Question about Dell AS501 SoundBar 2 Speakers
Where does round plug go in connecting?
I have the wire to the computer plugged in but cannot find where to plug in the round plug.
  • 416 Answers
The round connected, i believe is for the power adaptor
Posted on May 06, 2010
  • Firey5 Jul 13, 2011
    It plugs into the monitor, enabling the monitor to supply power to the speakers. Look for a small round port near the main power cord outlet on the monitor. Ironically, not all Dell monitors have this ac port for the speakers. In fact, some models, notably the e176FPc, don't have this port, yet they contain the slots for mounting the speakers. So don't worry, you're not insane, just some hasty manufacturing.
How do i hookup the what i think is the power cord to the computer its a round plug in
If it's a power cord, it doesn't plug into the computer; one end goes in the wall, the other into the speakers.
For most speaker pairs, there are 3 wires:
1) The wire that connects the speakers to each other. That's often fused into the back of the left speaker, and gets plugged into the right speaker (it's usually pretty well marked where to plug it in).
2) The wire that connects the right speaker to the computer. Usually it's pretty well marked where to plug this into the speaker. On the computer, that wire will fit into 2 ports. Usually those ports are marked with microphone and headphone icons. You want the headphone jack. If they aren't marked, try them both or check your manual.
3) The power cord. One end of that will plug into an electric outlet on the wall (or into an extension cord or power strip). The other end will plug into the right speaker; it should only fit into one hole (which will probably be marked with "12V" or "0.5A" or something like that).
It would help if you told us what kind of speakers you have, and what kind of wires you're seeing.
Mar 02, 2015 | Audio Players & Recorders
Where does the green wire connect from the power cord on a dewalt dw 236 drill
The green wire is always the ground pin (ground connection)
Hope this helps.
Feb 28, 2015 | Dewalt Dw236 1/2" Heavy Duty Vsr Drill...
How to wire a plug
In USA, Either the male or female plug connector would be wired the same. Black is hot wire and would connect to the BRASS colored round head screw ( Smallest flat prong or slot ). White is the neutral wire and would connect to the SILVER colored round head screw ( Largest flat prong or slot ). Green is the ground wire and would connect to the GREEN screw ( ONLY HEX shaped screw ). 1) FOR YOUR LIFE SAFETY, ALWAYS USE 3-WIIRE PLUGS WHEN REPAIRING 3-WIRE EXTENSION CORDS! 2) Check the male plug connector. It should have two flat and one rounded prong. The rounded prong is the ground wire connection. If the ground prong is missing, replace the plug. 3) Inspect the outer cover for damage. 4) Do not use cords with damaged outer covers. Taping over the damage is not an adequate repair, for safety, replace the cord.
Apr 04, 2014 | Woods Industries 12/3X100FT Yellow Jacket...
How do I connect this keyboard to the computer
Keyboards connect several ways. Older systems use a PS/2 connector (round) that plugs into the purple/gray jack on the back of the computer. The mouse plugs into the green jack next to it.
If you have a USB keyboard, it plugs into any USB slot.
PS/2 connections must be made with the computer off. USB connections work any time. If one slot doesn't work, try another.
If the keyboard doesn't work, try another.
Nov 17, 2011 | Unitech K2724U-B Keyboard PC Desktop
Please help western australia.britax trailer lights not connected properly.this is how currently connected.left hand trailer light top pin yellow,side pin green,bottom left pin brown,bottom right pin...
plug wiring is in
the following web site
ww.narva.com.au
the site is very specific for 7 pin , 6 pin and rectangular to round 7 pin
the small tag that you have to use to put the plugs together is identified at the top oh the round plugs
you can get the site by googling and typing in ---trailer plug wiring australia
Apr 02, 2017 | GPS
My wireless keyboard and mouse has a computer connection of a USB plug and another plug that is round and green with multi pins in it. My new computer does not have a recepticle for the multi pin plug....
The round plug is for older computers that don't have USB. You don't need to concern yourself with it if you have USB. Just use the USB connection and everything will be fine.
Mar 06, 2011 | Logitech Wireless Access Duo Optical...
What color wire do you connect to the plug in for the Kenmore range model C970-44073800? We purchased a four prong plug in and it states on it to refer to the appliance to wire it correctly. The only wire...
White is your neutral. Red and Black are L1 and L2. The 4th wire is the cabinet round. The round post is the ground, the one directly above it is neutral(White) the other 2 don't matter which one is Black or Red. You can verify the connections with a meter, Red to Black - 240VAC, White to Red or Black -120VAC White to Ground -0VAC
Eric
Mar 10, 2010 | Kitchen Ranges
How do i hookup a new computer?
Most of the chords fit in only one place.
The power cord, big black one can only go in one place.
The keyboard will be either a round ps2 plug or a usb plug. If it is round plug it into the purple round matching socket close to the top of the tower, if usb then plug it anywhere it fits.
Same with the mouse but that goes in the green socket if its a round ps2 type.
the screen goes in the matching plug. if there is more than one plug for the screen then it goes in the bottom most one.
speakers go in the green speaker connection.
If you have a broadband connection it goes in the network port nmost likely, the only one it will fit in.
Jun 18, 2009 | HP Compaq dc7100 PC Desktop
Need to replace a/c belt and also the spark plugs
plugs located on the cylinder head look for 4 large round wires on front side of engine.plugs are connect to wires. plug gaps is .040 for the 2.5 engine .041 for the 2.0 engine.
Apr 08, 2009 | 2003 Chevrolet Tracker
Connecting speakers to compacq computer
its a green round plug on the back of the pc
May 02, 2008 | Audio Players & Recorders
Dell AS501 SoundBar 2 Speakers Logo
362 people viewed this question
Top Dell Audio Players & Recorders Experts
Greg Cann
Greg Cann
Jax Planet
Jax Planet
Are you a Dell Audio Player and Recorder Expert? Answer questions, earn points and help others
