Question about Konica Minolta PagePro 1350W Laser Printer
Will only let me print to file
When i hit print - it doesn't and opens up a print to file box, i don't have the print to file checked
any thoughts?
Click on konica minolta properties, go to ports then check the correct port. Uncheck the print to file box
Posted on May 02, 2008
Dell V715w all-in-one print job stuck in que
Go to your search programs and files box in the start menu and type in services when you open services scroll down to Print Spoolers double click and you will see service status started hit the key that says stop after it stops hit OK to close it and reopen Print Spoolers and click open tab and then hit OK to close then close services box and you should be able to print again.
Good Luck
Aug 16, 2012 | Dell All-in-One Multifunctional (v715w)...
I want ti print in color only,how do i do that,?Lexmark X1240 All-In-One InkJet Printer
On your computer, with your file open (your document/picture, etc. that you wish to print), click File > Print. From Print dialog box, click Properties, Preferences, Options, or Setup (depending on the program). The Print Properties dialog box appears. From the Quality/Copies tab, make sure there is no check mark in the "Print Color images in Black and White ". Then hit OK button to save the setting. Once you print your colored document/pictures, etc, it should come out in color.
I hope this helps.
Dec 02, 2011 | Lexmark X1240 All-In-One InkJet Printer
My files are created in adobe pagemaker now I want them to convert in jpg or pdf format how?
1. Save the Pagemaker document. If you don't do this before proceeding, a pop-up box will remind you.
2. Go to File>Export>Adobe PDF. A dialogue box of PDF options will come up.
3. Determine what you want to use the PDF for. If you are exporting for a specific print job, the printer will give you Distiller settings. Otherwise, in Job Name, just choose the settings that most closely meet your requirements: High Quality Print for a printout, Smallest File Size for a document that will be viewed online.
4. Click "Export." An "Export PDF As" dialogue box will pop up. Choose the folder in which you wish to save the PDF, and name the file. Check the "View PDF" box, so the PDF will open after it has been created.
5. Watch the dialogue box. It should show that Distiller is creating the file. When finished, the PDF document will open.
Good Luck!
John Vickers
Aug 13, 2011 | Computers & Internet
Recently I have gotten a message,
The application you are using is calling for a specific size or type paper in tray 1.
For example, you have "Executive" size paper and the job needs Letter size.
Easiest fix is to make sure your "Page Set-up" matches what you have in Tray.
Failing that, you can also, open tray 1, pull it most of the way out and then push it back in. This will force a re-read of the paper size. Then press the "Green" button.
If it still happens, use the "Print To File" check-box on the Printer Properties screen and then name the print file something like "tray1fail" and send it to me at and I'll be happy to run it through some of my file readers and tell you what the print job is looking for. There is no fee or charge for this. I actually enjoy reading print files.
Feb 11, 2010 | Lexmark Optra S 1625 Laser Printer
Tried to cancel a print job--now stuck in "deleting" status. How do I fix this?
I suspect that on the bottom right of your computer screen you will see a small printer icon. Double click on the icon and it will open the print queue.
You will see the troublesome print file. Highlight the job and then go to the top of the box and delete the highlighted file.
Feb 06, 2010 | Lexmark X6675 Pro Colour Wireless...
Re-try the print option. When the driver window opens, read through the options. Look for a box that says, "Print to file". If the box is checked, uncheck the pox.
Jan 22, 2010 | Office Equipment & Supplies
Avery design pro will not print with my HP C5500
I found an odd workaround. Probably a better one available, but this worked for me. When you select Print from Design Pro, in the printer drop down box select Microsoft XPS Document Writer instead of your printer. Click OK, enter a file name, and save. That will save a .xps file. Next, open the .xps file and print it.
Dec 13, 2009 | HP Photosmart C5580 All-In-One InkJet...
What kind of printer are you using?
If you are trying to print a PCL PC-XL or PostScript file, go into the printer driver and click the "Print to File" box. Then send the print file to me at I can look at the file with some lab tools that I have and see if I can find the failure.
You can cancel the print job that is active in the queue by double clicking on the printer icon (lower right of the screen) Then highlight the print job and select cancel from the menu at the top of the queue box.
Nov 20, 2009 | HP Office Equipment & Supplies
No color prints
When you tried to print, did you press the button for black or color? Either one of these will be the start button. If you hit color and it still prints in B&W, the other solution is to the pop-up box should come up then you click on advance options. file-print --then click on preferences just below your icon list of printers. Two pop-up boxes will appear. close the smaller one (I want to...), and the other box should stay open. You will see on the lower right corner the box to check off for "print color images in black & white. Make sure the box is unchecked. then click ok, and print.
Dec 11, 2007 | Lexmark X6170 All-In-One InkJet Printer
Konica Minolta PagePro 1350W Laser Printer Logo
Top Konica Minolta Office Equipment & Supplies Experts
Norman  J Weimar Jr
Norman J Weimar Jr
Adorjani Laszlo
Are you a Konica Minolta Office Equipment and Supply Expert? Answer questions, earn points and help others
