Question about Mitsubishi WD-52525 52" Rear Projection HDTV
Wd 62525 honeycomb pictues
What can i do to fix my dlp tv? it has a honeycomb like picture, which one is the DM BOARD?
  • Mitsubishi Master
  • 8,617 Answers
The DM board wont cause that symptom. The DM only directs power that is recieved from the PWB to the ballast fans and etc. That sounds like a problem with the FMT. capacitors 1000uf @16volts numbers C8F21, C8F22, C8F19, and C8F27. those will cause distortions in the video on the V26 chassis. Let me know if you need more info
Posted on Mar 27, 2008
SOURCE:
Flashing green light
you can buy a DM or Power kits from tv repair. i changed the capacitors on both of mine but it has not fixed the problem. Same WD-62525 it may work for yours.
Dec 27, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Green blinking timer light on my WD 62525 tv
That symptom is almost always caused by bad capacitors that are known to fail through ou the five circuits boards within the chassis. Usually the DM board and The Power Board caps fail which can cause the non stop blinking timer led. You can get the V26 Chassis DM / Power repair kit from www.tvrepairworld.com which has the caps with repair instructions that will often repair that issue.
Oct 04, 2011 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi DLP WD62725 TV after powering down the timer light say blinking till unplug it then reset it to turn back on can any one help me
Good Day,
More than likey you have bad caps on DM Board.
It willcost about $450 to repair or you can do it yourself,.
On the DM PCB (part # 934C116002) check C81A2, C81A3, C81B3 and C81B4 (1000 UFD, 16V, 105C), if any are bad, replace all of them with part # 181P734030 (680 uFD, 16V,
The DM PCB is on the left hand side of the TV when you take off the back cover.
Good Luck, BIG IRISH,.
Dec 15, 2009 | Mitsubishi WD-62525 62" Rear Projection...
5 year old mitsubishi wd-62525 with blinking timer light. This site says there aren't replacement boards available for it any more. Also to send it to a technician for repair. One suggestion was that it...
The WS62525 doesnt have an inverter board. The blinking led is usually caused by failed capacitors on the DM board. You can get the V26 Chassis dlp DM repair kit at the following link which contains the capacitors and the CD with detailed instructions. www.tvrepairworld.com
Aug 29, 2009 | Mitsubishi WD-62525 62" Rear Projection...
I noticed that there was a green blinking light on the front pannel of my WD-62525 TV. The TV would not power up. The cable sound was OK..I disconnected the power Cord for the TV from the wall. Waited 10...
The DM pwb is about 300.00 but it sounds like the caps have failed in the DM which is a 35.00 kit which includes the caps and detailed instructions. Its called the V26 DLP DM repair kit. You can get it at www.tvrepairworld.com
Aug 03, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Getting error code 12 on mitsu wd 62525 dlp tv. any help would be great.
12 means no error detected. What are the symptoms of the set? If its the blinking led thats the DM caps which have failed.
Jun 16, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Greem led timer light is flashing and the tv wont turn on what do i do ?
you need to replace the capacitors on the DM power board. You can get The V26 DLP DM repair kit at the following link which has the caps and full instructions with pictures.
http://servicemanuals.vstore.ca/
Apr 08, 2009 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi tv
ok.
#1. replaced capacitors on power board. DM board FMT board .
# 2 on power board you need to chek caps. 3300mf x 35 v.QTY 2.
# 3 12 capacitor 1000mf x 16 v.
If caps 1000mf x 16 v . looked good. replaced anyway......
Sep 14, 2008 | Mitsubishi WD-62525 62" Rear Projection...
Mitsubishi Projection TV Power Supply Board assistance - Model # WD 62525
Mr.Marxxx you need to let one of your friends fix it for a small fee.Just like everyone else does.
Jul 28, 2008 | Televison & Video
Mitsubishi WD-52525 52" Rear Projection HDTV Logo
148 people viewed this question
Top Mitsubishi Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Mitsubishi Televison and Video Expert? Answer questions, earn points and help others
