Question about D-Link DIR-615 Wireless Router
How do I disable my DIR-615 and make it un-secure to allow internet access on my Wii?
  • 4,281 Answers
For that Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Click on wireless settings disable wireless WEP Security .Then save settings and restart router.
Let me know if you need further assistance.
Thanks for using FixYa
Posted on May 06, 2010
SOURCE: how to install d link Dir 615 router
Port opening
Posted on Apr 22, 2009
  • 6 Answers
SOURCE: D-Link DIR-615 router
default username and password on the router should be
username: admin
password: *left blank*
Posted on Sep 22, 2009
Geekman
  • 32281 Answers
SOURCE: How can i put a password to my N router (DIR 615)?
Connect a LAN cable to the router and computer. Open your WEB Internet Explorer and your in the router's URL IP configuration address.
This will be 192.168.0.1 and the default Login = admin and the default password = (blank) just press Enter.
You can now change the default password.
Posted on Oct 21, 2009
govinda123
  • 2260 Answers
SOURCE: dlink dir-615 change nat from strict to open
you will need to change some settings on the router.
reduce the MTU. if the MTU settings on the router is 1500 then change 1365 also you will need to open the some ports on the router.
Click Here for more info
Posted on Jan 12, 2010
SOURCE: Hello, I forgot the Network security Key , how can
Ok. you cannot so much "Solve" it, as such, as you must simply re-set it up again. You must access the router via a browser, and login, now you simply set it all up again, OR leave as is, except for the "Key"and when you get to the security tab, to do the WEP?WAP key, when the "Key" this is generated, I copy paste into a notepad document, & save. When you setup the security. do it all save and exit. Now when you try to access the WiFi network, from a "Client" you will be asked for that key, simply copy paste it from the document.
Also ensure DHCP is set to OFF and disabled on ALL client computers. START>>RUN>>services.msc enter, When services comes up, scroll down to DHCP and set to OFF & Disable. Reboot.
Posted on Mar 13, 2010
D-Link DIR-615 mobile phone wifi internet connection problems? connect but no internet
What wireless modes are you using? Under Setup/Wireless/Manual.
Try single mode G or mixed G and N?
Channel Width set for Auto 20/40Mhz or try 20Mhz only.
Try setting a manual channel to a open or unused channel.
What security mode are you using? Preferred security is WPA-Personal. WPA2/AES Only. Some WiFi adapters don't support AES, so you might want to try TPIK only or Auto.
What wireless devices do you have connected?
Any cordless house phones?
Any other WiFi routers in the area? Use InSSIDer to find out.
Turn off Short GI, WLAN Partition and Extra Wireless Protection if you have it. Under Advanced/Advanced Wireless.
Sep 17, 2014 | Computers & Internet
Reset my dlink dir 615 router and now internet light stays flashing orange
Do you have the Internet connected to the Internet port in the back of the DLINK? You will have to configure the DLINK for internet access. Open a web browser to your DLINK and check on the configuration under internet-setup. Select the type of internet connection you have i.e. DHCP, PPPoE, Static, etc. Once that is set up, you should have access to the internet like before.
Feb 13, 2013 | D-Link DIR-615 Wireless Router
Dir 615 Instructions
You can access the router through web interface and configure it.
The default username is admin and leave the the password field blank - Don't type anything - and Click Login). All you have to do is connect the router to the DSL Modem through LAN cable (or wirelessly) and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
1. Change the SSID (Name) of the router
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and leave the the password field blank - Don't type anything)
(The above step would prevent unauthorized access to your router)
Next step is to secure it:
1.On the left-hand side, under Setup, click "Wireless Settings" 2.Under "Security Options", select your desired encryption method (preferably WPA2-PSK)
3.Choose a Network Key - it can be anything, as long as it's 8-63 characters in length
4. Click Apply
Now your router and your connection would become secure and the user has to provide the network key to access the internet.
You may refer to Product Manual (Page47 onwards for security settings)
Feel free to contact me for further assistance
Hope it helps! Good Luck! Thanks for using Fixya!
CreativeTECH
Oct 20, 2011 | D-Link DIR-615 Router
I have a DLink DIR 615 wireless router from my cable/internet provider. It works (mostly), but setting up and securing a wireless network is nearly impossible. How can I create one, secure it, and can I...
I am not sure what you are missing, you should be able to do what you desire, with the unit you specify.
Here is how:
Wireless Router settings:
It is usually easiest to run the install wizard, which you can get from the manufacturers' website, usually for free, but be sure to be ready to set the items listed below:
To get access, start your browser, and put 192.168.1.1 or 192.168.0.1, or other address for your unit, into the ADDRESS bar (not search box) of your Internet Browser. Every unit has unique access login and passwords, some are admin with no password, some are admin and admin...seek access information from the website of the manufacturer of your unit. Look under support, downloads, drivers or similar sounding areas.
Things to set:
(Note: Routers are intended to be set by geeks. You have to SAVE EVERY page before you leave it, or the changes will be lost. A geek knows this (apparently). The router gives no protest...just dumps your changes. SAVE OFTEN.)
1. Login password (RECORD THIS!!). Consider taping to bottom of the router. Physical access is typically NOT the security issue.
2. Set a recognizable system ID (descriptive name is easier to find when you need to connect wirelessly).
3. Invoke wireless security of at least WEP.
a. Assign your own access code, 10 digit home or cell #. Consider taping this information to bottom of the router. (Physical access is usually not the security issue.)
4. Check that your router is set to broadcast its' presence.
5. Change the channel of the wireless to 11, and avoid conflict with landline cordless phones. (Big issue, even the neighbors can interrupt).
There are more secure settings available, all the way down to only allowing certain MAC addresses to have access. A MAC address is a digit unique to each and every network card. Like a fingerprint. Most users do not set mac address limits.
May 31, 2011 | D-Link DIR-615 Wireless Router
Trying to connect my wii console but i need password for d-link router
The default SSID is DLINK. If you want to set your own password type 192.168.0.1 into your computer's internet browser address bar. The username is ADMIN, the password is left blank. You can set the access password to whatever you'd like
Feb 20, 2011 | D-Link DIR-615 Wireless Router
Need to secure router access
Here is a direct website to show you how to secure your router it is a manual for the router simply download it and view, it is under product manual. http://www.dlink.com/products/?tab=3&pid=DIR-615&rev=DIR-615
Jan 13, 2011 | D-Link DIR-615 Wireless Router
Dir 615 installation cd
In case you dont have the installation, you can access the router through web interface and configure it. All you have to do is connect the router to the DSL Modem through LAN cable and make configure the router according to the needs and ISP. To secure the connection follow the following steps: -
First you have to access the router through web browser (Internet Explorer) by typing the IP address of your router in the address bar, which is usually 192.168.1.1 or 192.168.0.1 (written at the back of router) and lookup for the options to do the following: -
2. Change the default administrative user name and password (unless you've configured otherwise, the default username is admin and the password password.)
4. Click Apply
CreativeTECH
Jan 03, 2011 | D-Link DIR-615 Wireless Router
How do I make the DIR-615 secure
To secure youe wireless network from unauthorized access, please click on this link and follow my instructions :-
http://www.fixya.com/support/r3559128-wireless_router_security
Nov 28, 2010 | D-Link DIR-615 Wireless Router
I have a business requirenment that when user open the web browser it should get routed to a specific web site and then do a registration and after registrtaion he is free to use the internet and surf net....
If the user is outside your business you don,t need to it.If the user is on your network you can allow or restrict the access to the internet.The option you want to can be made in your web server by the webmaster.I think your bis is an internet cafe.So you need to make a page to do this kind of interface.If you run an internet network for your clients you need to let them to pay for it.
You can use a third party software to restrict user to access internet.
With iNet Protector you can restrict access to the Web and password protect Internet connection. You can restrict internet access at specified times or on demand. You can disable connection completely or limit Internet to work with allowed programs and services only. In order to fully enable Internet access, user defined password must be entered. You can easily schedule Internet availability. Timer allows you to disable Internet connection after specified amount of time. Very useful for parents and business owners.
Key features:
* Restrict Internet access at specified times
* Password protect Internet connection
* Enable and disable Internet on demand
* Allow Internet access for a specified amount of time
* Allow only specified services or programs such as e-mail
* For Parents - Protect your kids from using Internet too much
* For Businesses - Keep employees from online entertainment at work
Internet Access Controller is a leading software tool for controlling, blocking web sites and restricting internet & network access.Internet Access Controller can restrict internet access at specified times or on demand. You can password protect an internet connection. Protect your computer from viruses, trojans, worms that can be contracted from malicious websites or programs. Great for parental control or to prevent employess from inappropriate internet usage. You can block, limit or allow which programs and services have access to the internet. The timer feature allows you to disable the internet connection after a specified amount of time. IAC gives you complete control over your computer's network connection.
Key features and benefits
- Restrict internet and network access automatically at specified times
- Password protect internet and network connection
- Enable and disable internet on demand
- Allow internet access for a specified amount of time
- Allow only specified services or programs such as e-mail
- Allow only specified web sites
- Block specific web sites and allow the rest
- Set daily internet usage limits applied to all users or only specific users
- For Parents - Protect your children from the dangers of the web and limit online usage
- For Businesses - Keep employees from online abuse at work
Parents: Protect your children
- Limit time spent online
- Automatically turn off internet at night or at any other inappropriate time
- Block harmful programs, such as chat and online games
- Protect your computer from malicious websites or programs.
Businesses: Increase employee production at work
- Increase productivity by limiting temptation for inapporpriate web surfing.
- Only allow websites needed for daily tasks.
- Block unwanted websites or games.
- Only allow access to programs such as email, file sharing and business related programs.
If you use NTFS, you can use the file system's built-in permissions to restrict access to the Internet Options or Internet Tools Control Panel applet by performing the following steps:
  1. Start Windows Explorer
  2. Navigate to \%systemroot%\system32 (e.g., c:\windows\system32).
  3. Right-click inetcpl.cpl and select Properties from the context menu.
  4. Select the Security tab.
  5. Adjust the user and group permissions as appropriate, and ensure that the SYSTEM group has Full Control.
Nov 11, 2010 | D-Link DIR-615 Wireless Router
Hello, I forgot the Network security Key , how can I solve this problem?Product Model d-link dir-615 Wireless Router
Mar 13, 2010 | D-Link DIR-615 Wireless Router
D-Link DIR-615 Wireless Router Logo
131 people viewed this question
Top D-Link Computers & Internet Experts
Prashant M
Prashant M
Are you a D-Link Computer and Internet Expert? Answer questions, earn points and help others
