Question about Mitsubishi VS-55705 55" Rear Projection Television
White lines I have an old 55 projection TV about 7 years old, I turn it on and I get these white horizontol and they vibrate. For a while if I keep the TV on for about 15 min. they will go away and evreything was fine , but now the lines are there for good. Can you help please?
  • lollibug5963 Jun 24, 2008
    I have a 55 inch Mitsubishi Big Screen Television model #VS-55705. It turns on, but if you turn it off, it takes about an hour before you get a picture or sound. There are vibrating horizontal white lines running continuously on the screen. I sure would appreciate any assistance. Also, does anyone know where I can buy a repair manual for this model? Thanks, very much!
I have same problem, i have 55 projection tv mitsubishi, i get those white lines. how can i fix the problem.?
thank you.
Posted on Nov 17, 2008
Green light flashes under timer when tv is turned on. no picture
Sounds to me that the DM is the cause. If this model is 7-8 years old, it uses a DM that is no longer available or supported by Mitsubishi. You could confirm this by calling Mitsubishi at 1800-332-2119. This is there Customer Service Line.
Hope this helps,
Skyassoc
Jul 18, 2009 | Mitsubishi WS-55513 55" Rear Projection...
55 inch with blue ghost like glow on white or blue colors
Inside of your TV their is a fluid that keeps the tubes cool. Over the years this fluid will turn cloudy and cuase the screen to look dull, bright white, have halos, etc. You can get the fluid over the internet from various sources or your can get a complete kit including repair instructions from www.TvRepairKits.com.
May 08, 2009 | Philips 55PW9363 55" Rear Projection...
I have a Samsung HCN5529W projection tv. The
yeah plenty, on older rear projection t.v.'s the circuit boards tend to over heat as they get older. keep the t.v. off and unplugged. contact a local repair shop.
Feb 20, 2009 | Samsung HCN5529W 55" Rear Projection...
"Halo" Effect
Projection TV tubes have a liquid coolant that is used to keep them from overheating. After many years the coolant in the blue and green tubes will become cloudy and cause the screen to look dull, red/orange, etc. You may even see halos around images.
What you will need to do is replace the coolant and clean the crt. You can get a repair kit from www.TvRepairKits.com that includes replacement coolant, photos. instructions, etc.
Jan 19, 2009 | Philips Magnavox 55P9271 55" Rear...
I have a panasonic PT47WX51E projection tv. It is about 7 years old and I am getting some faint diagonal lines all across the screen. I was wondering wht the problem may be. Thanks
They are retrace lines , do they have a paticular color, red, blue green or white? Let me know and i should be able to help you with it.
Apr 13, 2008 | Televison & Video
Aging 43H7143
http://cmpalmer.blogspot.com/2006/11/fixing-my-own-tv-part-ii.html
Dec 24, 2007 | Toshiba 43H71 43" Rear Projection...
Pink horizontal line when the tv is powered on.
1. White raster with no signal, washed out looking video with signal. Access the service menu, "menu 0357" use the audio button to select "video chroma" adjustments, use the video button to select item "40 - AGIW", use the adjust button to change the setting to 0, then press the enter button to store the change.
Jun 13, 2007 | Mitsubishi WS-55315 55" Rear Projection...
Phillips/Magnavox 9P5544C102 white raster and shuts down
This denotes a problem called blooming the horizontal lines you see are called retrace lines this is caused by the increase in anode voltage which could be caused by an increase in HV section current which trips the overcurrent protection dircuit and turns the TV off.If you do not have electronics experience I would suggest taking the set to a TV repair shop.
May 29, 2007 | Philips 9P5544C 55" Rear Projection...
Weird lines
your getting a 120 cyclr hum,possible a leaky cap in the power supply also check all ground connections are tight
May 23, 2007 | Sony KP-51HW40 51" Rear Projection...
Open Questions:
Mitsubishi VS-55705 55" Rear Projection Television Logo
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
