Question about Mitsubishi WS-65907 65" Rear Projection Television
I have a problem with my WS-65868. Picture &
I have a problem with my WS-65868. Picture & sound not wanting to come on. I hit the reset button and the green lights continious to blink but will not reset? It is 5 years old. I think a power surge may have hit it. Thanks
    Top Expert:
  • Mitsubishi Master
  • 14,553 Answers
ONLY 1 of 2 things can cause this problem----
First thing to do is remove front speaker grill--it should pull out and is secured with plastic pegs--behind it you will find an inspection plate---
Notice the one or two pairs of wires coming from the front keyboard of the set---remove the inspection plate and follow the wires to the right--you can unplug both plugs(most have two and they are marked with letters and different sizes so you cannot get them wrong)
The idea here is to remove the front keyboard with its reset button etc from the circuit---You will still be able to try to turn the set on with the remote---
These sets have a Receiver that is called a DM board--(large metal box to the left as you look from the back) and if the power goes out the green light will blink for about 70 seconds and then go out---it is the Receiver booting up. It is called the DM board.
If disconnecting the keyboard allows the set to turn on--you have a bad reset switch and two choices---either operate the set only with the remote or to remove the front screen and get at the reset switch (it is tiny) and remove and/or replace it.
If disconnecting the keyboard does not restore the set to operation---the receiver is bad---there are 4 or more caps and some pico fuses that can fail in that unit---Mitsubishi no longer sells or repairs these--if it is bad and not the caps there is a company you can send the unit to and have it repaired--if you need to know their name let me know---
You can call them and get a quote for repairing the receiver.
Let me know what more information you need--I am here to help.
SD TECH
Posted on May 06, 2010
Unplugged my Ws-55711 TV to move it to another room so the carpet could be cleaned. When I moved it back and plugged it in, the green light kept blinking for more than 60 seconds. I unplugged the TV for...
Open up the front, look under the right side picture tube. Look for puddle of oil on signal board. If you see this, it has bad picture tube & signal board. Not a good repair.
Jan 17, 2011 | Mitsubishi WS-55711 55" Rear Projection...
Mitsubishi 62 in 1080p turns on ,has sound but no picture
Your going to need to measure the various power supply voltages to see if its a bad main or power supply board
Nov 08, 2017 | Mitsubishi WS-65513 65" Rear Projection...
Mitsubishi 1080i HDTV has sound but no picture. Goes through all the menus fine but no picture on any antenna input. Mitsubishi Model WS-55807 Made December 2000
a COUPLE of things occur to me--Some of these sets had a problem with coolant leaking from one of the picture tubes--there is a sealed unit for each tube with Glycol--clear liquid like anti freeze but much more concentrated and TOXIC!
You may want to remove the front speaker grill and inspection plate behind it and look carefully across the front of the three main boards--it will appear as a discoloration of any parts on the boards-it does not take a lot to do fatal damage to the board--if you see any actual liquid on the board--do not touch it--you have to look mostly at the first few inches from the front of the boards--if you do not find any Glycol signs I have only one other suggestion:
All these sets have a hard reset that will put the set back to the condition it was when new and in the box---any labels on inputs will be removed and the set will turn off and then come back on channel 3 in the air band---you would have to put it into the cable band and autoprogram the channels again----
Take your time and look for any discoloration of parts on the boards---if glycol---solder connections will not shine but be discolored. (may look a little like battery cable in a car that has corrosion)
Let me know what you find and if you want to try the reset let me know and I will tell you how to do it for this model.
Sep 20, 2009 | Mitsubishi WS-55809 55" Rear Projection...
Power light comes on for 2 seconds and then off.
Need to have the power supply rebuilt, expect to pay around $350 Julio at milleniumtvsvc@gmail.com
Jul 21, 2009 | Mitsubishi WS-55807 TV
Mitsubishi WS-65809 turns off right away
check the collector drop on Q29a002. If it is less than 16 nano amps, repl ic u12 in conver circuit. stk392-570 and pico fuses f04 and f05 24v circ
Jul 28, 2008 | Mitsubishi WS-55857 55" Rear Projection...
Power Problem
Most likely the power supply is failing, or some other circuit that is causing a safety shutdown.
Without doing the proper tests and diagnistics, it is impossible to accurately speculate the exact fault.
Jerry G.
Jun 01, 2008 | Mitsubishi WS-65819 TV
Mitsubishi WS-48613
Did you try reset? Unplug AC cord for a while,plug in try again...
2) With paper clip, activate reset thru access hole on front of
TV ( consult owners manual) recheck.....................
3) Leave set unplugged from AC overnight.................T.
Please rate this solution........................
Nov 11, 2007 | Mitsubishi WS-48613 48" Rear Projection...
Mitsubishi WS-65907 65" Rear Projection Television Logo
87 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
