Question about Mtd 22" Yard Machine Push Mower
What is the fuel mixture required for model 60-1683
    Sniper:
  • 52 Answers
Unless this is a 2 cycle engine you don't mix anything with the fuel.
Posted on May 06, 2010
Why doesn't it idle unless choke is on?
Maybe you are running too lean. When the choke is on it reduces (chokes) the air being drawn in meaning higher fuel to air mixture (richer because of more fuel and less air). Turn the choke off and more air is drawn in and the fuel to air mixture is reduced. There should be a mixture screw where you can alter the mixture to the required setting for normal running.
Feb 16, 2016 | 2004 KTM SX 450 racing
On the homelite DM 50 model 05020 what is the fuel mixture ratio?
What Fuel Mixture Do I Use for a Homelite Chainsaw Model ...
homeguides.sfgate.com > Foreclosures > Avoid Foreclosure
It has a two-stroke engine similar to newer models made by Homelite. The recommended fuel mixture is a 50-to-1 ratio of unleaded gasoline and two-cycle ...
Oct 25, 2015 | Homelite Garden
Why does engine surges at idle on craftsman lawn tractor
Probably has partially clog idle mixture ports which will require a carburetor cleaning to fix or simply need the fuel idle fuel mixture adjusted.
Jun 15, 2014 | Craftsman Garden
Workshop manual for pro mac 5700-20 chainsaw required.
You may contact the manufacturer, download manuals, check fuel/oil ratios, order parts, find your local service center, and view other resources using these links:
Contact us
User manuals
What is the correct fuel mixture for McCulloch products Chainsaw Trimmer...
McCulloch Service
McCULLOCH PARTS ACCESSORIES
I trust this information has proven beneficial.
Jul 11, 2012 | McCulloch Garden
Amt. of oil to replace at change in Husquavarna chain saw model CRT53
Chain saws don't require oil changes--the bar oil is 'constant loss' from the oil tank while running--just top up the tank before and during each use. Husqvarna does recommend draining and cleaning fuel and oil tanks before storage (not sure how many folks pay attention to this). The fuel mixture is also 'constant loss', so there is nothing there that requires changing--just be sure to use fresh fuel and always shake the container before adding to the saw to make sure the saw oil is properly mixed. Hope this helps!
Oct 04, 2010 | Garden
My weed eater wont turn on it keeps turning off as soon as turned on it is really frusterating sorry if i spelled that wrong
Most two stroke engines in weed eaters require a premixed fuel combination of gasoline and two cycle oil. I am assuming you have a gas model which needs a gas and oil mixture. A possible problem is the choke is turned on, and once it starts you need to move the choke to run. Another possible problem is the gas oil mixture is incorrect, and you may need to remix the fuel to the manufactures recommendation.
Jul 23, 2010 | Garden
Developing a ping... not bad gas, low miles
It may not be bad gas, but it could be the wrong octane rating for that engine. Check your owner's manual and see what octane is recommended for that engine. If you're running 87 octane and it requires 91 or higher octane, then you need to be running the higher octane fuel. By running lower octane fuel in an engine that requires higher octane, your getting pre-ignition, the knocking sound you hear. What's happening is that as the piston moves up on the compression stroke, the gas/air mixture is compressing and as the pressure goes up, so does the temperature of that mixture. It's possible that temperature can get so hot that the gas/air mixture ignites from the high temperature and not from the spark plug. Higher octane fuel will help this since higher octane fuel is harder to ignite. I say try running some 92 or higher octane fuel in your car and see if you still hear the knocking.
Jun 06, 2010 | 1986 Lincoln Town Car
What is the correct fuel mixture for this machine
Every Stihl I have ever touched requires 40:1 fuel mixture.
Jun 02, 2009 | Garden
Fuel requirements for a Stihl 131 Polesaw with the 4mix engine?
hi Ray
For your polesaw Stihl HT 131 with 4 mix engine you need a fuel/ oil mixture.The lubrication of the engine is realised through the fuel/ oil mixture(you need a superior quality of the oi for the mixture ).Buy it from an authorised Stihl dealer shop.Any other oil is not needed on the 4 mix engine.
best regards savumihai71
Dec 05, 2008 | Garden
Hot starter
4 stroke engines require a leaner than normal fuel/air mixture to start when hot. The cold start choke allows more fuel into the mix. The hot start choke allows more air into the mix.
Nov 20, 2008 | 2005 Suzuki RM-Z 250
Mtd 22" Yard Machine Push Mower Logo
Top Mtd Garden Experts
Jim Parker
Jim Parker
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
