Question about Hayward SAND FILTER, PRO SERIES
Not getting sufficient water flow
The motors starting, all intake lines are open but we aren't getting sufficient water flow. What could be the problem?
  • 198 Answers
Usually that would be caused by air getting into the lines and/or pump-check all gaskets and seals
Posted on May 07, 2010
No water flowing out my 40hp envenrude outboard water exaust port
Plossibly clogged intakes (grim in intakes) or thermostats not opening. I would suggest pulling the lower unit and then your thermostat housing and use a water hose to back-flush it out. Also check the thermostats in boiling water to make certain opening.
May 09, 2014 | Clymer Evinrude/johnson 2-40 Hp Outboards...
Error after short prime cycle
AIR LEAK IN SUCTION LINE. PUT A GARDEN HOSE WITH A RAG AROUND IT TO BACKFEED FROM INTAKE IN POOL. WITH PUMP "OFF" TO LOCATE BREECH IN LINE.
Apr 21, 2014 | Pentair IntelliFlo VF High Performance 3HP...
It wouldn't start and an error sound comes off after 10 seconds pressing START.
If there is no water intake or the inlet valve working then it can be faulty in the main control board. The possible fault that the machine does not start off the cycle is because there are errors due to feedback from the inputs. For the program to start up the main program controller must initiate the INLET/MOTOR/DRAIN pump/ valve to open up and allow each function to be driven starting from the flow of water into the drum as also the drain valve to open to exit the water at the point of the program cycle. If this does not happen then the voltage at the valve/motor/pump must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows though the inlet then the flow pressure should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the WATER LEVEL SENSOR - normally a pressure switch- must activate at the preset/chosen level to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut or this will be an error for starting the motor for rinse and wash.
Test a pressure switch: Click on : http://www.youtube.com/watch?v=HZZ2bDMspj8
Check this link to replace the inlet valve:
http://www.espares.co.uk/advice/washing-machines/a/7/1408/how-to-replace-the-inlet-valve-on-a-washer-dr.html
Feb 12, 2013 | LG WFT1071TP Top Load Washer
Flo code is on and pump won't start up
Flo = Improper flow or pressure switch malfunction or Flow switch malfunction (system specific).
Before you purchase a new pressure switch:
- Clean or replace your filter cartridge (if its older than 1 yr).
- Check that all slice/gate valves are up/open.
- Check water lines for blockages incl. suction cover & ensure sufficient water level in spa.
Jan 29, 2012 | Qca Spas Majestic Series Aruba Xl Hot Tub
Leaking at cold water intake
If your unit is leaking from the joint where the pipe actually meets the tank, the only solution is to remove the pipe, check the threads to make sure they aren't all beat up and scratched badly, then re-wrap with teflon tape clockwise while you're looking at the pipe's open end. Three wraps is usually sufficient,, then re-insert into the threads and tighten with a medium pipe wrench. Tighten until you can't turn the pipe any more.
Dec 18, 2011 | Rheem 40 GAL ELEC TALL Water Heater 6YR SC...
I pressed cancel & it still wont work! its flashing "H" & "F"
Press Cancel twice. Then check your water inlet. Are the valves open? Unplug the washer. Then close the valves and disconnect the water hoses. Check the filters in the hoses (if present) and at the washer inlets for objects clogging the filter. Make sure that the hoses aren't kinked when you reconnect them to the washer and the incoming water valves. Make sure that you have sufficient water flow coming into the washer. The pressure must be above 20 PSI . Replace the hoses. (If you use certain anti-flood hoses, they will seal and block water flow when they notice a pressure issue that could be from a water leak.)
Plug the washer back in, reselect your wash cycle and then press Hold to start. If the FH error persists, then you probably have a problem with the inlet valve or the pressure switch for the valve. Call for service if the washer is under warranty or you aren't sure that you can replace the valve. (See the parts list labeled Top and cabinet parts.)
The manual and parts list for the Duet GHW9150P washers are available from Whirlpool here: https://www.whirlpool.com/webapp/wcs/stores/servlet/OCManualsLiteratureSearchResultView?catalogId=10561&langId=-1&storeId=10211&krypto=5QgxQhneFlibuKNJvC4qU4ramPrjJ75r2vuMTp0sZ%2F5gVjei80pPz5Qc1hYJgPeg&ddkey=http:OCManualsLiteratureSearchResultView . There are several models so look for yours.
I hope this helps.
Aug 25, 2011 | Whirlpool Duet GHW9150P Front Load Washer
Siemens SE55T790 dishwasher does not work. We can hear apump or motor running but there is no water inside and the program does not advance. We have checked the water intake & filter which are both...
It is possible that the machine does not start off the cycle because there are errors or back feedback from the inputs. For the program to start up the main program controller must initiate the INLET valve to open up and allow water to flow into. If this does not happen then the voltage at the inlet valve must be checked or the fault relates to no voltage from the controller. This means the controller is a suspect.
If the water flows then the flow should be good, if not the inlet valve is bad or there is dirt in the filter. Also check the flow at the inlet of the water line. Once the water comes into the system the SENSOR must activate to give the signal to the program controller to switch on the motor. What is most important for the motor to start functioning is that the door switch must be ON when the door is shut .
Finally after the wash the drain valve will be activated.
Make sure that a fault in any of the cycle will relate to the specified action, so check the command from the program module and then the executing device be it the valve or motor or pump.
Jul 09, 2011 | Siemens 24 in. SE25T250 Free-Standing...
Turn on dishwasher hear noise solenoid clicks water valve works but no force of water to turn tines and no clean.
Sounds like you may have a bad solenoid valve. you can check this by opening line that feeds the valve to see if you have sufficient water flow. GET SOME TOWELS READY THIS MAY GET A LITTLE MESSY!
  1. turn off the water valve that feeds the dishwasher.
  2. remove the line to the dishwasher solenoid valve.
  3. slowly turn water back on that feeds the dishwasher.
  4. verify sufficient water pressure flows onto the towels.
Dec 30, 2010 | KitchenAid 24 in. KUDP02SR Built-in...
Cold water ok, no water flow from hot water lines.
Bypass valve incorrectly set
obstruction or dirty tank
plugged line - lime or other! does cold flow into tank ok?
Tank is split water going somewhere you can't see - this should be obvious.
There is not really anything to obstruct the flow normally so there
would have to be an obstruction somewhere. Lime, junk, garbage etc build up .
On my coach I have lots of pressure on the cold side so hot would have to have the same unless there is an obstruction into or out of the tank. If in the bypass position you have sufficient flow than the lines are ok and the problem or obstruction is in the tank itself. Drain the tank, leave the bottom plug out, open up the pressure relief valve. Turn on the water and see if you get a lot of water draining from the drain hole on the tank. There should be a lot of water coming out of the drain hole. If so that tells you that your getting sufficient flow into the hot water tank. If so your problem is the water getting out of the tank. Like a clogged return line or an obstruction from the water tank to the faucet. A dirty scale lined tank can do a number on tank water flow. Also check to see if the water is going somewhere else, your tank could be split and you just can't see where the water is going!
Dec 17, 2009 | RTO Atwood Water Heater - 6 Gal LP
Small coffee and coffee buttons flashing, hot water button on solid, water tank and priming butten on solid. I can open steam knob and let cold water run all day, but that's all that happens. What's wrong?
HI
Its your flow meter. If you have a restriction in the intake line the message will not go away. There is a flow meter inside the machine that measures water flow. If the flow meter does not spin when the pump is running, the computer thinks that the pump is not primed. Coffee grounds will get into the intake and restrict the flow meter. If you get a restriction in the water intake (below the water tank, on the machine) the pump may run and water comes out, but the flow meter does not create the jet of water to spin the turbine wheel to send impulses to the computer. You get the ventilate message.
You need to take the flow meter apart and clean it or replace it.
Nov 18, 2009 | Saeco Incanto Classic Espresso Machine
Hayward SAND FILTER, PRO SERIES Logo
113 people viewed this question
Top Hayward Pool & Spa Experts
Jay Finke
Jay Finke
Bill Jordan
john h
Are you a Hayward Pool and Spa Expert? Answer questions, earn points and help others
