. May broke, off, slipping.
How can i get more blade speed from my 355z snapper
what for you have 26hp. what are you trying to cut. check your blades are sharp. and dont expect it to act like a mulcher.
Jul 28, 2012 | Briggs & Stratton Snapper 5900748 355Z...
I have a cub cadet rzt50 zero tudn. Blades are new and sharp but when i cut there is a trial of cut grass in the center of the mower tracks that is left behind. Mower is only a few years old with 100 hours...
if this started after the blades where replace make sure you have the right blades zero turn and reg mowers have different blades then check the bearings on the blade mandrels then last is to check for a rotted out deck with the belt tension pulling the blades apart
May 16, 2012 | Cub Cadet Garden
What would cause my craftsman zero turn to die when i engage the blades?
First, sort out between two possibilities: 1. The safety system is killing the engine -- for example, if the seat switch is faulty or misadjusted, the engine ignition is killed when you activate the blade engagement switch. 2. The blades, spindles, or belts are binding or stuck, which would "drag" the engine to a stop. I suggest you remove the belt that drives the mower from the engine. If the engine still dies when you engage the blade switch, it's problem #1. Check all connections, and check the seat switch with an ohmmeter. If the engine does not die, then you have mechanical drag. With engine off and the belts taken off, turn each spindle to find out if one is frozen or binding. Good luck!
Apr 05, 2010 | Craftsman 21 HP 42 in. Zero Turn Tractor...
I have an 89 snapper riding mower . all of a
Check the springs, and nuts, and see if the pulley moves and doesn't stick when engaging/disengaging
Jul 20, 2009 | Garden
Garden Logo
536 people viewed this question
Top Garden Experts
Dennis Key
Dennis Key
john h
