Question about Excalibur 201CS Remote Control
I have a excalibur 7 in 1 football remote but dont know how to set it up or have no code,can you help me?
My Excalibur echo remote will not start my Chrysler 300 anymore, is there a reset or reprogram I can do?
Set-up (Programming) procedure is too much to type in here, and is not practical and it will differ brand-to-brand remote controls. If you wish to get more; check the sites linked here. It has set-up code list & set-up procedure to many popular brand remote controls. One among it has general set-up codes to check with TVs and other devices are given, in the order of the 'device's brand name list' in alphabetical order. Pull up older posts. Search the sites by type in the brand name to your device in its search box at the top right part of the display window. It will help you to find the document easily.
http://remotesearch.blogspot.com/
http://electro-medical.blogspot.com/
http://electrohelponline.blogspot.com/
Search the site by type in the brand name of your device, in the "Search box at the top right of the Home page display" to see the set-up codes to your device, with different brand remote controls.
Programming Notes
• If your device does not respond to the remote after trying all codes listed or your brand is not listed in the code list, use the Auto Code Search method to program your remote.
• Sometimes the first code that "works" with your device may operate only a few functions of your device. There may be another code in the code list that performs more functions. Try other codes from the code list for more functionality.
This is a trial and error procedure; and quiet time consuming. You might have to check different codes said for your device.
Feb 09, 2016 | Excalibur Echo3 2 Way Remote
How do I program my football remote to a TiVo box?
Nov 07, 2015 | Excalibur Televison & Video
Have codes but don't know how to program my football remote 201-NFL
Check these links for more details about the set-up procedure. http://remotesearch.blogspot.com/
Pull up previous posts by its left sidebar, or type in the brand name and model number to of your set, to its search box, and press 'Enter' or view it in Mosaic / Timeslide option.
Sep 30, 2013 | Excalibur Electronics 201CS Monday Night...
Dvd codes and which device to use
If you wish to get setup codes, three digits, four digits or five digit ones, check this link. Pull up older posts there. Setup code list and setup instructions to some popular model remote controls are given. Select the 'Timeslide' option from the drop-down list by the 'Sidebar' at the display window. It will make search easy.
Mar 21, 2013 | Excalibur Electronics 201CS Monday Night...
I lost the manual for my monday night football tv remote how can i get the codes for a viso tv
You can get the manual and codes on the link below. There is no codes for the Viso Tv. you will need to do a code search.
Manually turn off the device that
yo11 wish to control. Press and
hold the key for the device type
(TV, VCR, CBL or SAT) that you
wish to program your football to
control. After about three seconds,
the red LED near the
threads of the football will come
on. This indicates that your football
is ready to program.
Press the ONIOFF key Cjust to
the left of the TV key). Press the
CH+ key repeatedly until the
device turns on. You may need to
step through quite a few codes
until this happens. Once the
device turns on, STOP. Do not
press the CH+ key again.
Press the ENTER key t9&?cept
the programming. Your football is
now programmed to control the
device.
Note: If none of the brand
codes for the device work, go to
www.ExcaliburElectronics.com
for more information.
Follow the above steps for any
other device(s) that your football
will be used to control.
http://www.smarthome.com/manuals/8059_manual.pdf
Jul 02, 2011 | Excalibur Electronics 201CS Monday Night...
Will the excalibur touch remote work with another excalibur alarm i dont have the alarm model number but do have the alarm that i have on my car remote fcc # and it is a remote start alarm too the fcc...
The Touch remote can be used with any Echo compatible systems. These systems can be identified by their model numbers. Systems ending in E, EDP and EDPB are Echo compatible.
Dec 11, 2010 | Vehicle Parts & Accessories
Excalibur car alarn
i have a Excalibur AL1830EDPb Remote Start Alarm 2 Way. I only have a range of about 60 ft from from the car, should this not be about 3000 ft
Jul 26, 2009 | Excalibur AL1810EDP Remote Start Alarm 2...
Need Directions
the directions were in the bottom of the plastic encasing.
Dec 25, 2007 | Excalibur 201CS Remote Control
England football tv remote
if this is the one i have just bought then you tune it by:
1. Press desired function (eg tv)
2. Hold down P+ and VOL- simultaneously for 2 seconds until indicator lights up
3. enter 4 digit code, indicator will go out
4. test if remote works.
if your code dont work you can try the scan option, not sure what its called, sorry
3. enter a magic search code from these
a. tv=0001
b. vcr=0002
c. sat=0003
d. ctv=0004
e. dvd=0005
(eg press 'TV' device key, then P+ and VOL- and enter tv magic code 0001)
4. Press same desired function key again (eg tv)
5. Hold down P+ and VOL- simultaneously for 2 seconds until indicator lights up and the remote is ready to search
6. pres the england key repeatedly until device turns off
7. immediately press P+ and VOL- when the device switches off to lock in the code.
Hope i have helped with this.
Craig
Sep 23, 2007 | Televison & Video
Televison & Video Logo
161 people viewed this question
Top Excalibur Televison & Video Experts
Electro Med Services...
richie46
Are you an Excalibur Televison and Video Expert? Answer questions, earn points and help others
