Question about Fedders R6DH45X Dehumidifier
The water container has cracked and does not hold water. Where can I buy a water container replacement?
  • Fedders Master
  • 43,501 Answers
Follow this tip to see if you can find the part you need... dehumidifier parts are not all that common and are not readily available...
How to Buy Appliance Parts Online
http://www.fixya.com/support/r3907570-buy_appliance_parts_online
How to find Air Conditioning, Heating and Furnace parts online
http://www.fixya.com/support/r4016017-find_air_conditioning_heating_furnace
heatman101
Posted on May 07, 2010
Water is dripping from the base
Hi Dawn:
Check:
- to see that the holding tank is located properly
- That the holding tank is not cracked
- that the holding tank is not full and overflowing
- that there is not a drain hose disconnected.
Cheers.
Oct 24, 2015 | Dehumidifiers
Hi I have problems with my mitsubishi dehumidifier Oasis Elite MJ-E-142NX-A1 The water tank full light stays on even though the tank is empty. I have emptied the water and replaced the container care
Sounds like your float is stuck in the full position, or the sensor that shows full is stuck on full.
If tank is empty but shows full, problem lies where full signal is coming from.
Aug 19, 2014 | Dehumidifiers
Unit is not collecting water and carpet is wet
Unplug it and let it dry out. Place it on old newspaper and start. Check the paper and look for the wet spot. That will let you know where the water is coming out of the unit. Check that area, it is probably a bad seal on the drain or a crack in the water container.
Feb 16, 2014 | Whirlpool AD50USL Dehumidifier
Dehumidifier leaks at the bottom and runs on the floor
Feb 15, 2014 | Dehumidifiers
A PUDDLE OF WATER FORMS UNDER MY DEHUMIDIFIER WHEN IT IS RUNNING.
Dehumidifiers have a container that holds the water the the unit extracts from the air. If that container is full or not placed correctly, the water will leak out of the unit.
Aug 05, 2010 | Haier DM30EAL Dehumidifier
Tubing to drain the water into the container for the Amcor TC 120
take a sample piece of tubing to a home improvement,hardware,or appliance parts store to match it up.
Sep 29, 2009 | Dehumidifiers
Unit runs but doesn't pull humidity out of room, filter clean
Possibly lost refrigerant from system- check warm air is coming out of machine. Otherwise it could be dirty filters, and not getting enough air over evaporating coil. Other than this, replacing parts is usually more expensive than buying a new dehumidifier :(
Jul 18, 2009 | Dehumidifiers
FULL LIGHT FLASHES
An automatic overflow switch and Container “Full” indicator light are provided to turn the
dehumidifier off before the container overflows. When the indicator light on the control panel
glows, the water container must be emptied. If the light remains on and the dehumidifier does
not begin to operate make sure the float is attached to the water container.
When the condensate water container is full, the indicator lights up.
1. Turn the power off before removing container. Wait 3 minutes for
any remaining water to drain into the condensate container.
2. Tilt the container forward then lift carefully by the handle.
3. Empty and gently re-insert the container.
Important:This water is not suitable for drinking.
Please rate and god bless:)
Apr 24, 2009 | Fedders A7DH45B2A Dehumidifier
Fedders R6DH45X Dehumidifier Logo
63 people viewed this question
Top Fedders Dehumidifiers Experts
Bill Long
jasbo
jasbo
dadr
Level 1 Expert
Are you a Fedders Dehumidifier Expert? Answer questions, earn points and help others
