Question about KitchenAid Refrigerators
Kitchenaid Refrig Water Dispenser Hose Outlet
I have a Superba 42 KSS42QJX00 that is about 10 yrs old. The water outlet hose broke off (very end) and now water sprays all over when you try to fill a glass. I have been trying to find the part but keep getting the wrong one. The refrig diagram for this model does not show the actual part only a line to where it should be. I have now been told that I need to replace the whole door panel just to get a new dispenser outlet hose. Any help would be appreciated.
    Brigadier General:
  • 3,513 Answers
Please check the links to search for the part ….
http://forum.appliancepartspros.com/refrigerator-freezer-repair/812-water-dispenser-hose-replacement.html
http://www.buyspares.co.uk/fridge-freezer/kitchen-aid/catalogue.pl?path=465988:496327,287506:466210
Let us know if you have something more to know else accept the suggestion.
Thank You for contacting Fixya.com
Posted on Jun 22, 2010
  • pwperry Jun 22, 2010
    I tried to locate the part on the website you listed but no luck. The site does not recognize my model.
    President:
  • 1,561 Answers
From all indication, i would suggest you contact the manufacturer of the unit to see if you can get part from them or perhaps get a description of the actual part you need to get for your unit to work again, because, looking at the cost of getting a whole unit of the door will be quite expensive, so i suggest you look for a way to contact the manufacturer to see if they can render assistance.
But if all effort doing that as been in vain and there is no support from all angles, then, i will advice you replace the whole door, since this will help fix the the problem once and for all.
Wish you best of luck.
Take care.
    Thanks for the comments.
    I have tried 4-5 times over the last year to get an answer from Kitcheaid and the authroized rep. No luck.
My KitchenAid side by side refrigerator is just over six years old. The water dispenser just stopped working today for no apparent reason. I'm not sure there is new water for the ice maker. I can hear a...
That is the inlet water solenoid you hear click. The water maybe frozen somewhere in the hose. You can check for water getting through the solenoid valve by pulling the hose off going to the freezer and have someone push the dispense button while you hold a towel to catch the water coming out of the solenoid. If that works, then the hose is frozen or clogged.
Dec 10, 2013 | KitchenAid Superba Architect KSCS25INSS...
Kitchenaid Superba Ice Maker quit
If you add some water there, yourself. It should make some ice for you, untill the water runs out.
Try this
http://www.acmehowto.com/howto/appliance/icemaker/diagicemaker.php
Sep 08, 2008 | KitchenAid Superba Architect KSCS25INSS...
Connecting dishwasher hose
Try soaking the hose in a bucket of hot water for a few minutes ,then twist it anti-clock wise so you have enough turns to screw it onto the water hook up.
Feb 23, 2013 | KitchenAid Kitchen Aid Superba Series...
Instructions for installation of amana water inlet valve 12544001
I know that seems like the incorrect part but it replaces the water valve that had 2 outlet hoses connected to it. To replace that;
Turn off house water supply to old valve and disconnect tubing
remove old valve and unplug the 2 wire connections and the 2 outlet hoses
The two outlet hoses were what was considered a Y hose..cut off semi clear plastic tubing a inch back where the 2 semi clear plastic tubes merge and become only 1
pull one of the plastic nuts off of the Y tube
slip it onto the end of the newly cut single tube
slip single tube into outlet threaded outlet of new valve and tighten that plastic nut
connect the 2 wire plugs onto new valve
remount to back of refrig
attatch house water supply to metal fitting that has/had protective rubber cap over it (oh of course remove procetive rubber cap and discard it)
turn water supply back on
it may up to 4 hrs for water to flow to icemaker so best to test by dispensing water through freezer door
Good luck,any questions or problems please reply and i'll help you,
Gene
Aug 12, 2011 | Amana 22.6 cu. ft. Side-By-Side...
I want my water dispenser to provide cold water
IF YOU PULL OUT THE BOTTOM BIN IN THE REF YOU WILL FIND A COILED UP HOSE, THIS DOESNT HOLD MUCH, PLUS THEY RUN THE HOSE THROUGH THE BOTTOM OF THE REF WHERE ALL THE HEAT IS THEN UP THROUH THE DOOR, STILL NO COOLING THERE. BESIDES RIGGING SOMETHING THERE IS NOTHING YOU CAN DO. THIS IS WHY THEY CALL IT CHILLED WATER, NOT COLD WATER
Aug 11, 2009 | KitchenAid Superba Architect KSCS25INSS...
Water is dispening to slow
check for proper flow and pressure on water supply line
Feb 23, 2009 | KitchenAid Superba KSCS23IN Side by Side...
We are renovating our kitchen & last week my husband moved thbe washer. It is taking in water but it then runs straight back out through the outlet hose....please can you help. It is a Hoover washer...
is the hose lower than the tub as this could lead to the water siphoning out due to gravity, the outlet hose standpipe should be at least as high as the top of the drum
Jul 15, 2008 | Washing Machines
Water is infrequently dispensing from our water line on our refrigerator
the ice maker and dispenser are on different water valves check your water filter first slowly push in your dispenser paddle and listen for a click then hum look at the bottom of the freezer door after removing the kick plate check to make sure the line there is free and not kinked if all that's ok replace the water valves
Feb 12, 2008 | KitchenAid Superba Architect KSCS25INSS...
Water showing mold like substance visible despite 2 new filters
Disconnect the water from the refrig. Get large bowl and turn on water supply. Does water look clear?? Flush real well.
Nov 23, 2007 | KitchenAid Superba Architect KSCS25INSS...
Refrigerators Logo
43 people viewed this question
Top KitchenAid Refrigerators Experts
John Tripp
John Tripp
vince
geob91
Are you a KitchenAid Refrigerator Expert? Answer questions, earn points and help others
