Question about HP Pavilion a1253w Notebook
Overheating I use to be able to feel my computer and it would be ice cold, now when i touch it room tempature
I SAY STOP FEELING UP YOUR COMPUTER :) TRY CLEANING ALL COOLING FANS INCLUDING THE POWER SUPPLY! CPU FANS, SYSTEM FANS ETC. ALSO TRY TAKING OFF THE CPU FAN AND MAKE SURE THE PROCESSOR HAS BEEN COATED WITH HEAT RESISTANT COMPOUND. A GOOD CLEANING ALWAYS DOES WONDERS!
Posted on Apr 02, 2009
  • 20 Answers
The first thing you should do is buy a can of compressed air (most electronic shops sell it for under $10) and completely blow out the inside of your computer and fans. Then check to make sure all of your fans are working. Unfortunatley the life expectency of computer fans is a lot shorter than the components they are cooling.
Posted on Mar 27, 2008
Jiffy ice auger won't start if cold model 30 start good room tempature
Piece of junk if it needs to be warm.....being an ice auger and all.....take it back if you can.
Jan 10, 2017 | Refrigerators
My hotel room ac is blowing cold air just not strong enough to cool entire room
It may be frozen over. At the front of the unit there should be an air filter. May be behind a panel that opens, or it may slide out. Behind that filter will be the indoor coil or evaporator coil. Look to see that coil and if there is any ice on it. It will be a white ice covering the coil. If it's frozen up, turn the cooling mode to off, turn the fan mode to on, and let it run at least a couple of hours to thaw. Let maint. know it's frozen up and needs service. Get what you pay for! If it's not frozen up, find some way to check the supply air temp. Some sort of a thermometer. It should have a 50-60°f supply air temp, depending on the indoor temp. Most I've seen will supply 45°f, but 50-60 is a good reference. Hope this helps! I bet it's frozen up.
Apr 06, 2017 | Heating & Cooling
Alarm sounds with F2 flashing and won't clear
,Hello,
The F2 error code means that the over overheated by at least 100 degrees above the tempature that was set at the time. The usual reason the oven would over heat by so much is a defective oven tempature sensor and the sensor would need to be tested to see if is the problem to test the sensor it would need to disconnected from the wiring to it and measure the amount of ohms of resistiance AT ROOM TEMPATURE when the oven is off and cool. At room temp. the the meter used to check the sensor should display between 1060-1100 ohms,if the number is vastly different that 1060-1100 at room tempature the sensor is defiently bad and should be replaced. This is what the sensor looks like oldtech2332_129.jpg
it will be inside of the oven chamber and again to properly check it the wiring should be unplugged and the meter leads should be placed into the plug at the end of the sensor to measure the ohms
GENE
Oct 10, 2011 | Kitchen Ranges
Buzzing and f2 showing on display panel
GENE
Oct 10, 2011 | Amana AOCS3040 Electric Single Oven
All the functions works well, but after a few minutes the oven stops and display "F2". The screen is well, the temperature selector, timer, clock, all works well but the oven stops functioning
GENE
Oct 09, 2011 | Whirlpool RBS275PD Electric Single Oven
Hi.. we'll feel cold after taking bath from? 1. cold water 2 water at 40 c 4 water at room tempreature 3 water at 50c
"we'll feel cold after taking bath from?"
(Let's assume room temperature of the bathroom is 25 c.)
1. cold water
Assuming cold water means below room temperature, for example, 22 c. One taking a bath in water at this temperature would probably feel cold DURING his bath at least at first. However, a cold bath would tend to bring blood to the capillaries under your skin and create a warming sensation. But after you get of the bath tub, you would definitely feel cold unless the room were heated!
3) water at 50c
Most folks would feel quite hot while in the water at this temperature. And after exiting the tub, since the layer of water on his skin would probably still be well above body temperature (37 c), a chill would not set in until the water on his skin cooled down to below body temperature. So if he quickly dried off, he would avoid feeling cold.
2 water at 40 c
While almost completely immersed in the bath water, one would certainly feel warm unless there were a draft in the room, because 40 c is 3 degrees above normal body temperature. For the same reason as stated above (#3), he could escape feeling cold outside the tub if he dried off quickly.
4) water at room temperature
- If I had to select only answer, I would choose this condition that would make one feel cold after stepping out of the bath tub, because:
Upon exiting the tub of water at room temperature, one would certainly feel cold if there were a draft in the room. Even if there were no draft, one would still feel cold, because the water on his skin would be cooler than his body heat (37 c), and cause a finite evaporation of the thin layer of water on his skin, which is a cooling process. The skin's heat would be lost, because its energy would be used to evaporate the water.
Mar 30, 2010 | Scientific Explorer My First Chemistry Kit
Oven jjw9527aab fan runs continuously even when cool and now shows F2 alarm message
The F2 error code is due to the temp sensor is registering a tempature over 600 degrees. So the reason why the convection fan is continously running is because the ERC thinks the oven is overheated and is trying to cool it down. It is probably a bad tempature sensor or oven relay board. You will need to test the tempature sensor with an OHM meter. They usually will read 1000-1100 OHMS at room tempature. If you get an open read or a incorrect OHM reading then I would replace the tempature sensor otherwise replace the power relay board if the temp sensor is reading correct. But try unplugging the power to the oven for over 10 minutes first and then plug it back in. This will reset the ERC and might fix the problem.
Jan 18, 2010 | Jenn-Air 27 in. Electric Single Wall Oven...
Jiffy ice auger won't start if cold.
I
Hello. I'm kind of "out on a limb " here but my older chain saws and my Jiffy auger's the same. I use the highest octain fuel I can get (at the pump) and I think it helps. These old motors were made to run on real gas.
builderdale
Jan 08, 2010 | Omega Eskimo 39 In Ice Fishing Auger 8 In...
Split system getting cold at first then just not cooling the room
Split Air Conditioners are not meant to run constantly. so check this first . you may have a faulty component i.e. compressor, condenser, evaporator, or evap fan. Depending on your technician you may have gotten ripped off. You need to find out if he checked the system for refrigerant (gas) leaks. A good way to tell if your ac is leaking is feel the low and high side copper pipe in between the inside and outside units.
the smaller pipe (high side) should be hot be carefull maybe touch it with an ice cube. The Large pipe should be cold but not iced over.
if there is ice on any component you should call a qualified tech. you probably have a leak. you should also clean your air filters which are right above the vents. I am a certified AC mechanic and i have seen this problem. in Iraq because of ambient temperatures being high the systems take alot of abuse and we dont fix them because repair costs exceed replacement costs alot of the time. good luck.
Nov 19, 2009 | Mitsubishi MSZ09UN Air Conditioner
HP Pavilion a1253w Notebook Logo
112 people viewed this question
Top HP Computers & Internet Experts
pontelemon
pontelemon
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
