Question about Panasonic Toughbook CF-29 Notebook
How to remove the present cd drive from a CF-29 toughbook?
    Novelist:
    Scholar:
  • Panasonic Expert
  • 105 Answers
The cd rom drive on the CF-29 is a modular, removable drive.
When you open the left side cover, the cover has a small square symbol which is "MP". MP stands for Multimedia Pocket which is what Panasonic calls the drive bay where is the cd rom drive is installed. On the bottom of the Toughbook is a sliding cover which has a left arrow sysmbol <MP RELEASE which stands for Multimedia Pocket Release. If you slide this cover completely to the right side and the left side cover is open, then you will see a new switch which you push to the left side. This will release whatever drive is in the multimedia pocket and this can be replaced by a CDRW/DVD Drive. The approx. cost of the drive should be maximum $50 for a used drive plus taxes and shipping. At least this is how much we charge for a CDRW/DVD Drive.
Good Luck.
Richard/Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989
Posted on Oct 02, 2017
harvester3
  • 181 Answers
SOURCE: Panasonic Toughbook CF-27
You need to access the bios, and set the boot order properly.
What  kind of external cd drive is it? If it's usb, I've never had any luck getting the system to actually load off of one.  The CF-27 came with a pcmcia optical drive, which works pretty well.
I've got a couple of cf-27 cd roms which take the same slot as the floppy. Loaded XP on one of ours.
Good luck.
Posted on Oct 27, 2007
SOURCE: Install XP on Panasonic Toughbook CF-27 ?
I'm doing a clean install of XP but I can't do this as setup won't start bcoz the drive isn't bootable
Posted on Apr 30, 2008
leecom72
  • 4806 Answers
SOURCE: Panasonic c-29 toughbook BIOS Password breaking
you have to remove or unplug the cmos battery which is attached to the motherboard inside the laptop, doing this will clear all passwords. If the password clears replace the battery.
Here is some more usefull info if you want to this yourself>
The guts of the machine are usually under the keyboard. If you are okaywith opening up the laptop, you'll need to remove a few screws, thebattery and the hard drive, then carefully pry up the keyboard to gainaccess to the items that the manufacturers say you shouldn't tamperwith. If its just a matter of getting into the bios and theres apassword, you can usually simply remove the battery and leave itwithout power for at least 24hours, then it should reset....doesn'talways work but since most laptops actually do not have a standard cmosbattery, this would be one way to go about it. Of course you could justtry to figure out what the password is, someone has to have put it inthere so they should know what it is, or you could go to http://tcc.toughbook.com/ and get the bios update, which will reset it completely.
Posted on Nov 15, 2008
1234s282
  • 144 Answers
SOURCE: keyboard installation for CF-52 toughbook
Here you , this is a step by step disassembly guide with pictures
Its for a Toughbook CF-50 but it should be similar as theres not too much difference in the model number
http://www.machinaelectronics.com/store/library/article.cfm?f=key_type_k17
Posted on Jan 04, 2009
1alexh
  • 484 Answers
SOURCE: upgrade hard drive in panasonic toughbook cf-50
1 - Using a stack of DVD RW blank disks, or a large capacity USB Flash/Jump Drive, back up your Laptop computer completely. If necessary, Use WinZIP to ensue that everything has been compressed into the smallest capacity possible.
2 - When you are certain that you have backed up the drive completely, remove the older drive
3 - Line up the new drive and the old drive and ensure the jumpers are set to the same settings as they were set on the older HDD.
4 - Once you are sure, you then restore everything from the back-up drive for the old hdd to the new disk drive.
5 - Test to ensure that everything from the old drive has been backed up from the old drive to the new drive.
6 - If you are comfortable that your backup has been completly restored from the backup meda to the new, larger hard drive, then be certain that you have restored from the older drive to the new drive, tighten all screws and cables, then close all ports and ensure that everything has been done properly by and for you.
7 - Be certain that you have created the same user accounts in the new drive as you had on the older drive.
8 - Now, power off the new drive while in the laptop. Wait about 30 seconds to one minute, then restart the new hard disk drive.
9 Test everything, to be sure that everything works properly. Go through everything from the top of the menu to the bottom of the menu. Try all accessories, try all applications. Ensure that all works right and that the applications work as they used to work, when it was on the old drive.
10 - Remember, you have a warranty on the new HDD, so be sure that you have tested everything to ensure that it all works properly, before you sign off on this new drive.
11 - Once you are certain that it all works correctly, you can then be sure that it is working properly and competely, because only you know if things are working correctly as they should be.
12 - Then you can sign off and you can be sure that things work properly.
13 - As carpenters say ... measure twice; cut once. You can only do this one time, so if you measure it more than one tim, you can be certain that you will get it done correctly and be happy that you did it right. from beginning to end.
Have fun. Don't be too serious about it, but do be careful, and get it right. Remember, get it right the first time, and you will be pleased with the results at the end.
Posted on Jun 22, 2009
How do you get to the CF-29 diognostic test
All Panasonic Toughbooks built after 2009 or 2010
have a built-in DIAGNOSTIC utility Built-In at the
BIOS Level. Simply press the F2 function key while
booting and go to the last TAB (Usually SAVE/EXIT).
You will find the diagnostic utility at the bottom
of the menu. This is true for the CF31 MK1+.
This is NOT true for the CF29 which was built
between 2004 and 2006. Instead I would use a
CD Boot Disk like HIREN Boot Disk which has some
great diagnostic utilities. I like both Hiren 10.0 + 15.1.
http://www.hirensbootcd.org/
Good Luck.
Regards,
Richard - Montreal Based
Panasonic Toughbook Authorized Dealer since 1989.
May 06, 2014 | Panasonic Toughbook CF-29 Notebook
Remove bios password for a panasonic toughbook cf-30k
  • Press "F2" on your keyboard when you see the Panasonic logo appear on the screen. You will immediately be prompted to enter your Panasonic Toughbook Cf-29 BIOS password. Type the word "Biostar" into the password prompt. This is your Panasonic Toughbook Cf-29 backdoor BIOS password. Press the "Enter" key to unlock your Panasonic Toughbook Cf-29 BIOS.
  • Mar 10, 2014 | Panasonic Toughbook CF-30K (CF-30K3PAQAM)...
    Cf-29 no operating system
    You will require the internal Panasonic Toughbook CF29 optical drive (DVD). The cost of such a drive (used) in should be $50 or less.
    You will also require a Windows 7 DVD.
    You may be able to download an ISO file and burn your own.
    Try this Microsoft Website:
    https://www.microsoft.com/en-ca/software-download/windows7
    You must use the 32-bit version, NOT the 64-bit version.
    Please remember to set the DVD as the first boot device in the BIOS of the CF29.
    That is it. Good Luck and Best Regards from:
    Richard, Montreal Based Panasonic Canada Authorized Toughbook Dealer since 1989.
    Jan 27, 2014 | Panasonic Toughbook 34 PC Notebook
    Get wifi to work on Panasonic Toughbook CF-29 PC Notebook
    if you don't have a card, you can always buy a pcmcia card if it has the appopriate slot. if not you can buy a usb adapter for it. make sure that you have the physical on/off switch set to on
    May 05, 2012 | Panasonic Toughbook CF-29 Notebook
    Gratis audio driver para panasinic CF-29 TOUGHBOOK
    Follow the link enter the details of your laptop download and install your drivers.
    Jan 31, 2012 | Panasonic Toughbook CF-29 Notebook
    When i turn the cf-29 on i get the panasonic boot screen then it goes blank
    Your boot loader is corrupted try reinstalling with the WINDOWS installer CD
    Or Reformat your operating system
    Thanks. Cheers!
    Apr 15, 2010 | Panasonic Toughbook 29 Touch (P/N...
    Won't power up on AC power
    does the indicator light , if present, turns on when you plug the ac adapter in the wall socket.
    if not , you might need new ac adapter.
    Nov 05, 2009 | Panasonic Toughbook 29 Touch (P/N...
    Panasonic toughbook cf-27 cd/rw drive
    www.Newegg.com is a great place to purchase this product. Nice laptop BTW...
    Armymason
    Feb 26, 2009 | Panasonic Toughbook 27 Notebook
    Panasonic Toughbook CF-29 Notebook Logo
    123 people viewed this question
    Top Panasonic Computers & Internet Experts
    micky dee
    Computer Repairing
    Computer Repairing
    Are you a Panasonic Computer and Internet Expert? Answer questions, earn points and help others
