Question about Mtd Garden
Mastercut model 130-317D002 8hp 32" It started making a loud grinding noise in forward gear only.still moves forward and reverse in all speeds, just a loud grinding noise in forward. What do you think it could be?Ive had this mower for almost 20 yrs. Hate to part with it. It's been good to me. Thanks, Mike
  • 8 Answers
SOURCE: riding lawn mower
belt is twisted
Posted on Nov 15, 2008
SOURCE: Amana Mod # ABB2223DEB Refrigerator
I found this problem addressed on applianceblog.com and per they recomended part # 67006166. My repairman ordered this part and it had been superseeded by an even newer version, # 10127429. He installed that newest version in late June 2008 and it has been great ever since. So for me # 10127429 was the answer. Hope this helps
Posted on Dec 03, 2008
  • 22 Answers
SOURCE: New MasterCut mower runs erratic & gasoline leak around fuel cap.
as it is a new machine if it has not been p.d.id by dealer it may be that some test fuel residue is in carburettor which is causing this,you need do drain of carburettor of all fuel,remove bowl and spray clean useing either air or carb cleaner spray(should get from local autoparts store) note try to spray up centre of carb as may be a jet up there as well,refitt bowl and make sure you use fresh fuel this should solve problem,with unstable running fuel may be finding a way back through breather at carb with the vibration and may be cured after you have done carb
Posted on Mar 30, 2009
  • 45 Answers
SOURCE: Our shredder is making a loud, grinding noise.
simply try resetting the machine. unplugging it waiting for about 30 seconds then plugging it back in, also is the unit mounted properly on the unit? It might be one of the gears that is not broken...if you have a warranty now would be a good time to call them as they will fix or replace the part for the unit.
Posted on Apr 15, 2009
  • 77 Answers
SOURCE: My Toro Lawn Mower Model 20016 no longer moves
Your transmission is bad,need to have one ordered.
Posted on Aug 12, 2009
2001 Tahoe 4wd isn't engaging in 1,2,or 3rd or drive. It only goes forward when the gear shift is on reverse and when it starts to move it makes a loud clunk noise and grinding.
Not sounding to good. Sounds like you wiped out the planetary gears. Depending on the damage, your looking at $2000 rebuild.
Feb 07, 2016 | 2001 Chevrolet Tahoe
Transmission making loud grinding/sucking sound, doesn't go when in drive or reverse
Is it an automatic John? When was the last time you checked the level of your ATF (automatic transmission fluid)?
There are many different types, so make sure you get the right one.
If it is a manual shift, check the gearbox oil level. If that is OK, you need a transmission specialist. Look in Yellow Pages.
Nov 26, 2015 | 2000 Pontiac Grand Am SE
Mr car is making a loud metal grinding noise when put in gear to go forward what's wrong
You could have broken the axle shaft. It can break in the cv joint and just spin or on some models the axle splines can strip out of the axle hub. The car usually won't move or it can move only a little and then stop with grinding noise.
Jun 06, 2015 | Cars & Trucks
97 wrangler wont drive forward in 2wd. just makes a loud grinding noise but will drive in reverse
sounds like rear end is coming apart
google wrangler forums and post there
Feb 03, 2013 | 1997 Jeep Wrangler
TAPPING NOISE, NOW IT WON'T GO INTO GEAR WITHOUT LOUD GRINDING NOISE AND ACTS LIKE TRANSMISSION WON'T ENGAGE TO DRIVE
If it is an automatic transmission, first check the fluid level. If it is low, fill it up and try it again. If the level is fine, then there is a bigger issue and you should seek a professional's help.
Jun 18, 2017 | 1996 Buick Century
T-Maxx 3.3 wont drive
Sounds like an internal gear problem with the transmission. I would remove the transmission and open it up, anything that is broken will be easy to spot. All of the parts are available at a local hobby shop or from Traxxas directly.
Jun 19, 2009 | Traxxas T Maxx 3.3 Monster Truck
Engine runs vehicle wont move Possible ring gear? 84 Topaz
Is it a metal shaft? When you put it in drive does it make any noise? Does the speedometer move? Does it make a loud clicking sound when you put it back in Park?
May 23, 2009 | 2002 Ford Explorer
Garden Logo
61 people viewed this question
Top Mtd Garden Experts
Roland W VanLue
Roland W VanLue
Tim Whalen
Phil Walker
Phil Walker
Are you a Mtd Garden Expert? Answer questions, earn points and help others
