Question about Insignia LCDTV26 26 in. Television
Hd audio problems
Audio is fine without hd, but with hd it is popping at the top of the sylable, very difficult to understand, also the set up button will not allow access on the screen.
  • Charlie D Apr 02, 2008
    audio is fine without hd, but with hd it is popping at the top of the sylable, very difficult to understand, also the set up button will not allow access on the screen.
    menu screen no access to set up button, its greyed out and skips over it as you scroll down. No lock symbol.
  • Insignia Master
  • 19,396 Answers
Seems you have an hardware fault .
You should also test or have tested from a service centre, the DTV board, which is the main board inside the tv, or the audio board, one of them may be faulty.
if your TV is still under warranty, call Insignia. You just have to pay for shipping and shipping insurance.
Otherwise contact them and ask details on nearest authorised service, or part dealer to buy replacements.
Insignia Contact Information Main support number 877-467-4289
Email support [email protected]
Regards.
Posted on Mar 31, 2008
  • 818 Answers
  • 3,037 Answers
Is the setup showing any kind of lock symbol, the audio with the hd on this tv has shown similar problems. Let me know about the lock symbol.
Posted on Mar 29, 2008
  • Benjamin Patri
    Benjamin Patri Apr 02, 2008
    found your problem off of the Best Buy website
    Built-In HDTV Tuner: Add HD-capable antenna to receive
    over-the-air high-definition broadcasts, where available. Optional
    set-top box required for high-definition cable or satellite programming.
    Guru:
  • 1,894 Answers
There is some problem with tour vertical and horizontal IC i think
SOURCE:
Motorola sd 10 hd bluetooth stereo headphones. the buttons dont work properly. the product is very difficult to power on. what could be the problem? i m from india with 220 v output. the charger provided...
You can use the original charger on your headphones without the need of a step down transformer. It is possible that the age of the battery is causing your problem too.
Jul 28, 2017 | Audio Players & Recorders
Why do i have echo when i play music on my phonic powerpod 820 mixer
Visit this link to download the manual if you don't have it already. https://phonic.box.net/shared/crqxhlhmmz
This mixer has a multi-effects processor onboard, but the key is understanding the audio signal chain. There is a chance that you have your input audio going through an undesired effect, but without knowing your setup (input source, connections, mixer settings), it would be difficult to pinpoint the problem.
Apr 04, 2011 | Phonic Powerpod 820 Mixer
I have recently linked my playstation 3 up to my new lcd 42 inch full hd tele. since doing this the movement on the screen and commands are slightly behind when i press the button on the pad. its like im...
Often times there is lag between game systems and HD t.v.'s, caused either by the use of HDMI cables and or audio/visual lag. The severity of this depends on the game.
If a game has audio/visual lag problems, there should be an option to compensate for it in the options menu. If it is a problem with usage of HDMI cables, try using different cables. If that doesn't make a difference, then you'll have to use regular old A/V cables.
Mar 10, 2011 | Sony Playstation 3 (PS3) Console
My lap top is telling me I don't have any audio devices
if sound is working on laptop but not on skype, then the settings in skype needs to be set to you audio. go in to skype setting and audio and click on your audio and make it default, same for the mic choose the one you have and make it default. and click on save or ok when done.
Jul 04, 2017 | SMC Realtec Network Card NERENC01
Synergy V rt-u64cp remote to control Receiver volume
For those who want your audio device volume to work without changing modes here's how: hold cable and select until cable lights up - then press volume+ and then press audio. That's it.
Apr 06, 2009 | Televison & Video
Aspect ratio problems on Samsung LN-S2651D Flat Panel TV
The aspect ratio (zoom) button on the cable remote had been changed. On Brighthouse the # button toggles through the zoom settings. It's not a tv issue, it's a cable fix.
May 29, 2008 | Televison & Video
I purchased my Onkyo TX-SR 606 a few days ago from a shop in Nottingham. I finally got it connected up only to notice that I cannot receive any of the high definition sounds when playing titles such as I...
You need to set your PS3 to output "Linear PCM" and not "Bitstream" in the Bluray preferences. PS3 does not support sending direct TrueHD/DTS Master HD signals and thus they will not light up on your receiver. If you press the triangle button on the PS3, in the top it'll confirm which audio codec it is decoding.
May 12, 2008 | Onkyo Audio Players & Recorders
Audio problems for HD part fine for non hd
I put this in your first post but this is off of the Best Buy Website, looks like this is your problem
Add HD-capable antenna to receive over-the-air high-definition broadcasts, where available. Optional set-top box required for high-definition cable or satellite programming.
Apr 02, 2008 | Insignia LCDTV26 26 in. Television
Player went blank
I can't turn it on too!Do you understand what is the problem?
Mar 08, 2008 | Samsung Yepp YH-J70 Digital Media Player
Adjusting screen on HD TV
I had the same problem. My cable company told me to press the # button on my remote to change it from "zoom" to "normal" and it solved the problem.
Oct 21, 2007 | Televison & Video
Insignia LCDTV26 26 in. Television Logo
159 people viewed this question
Top Insignia Televison & Video Experts
Jaime Hernandez
Are you an Insignia Televison and Video Expert? Answer questions, earn points and help others
