Question about Magic Chef CGR3742 Gas Kitchen Range
Oven is slow to heat up to set temperature
My CGR3742 takes a long time for the oven to come up to temp setting.
  • Magic Chef Master
  • 43,501 Answers
The ignitor is not working right and is going bad....
have the repair man replace the ignitor, or DIY....
Check out this tip about your problem...
Oven not Working or Oven not Heating
http://www.fixya.com/support/r3663023-oven_not_working_or_oven_not_heating
Oven Problems Replacing the Igniter http://www.fixya.com/support/r4572625-oven_problems_replacing_igniter
heatman101
Posted on May 14, 2010
How do you turn it on and set temp
ELECTRIC RANGE USER INSTRUCTIONS - Whirlpool
www.whirlpool.com/digitalassets/.../Use%20...
Whirlpool Home AppliancesPress the number keypads to set a temperature other than 350°F (175°C) in 5° ...Timed Cooking allows the oven to be set to turn on at a certain time of day, ...
Oven Temperature Issue ' FAQ ' Sub-Zero and Wolf
www.subzero-wolf.com/.../oven-temperature-not-same-as-set-t...
Sub?ZeroOvens will heat up higher than the oven temperature set point and then turn off. ... If oven temperature is off on an R or GR Series Gas Range, ensure that the ...
Oct 29, 2015 | Kitchen Ranges
Why hasn't the oven reached the set temp when the buzzer sounds indicating desired temp has been reached?
What are you using to measure the temperature of the oven? If you using a typical round oven thermometer, the reason is that your thermometer response is slow. It takes about 20 minutes for those thermometers to reach and display the actual temperature, and your oven is probably reaching it's set temperature in about 10 minutes. You really need an electronic thermometer or at least one of those liquid thermometers which you can sometimes find at Ace Hardware or True Value Hardware stores.
If you need further help, reach me via phone at https://www.6ya.com/expert/ronald_e6b9572cebe3ad27
Apr 29, 2015 | Kenmore Kitchen Ranges
Temp shows 400 but oven is at 300
Is it continues to heat up then its working fine...if it continues to heat pass 400 then your have a thermostat problem and the oven is out of control. I do believe that the display is not an actual reading of the oven temperature, instead it is a reading of where the operator has set the temperature to . I have yet to see an oven with a actual reading temperature display.
Dec 01, 2013 | GE Profile JTP18 Electric Single Oven
It keeps displaying F4 or F2 and will turn the oven off. Help turkey dinner tonight! How do we solve this problem, do we reset it?
Sorry to read about your problem, I hope this helps you out.
f4 is the below and f2 is oven to hot
Oven temperature sensor open
Check oven temperature sensor, should be ~1100 ohms at room temperature. If too high or low, replace oven temperature sensor
I tried to help you. Please help me and Rate/Vote on my response. We take the time to answer your question. take the time to rate us.
Dec 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
Magic Chef CGR3742 Hi, I't has been pre heating, but took a very long time. Now it sometimes will heat up a little, but will not hold that temp. for long. I removed the bottom pan to see the burner and...
heatman101
Nov 25, 2010 | Magic Chef CGR3742 Gas Kitchen Range
The oven does not heat to the set temperature. It is usually much hotter
You can have the oven recalibrated by a professional OR you can purchase an oven thermometer and check the temperature yourself. Place the oven thermometer in the oven.Set the oven to a specific temperature. When it indicates it is at that temperature check the thermometer. Adjust your setting by that many degrees. For instance, if you set the temp at 350 and the oven thermometer shows 450, then reduce your temperature setting by 100 degrees each time you use the oven.
Nov 15, 2010 | Amana RanARG7302 Gas Kitchen Range
When set to bake eg: 350 degrees the audio alarm will indicate it's reached temp but the oven is 50- 75 degrees lower. Must wait another 15 min for it to reach the proper temp. Have tried to adjust the off...
If you are monitoring the oven temperature with an analog style thermometer you may actually be ok, but seeing the thermometers slow reaction time.
Some newer ovens actually do pre-heat beep prior to reaching temp in an effort to conserve eelectricity.
A good home test is to try your oven at several different temps to see if there is any variation in internal temperature. Try it one day on 300, the next at 375 and another day at 450. Give your analog style thermometer time to catch up (usually just about 15 min) and leave it on for a half an hour to see if the temp maintains.
Also Beware of aluminum foil AND THE NEW OVEN LINER MATS as they can alter oven performance bay absorbing and blocking the ovens natural heat radiation and convection air flow currents that happen in all ovens, not just convection models.
Another interesting fact is that older ovens used a thermostat in them that operated much like your thermometer and was very slow to react making the oven typically about 100 degrees hotter than where the customer set it. This was just a fact of life before the advent of electronic temperature management and became noticeable when people began trying to bake older "hand me down" recipes in the newer ovens with less than stellar results.
You can mimic the older oven performance by preheating the oven about a hundred degrees higher than called for and after it reaches temp, re-set it to the correct temperature and put the items in right away.
If you find your temperatures fluctuating ask your servicer to replace first the temp sensor and as a last resort the control board as this part is usually pretty expensive.
Good Luck with this!
Jun 14, 2010 | Ovens
Temperature control
sounds like a bad bake ignitor(uneven heat,long cook times, long preheat times, perhaps even gas smell while cooking)
Sep 29, 2008 | GE Profile Spectra JGBP90 Gas Kitchen...
Preheating
hummmm this sounds similar to what is happening to me. I am praying someone will have a solution, I don't want to have to explain to my daughter who is going to be 4 tomorrow, why I can't bake her cake.
May 12, 2008 | Ovens
Preheating
If your electric2_bing.gif oven is not heating then you probably have a bad heating element in your oven. This is not that hard to fix yourself...
Check out this tip that I wrote about the Oven not heating problem..
Oven Problems Electric2_bing.gif Oven is Heating Slowly or Poorly
http://www.fixya.com/support/r4511800-oven_problems_electric_oven_heating
heatman101
Jan 13, 2008 | GE Profile J2S968 Dual Fuel (Electric and...
Magic Chef CGR3742 Gas Kitchen Range Logo
367 people viewed this question
Top Magic Chef Kitchen Ranges Experts
Paul Carew
Sal De
Are you a Magic Chef Kitchen Range Expert? Answer questions, earn points and help others
