Question about Briggs & Stratton Gas Pressure Washer 20244
My gas powered pressure washer starts up then dies right back out..is there something I need to do after starting it
2 Suggested Answers
jeff_drakesr
  • 155 Answers
SOURCE: Gas powered pressure washer wont start
On pressure washers the more you pull the cord the more pressure builds up making it difficult to pull and start. I hold the trigger down as i pull this keeps the pressure down. If this is not the problem then take a look at the Spark plug, Air Filter if all is fine then check the fuel. How often do you use it, fuel loses its Octane when sitting around. Please give a 4 THUMBS UP if this free answer is helpful in anyways. Good Luck and have a Great Day.
Posted on Apr 02, 2010
Why won't my pressure washer start?
Im currious what on a pressure washer required "cleaning" what were you running thru it other than water ?
do you think you might have dissasembled something on engine part and might not have assembled it back quite right?
May 03, 2014 | Stanley 2350 PSI 2.3 GPM Gas Pressure...
Have a honda 5.0 hp engine on a pressure washer model belive is a de 1504 not sure of make, starts if you use starting fluid but then dies, getting gas to the bowl at botttom of carb but not to carburator
Hi there mburns44 i believe your problem is either that either the Air/Fuel mixture is too rich and causing it to flood or you have clogged jets. carburators are tricky and often times need to be cleaned or adjusted by a professional. I hope that this helps :)
Mar 30, 2011 | Devilbliss DeVILBISS Devap DVH2600...
I have DeWalt3750 psi pressure washer, its been long time since I used it, now that I wanted to use it, I can not start it. I already changed the oil and filled it up with new oil but still can not start,...
Here is the long answer with everything we learned while using a power washer twice a day for years::
This assumes you did not turn power washer over or on its side to drain oil, or dirty oil will flow into carburetor requiring complete carburetor cleaning.
It sounds like could be one of the problems listed below or a combination of those things.
1) The exhaust is partially blocked. Check the screen covering exhaust port for carbon and dirt build-up. High-speed exhaust air must pass freely. We finally broke the exhaust screen out with a screwdriver to get our machine going one day.
2) Gas is not flowing freely to carburetor > under gas tank, find the rubber hose connected to carburetor. Pull off rubber hose and make sure gas flows freely. You can use this hose to drain gas tank of old gas ... and then put in fresh gas.
3) Carburetor is partially gummed up and engine cuts off when gas flow slows down. Buy some gum out, and then don't store power washer with gasoline in the tank. Or put additive in gas when storing machine.
4) The choke is letting in too much gas or not enough gas. Try different adjustments. The choke-lever on our power washer got so bad that we could not set throttle at full open or the machine would die. We still use the machine at 2/3 throttle, and then start it each time using WD-40 as described below.
5) Dirty air filter that won't let engine breath enough air to keep up with combustion. Take off air filter and see if problem persists.
6) The spark coil is going bad?? Change spark plug to see if problem persists. Is spark plug wire pushed all the way onto the spark plug?
Now the nitty gritty: we're gonna start that thing right now
7) Take off air filter. Spray WD-40 directly into carburetor. Yes, we use WD-40 every time to start my power washer, and we use the washer twice a week.
Spray in the WD-40, Pull the engine cord. The engine will fire on WD-40. Guaranteed.
Once it starts, keep spraying WD-40 directly into carburetor to keep engine going.
If engine will not fire and keep going on WD-40, then your spark is suspect.
If your engine fires and runs on WD-40 but dies without it, then your gas supply or carburetor are suspect
8) Carburetor problem >>> try Gum out >>> and then take machine to small engine repair shop
9) Spark ... take out spark plug. Put spark wire back on. Hold spark plug by spark wire. Touch metal threads of spark plug to metal opening where plug came out. Metal to metal. Pull back start cord and look for spark between the metal.
If you have no spark, then spark coil is bad >>> take machine to small engine repair shop
Add a comment if you need more help
Nov 28, 2010 | Dewalt 3800 PSI Pressure Washer
It starts but it shuts off immedially.
Nov 01, 2010 | Karcher 2500 PSI Pressure Washer
Can not start the engine
Nov 01, 2010 | Karcher G3025OH Pressure Washer
It shuts off during use then starts right back up.
Most of the time it is due to fuel lock - very hot engine. Easy to check, run engine with gas cap loose (not with full tank, fuel may spill out). Replace cap or open vent if necessary. Other problems include low or dirty oil causing oil senser to shut down engine, or hot engine due to obstruction of airway under cover and finally pressure set too high. I find that most pressure washers are set to max pressure. I like to set pressure to 70 % of capacity making components last longer. How long would a car/truck last if you drove it at max speed everywhere? Good luck with your repair.
Jul 07, 2010 | Coleman Pressure Washer PW0881800
I have a hoda pressure washer it stats right up and while i was cleanning the wood fence i let go of trigger during about 10 min, and the motor started dying i pulled the trigger and it pick right up again...
A couple of things, what makes the engine change tone and revs is pressure, depending on the age, it may have excessive calcium build up in the pump, there may have also been a build up of crud or a wasps nest in the end of the hose when you connected and is now in the actual pump, you can remove the base and flush the sytem, hope this helps the problem, good luck.
Jun 01, 2010 | Devilbliss DeVILBISS Devap DVH2600...
Last year around this time I tried to start my
Carburetor is probably gunked up from old gas left in system. It will need some cleaning and / or dissasembly.
Have it repaired at a reputable mower or small engine repair shop. When being stored for long periods, run it out of gas or use a fuel stabilizer in the gas to prevent this from reoccuring.
May 13, 2010 | Honda 2500 PSI Gas Pressure Washer
Briggs & Stratton Gas Pressure Washer 20244 Logo
307 people viewed this question
Top Briggs & Stratton Garden Experts
Phil Walker
Phil Walker
John Trevino
donald boissonneault
Are you a Briggs & Stratton Garden Expert? Answer questions, earn points and help others
