Question about Dewalt DPD3000IC 3000 PSI 28 GPM Gas Pressure Washer
I have a dewalt 3000 psi pressure washer that runs for 3 to 4 hours great but when i shut it off after that it wont start again
  • 1383 Answers
SOURCE: Ryobi 3000 psi pressure washer detergent injector
Most detergent injectors work by the venturi system. That is that the detergent is drawn into the stream by the forward flow of the water thru a very narrow port after the water passes thru the pump. This system works best when the pressure at the tip of the wand is low. Trying using a very large tip to draw in and apply the detergent, then remove injector and rinse with high pressure. Not good for the pump but to apply soap reliably under high pressure the soap needs to be injected through the intake of the pump. enjoy
Posted on Dec 01, 2008
  • 1383 Answers
SOURCE: pressure washer, john deere 3000 psi, honda engine
Pressure variance is caused by the unloader/pressure regulator valve or slipping belt on belt drive systems. Worn packings in the unloader will not maintain pressure. Try lowering the pressure to 1000 psi then slowly increase until problem reveals then lower pressure again to maintain steady stream. This problem can also develop if the wrong size tip is used in the gun. Example, if output rating is 3000 psi at 4.5 gal per min and you are using a tip for 3000 psi at 4 gpm. The unloader will release causing variance of pressure. Easy way to lower pressure of system is to increase the size of the tip to 5 or 5.5 gpm in a system rated at 4.5 gpm. Enjoy
Posted on Dec 02, 2008
  • 942 Answers
SOURCE: My DeWalt Gas Pressure Washer Model DPD3100 is
Hi
Just try the following steps
  • Inspect the water supply connections
  • Inspect the drain hose
  • Inspect the water pump
  • Inspect outer tub for cracks or corrosion
  • Inspect the tub seal
  • Inspect the tub bearing
Good luck
Regards
PCmania
Posted on Jul 05, 2009
  • 548 Answers
SOURCE: I have a 3000 psi karcher pressure washer with
sounds like you need a seal and bladder rebuild < if you liver in a cold environmet for winters please dont forget to winterize your washres every year before winter
Posted on Sep 15, 2009
nova2nv
  • 197 Answers
SOURCE: cannot get it to uptake the bleach for spraying
On most pressure washers you wont be able to draw soap/bleach into pump unless you are spraying on low pressure.There is a valve on the inside of inlet hose fitting that closes when high back pressure is sensed.Would it draw bleach into hose when wand tip is removed?
Posted on Nov 21, 2009
The machine shuts off when you let off the trigger. Seems like pressure must build up and it shuts off.
Your unloader bypass system has failed. Several pumps were used on this model, see link for parts breakdowns.
Sep 28, 2014 | Dewalt Pressure Washer - DXPW3025
Dewalt DPD3800 pressure washer starts and runs fine. After 5-10 minutes of washing the engine quits. It will not start until it cools. The engine will start after a 10 minute cool down. It will run and...
I have the exact same pressure washer and have had the same issues with it. The cure for me was to simply run the washer with the gas cap loose. For some reason the fuel gets vacuume locked and stops flowing into the carb. The fuller the tank is it seems the shorter the time is between the time it starts and the time it shuts off. Or you might find a way to vent the cap. Hope this helps.
Jun 06, 2011 | Dewalt 3800 PSI Pressure Washer
My unit will start to pulsate/surge then completely shut off.
Possible that there is dirt accumulation on the pressure washer.
1.check if the lines are clogged?
2. Check the gun open and blow air.
3. check the power switch .
4. check line to motor and if safety/load switch is acting due to overload caused by accumulation of dirt.
So clean up and check again.
Aug 26, 2010 | Dewalt 3800 PSI Pressure Washer
Northstar PW shuts off hot if washer is moved. Honda engine
Being petrol driven, it may have a mercury kill switch which puts a ground on the ignition circuit stopping the engine if you move it. Perhaps for safety in case you overturn the unit somehow.
Apr 08, 2010 | Northstar Pressure Washer 3000 PSI
John Deere 3300 PSi pressure washer shutting off while in use.Everything appears fine Oil level,Gal level,Air cleaner ok etc.. May run 2 minutes or 12 minutes then spudders a bit then Bang "Off" as if i...
John Deere will replace the cap for free; they acknowledge the vendor who supplied Briggs & Stratton gas caps provided faulty caps. Call 1-888-228-3068 then 1 (English), 2, 1 and a technician will ask you for model number and Serial Number (which they need to replace the cap). Don't drill a hole in your cap: debris will find a way into the gas tank and end up possibly fouling the engine. Bob from NJ
Nov 03, 2009 | Dewalt 3800 PSI Pressure Washer
DeWalt 3800 Pressure Washer Runs 20 min then quits.
I have the same problem and even have the issue with gas cap off.
Sep 24, 2009 | Dewalt 3800 PSI Pressure Washer
Dewalt DPD3000IC 3000 PSI 28 GPM Gas Pressure Washer Logo
109 people viewed this question
Top Dewalt Garden Experts
John Trevino
JOHN LAPIER
Are you a Dewalt Garden Expert? Answer questions, earn points and help others
