Question about Hammering
Why 1 flickering light?
I have 2 porch lights out front of my house. The 1 closest to the front door periodically flickers every 30 to 45 seconds and does this throughout the night. Why is this happening and should I be concerned that it may have to do with the fact that this house has its original wiring from when the house was built in late 1930's? Or maybe just a dirty connector?
  • Hannah Schroeder
    Hannah Schroeder Oct 10, 2017
    Wow, it's amazing that your house still has original wiring from the 30s. I have a similar problem, except the flickering happens in my bathroom and it makes me nervous about using water around electrical problems. I think it would be best for both of us to call an electrical maintenance service to deal with our problems safely.http://www.kunselmanelectric.com/residen...
    Novelist:
  • 135 Answers
One of the first things that you want to check, is the wire connections above the light that is flickering. It would be a good idea to check the first light also, and the switch connections, due to the age of the wiring. If all this fails, then you are probably right and the socket of the flickering light should be changed.
It would not hurt to go in grids and work your way thru the house, checking the wiring and tightening the wire nuts, or connectors.
Enjoy :)
Paul
Posted on May 10, 2010
Periodic battery light flickers on my 2003 town car.if you just tap on brake or flicker headlights .is there a separate diode that could cause this?
You have a defective alternator, that what is most likely causing the flickering light. A voltage output test will not reveal this.
May 19, 2016 | 2003 Lincoln Town Car
Tip
How to reset the machine
Reset Procedure for Equator / Hirundo ( EZ3612CEE / EZ2512CEE / EZ1612V )
If the door of the machine is opening you can follow the below reset procedure so that the machine will function properly but if the door in your machine is not opening you need to first get the door to open by following the procedure as stated in the link http://www.fixya.com/support/r4240518-door_not_opening_in_equator_hirundo
Resting the unit will make sure that all the memory storage in the chip will be erased and hence the unit will be ready for a new cycle.
Reset Procedure
  1. Make sure that the machine is turned OFF.
  2. Make sure that the door is opening.
  3. Set the dryer & wash temperature knobs to the off position (12 o'clock / pointing vertically upwards)
  4. Make sure that the door is latched properly.
  5. Set the washer knob on the Red Reset position and switch on the power.
  6. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  7. Once the light starts flickering slowly turn off the power.
  8. Set the washer knob to the Green Reset Position and switch on the power.
  9. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  10. Once the light starts flickering slowly turn off the power.
  11. Set the washer knob to the Grey Reset Position and switch on the power.
  12. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  13. Once the light starts flickering slowly turn off the power.
  14. Set the washer knob to the Reset Position on Delay Time and switch on the power.
  15. You will observe that the mode + Door Lock light flickers rapidly for a few seconds and then flickers slowly.
  16. Once the light starts flickering slowly turn off the power.
You have now reseted the unit and the unit should work fine now , in case you observe that the washer knob/Dial is going round and round all by itself now please go through the link for fault codes for further diagnosis.
Hope this procedure helps.
on Mar 02, 2010 | Washing Machines
Porch light timer switch problem
0192773 is single-pole only.
I think you have wires reversed or attached incorrectly:
http://waterheatertimer.org/How-to-wire-timers.html
http://waterheatertimer.org/Program-wire-Utilitec-0192773.html
Gene h
If you need further help, I’m available over the phone at https://www.6ya.com/expert/gene_9f0ef4df2f9897e7
Mar 31, 2014 | Hardware & Accessories
Lights flicker in circuit with dimmer switch
Dimmer gone bad.
Buy new dimmer.
Check total wattage of bulbs, and compare with watt rating of dimmer.
Check if dimmer feels warm
reduce watts in ceiling linghts
http://waterheatertimer.org/How-to-wire-3-way-dimmer.html
Gene
h
Jun 26, 2013 | Electrical Supplies
Light flickers when door is opened
it has connection problems when you open the door of freezer connecting wire turn gradually and one time comes up light normally,you repair connecting wire of lights.
Mar 23, 2013 | Frigidaire 20.3 Cu. Ft. Frost-Free Upright...
Furnace fires but cuts out after 10 seconds. Yellow lite flashing 2 times continuous. Green light flickers and sfter furnace cuts out gos bright green for 2 seconds and then goes back to flickering.
Since you didnt include Brand and Model number, you could check on the inside of'
the front panel you take off to access the furnace. Most have a diagram of the wiring
and will have an Problem Code list that tells you what those flashing lights indicate.
Good luck and feel free to reply with Brand and Model #
Mar 31, 2011 | Heating & Cooling
New Leviton 'lighted, decorative' switch flickers when off
You cannot use standard electronic dimmer switches with CFL bulbs, only incandesant bulbs! That is why you are getting the flickering.
With CFL's bulbs installed in a light fixture that has a non-flouresant rated dimmer switch on that circuit, you will cause the standard dimmer to fail.
You have to look at the dimmer package (sometimes printed on the back of the dimmer itself too) to see if it can be used with CFL bulbs,as many are not rated for use with anything other than standard incandesant bulbs.
Hope you found this very helpful and best regards!
May 31, 2009 | Leviton Decora Light Dimmer Switch
Sony Trinitron Colour TV Stopped showing and switch light flicker
The vertical output IC has failed/Power to the vertical IC is out/ or there is bad solder on the pins of the vertical output IC.
Dec 01, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Hammering Logo
576 people viewed this question
Top Hammering Experts
John Trevino
Steve
Pieter Vleeshouwers
Pieter Vleeshouwers
Are you a Hammering Expert? Answer questions, earn points and help others
