Question about Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler . top fan is not working, the cooler is not cooling to set temperature. removed the fan, checked the fan, it works OK. no output from the board. Question: is the board bad or possible associated sensor. also it ices up which is probably part of the fan issue.
  • vern60 May 06, 2010
    thanks!
    there are two relays SPST on the PCB .do you know which one. or should i just replace the logic board?
    there is a bad zener diode. both relays are fine. once i replace the diode if not the culprit then i will replace the board!
    thanks you have been very helpful...
  • 6,784 Answers
HI. This will be a simple fix here. The culprit will be the main PCB. There is a fan control relay on that board that has failed. The necessary actions are to replace the damaged board, asap. Once the MAIN PCB has been replaced, the unit will return to its normal functioning properties.
Posted on May 06, 2010
  • Michael Masters
    Michael Masters May 06, 2010
    The replacement of the entire PCB or Logic board,will be the better solution, in my estimation. It could be a stealth issue that may have caused the relay to fail. This could be extensive, and may have cascaded throughout the circuitry of the board.
    I would recommend to replace the entire PCB(Logic board)
  • Michael Masters
    Happy to assist:)
    Have a great day..
Fans stopped working
go to sears parts direct and enter your DWC283BLS you will have the plan and number parts you need
Mar 15, 2014 | Danby DWC283BLS Wine Cooler
Wine cooler frost buildup
Some dual temperature wine coolers build up frost in the rear and top of the main compartment. Check the defrost timer, located either inside the main compartment near the light, or outside on the back of the wine cooler near the compressor. Look in the owner's manual for the correct settings for the defrost timer and adjust yours as needed. Make sure that you have the wine cooler in a spot where the outside temperature remains at or near room temperature to reduce frost buildup.
Aug 11, 2012 | Danby DWC283BLS Wine Cooler
We have a danby dwc283bls wine cooler that no longer cools, and the compressor gets warm (above normal) does it need to be recharged
that's always a possibility but not always the case. The thermostat may not be cycling correctly or set wrong. The condenser could be dirty or if there is a fan, it may not be running. Freeze ups can also cause an "Out of temp." condition. Check it out.
Apr 15, 2010 | Danby DWC283BLS Wine Cooler
Top evaporator fan not working and compressor hot , not cooling below 79 degrees
the top fan is not suppose to run all thetime only when its too cold and the heater kicks then the top fan will come on,you probley have a leak in the system
Nov 10, 2009 | Danby DWC283BLS Wine Cooler
How to reset the temperature on the danby silhouette wine refrigerator
This happened to me, I found that the cooler would not go below 70 degrees because the cooler had lost its coolant or wouldn't work. I do not know, but as it was under warranty, an appliance repairman came and said that it was worth fixing, so it was replaced with in a week. Normally you would just hole the button in until the desired temperature is selected. Once released the cooler would attempt to set this temperature. If it is not, then I suspect it too is broken. Good luck.
Jun 03, 2008 | Danby DWC283BLS Wine Cooler
Non stop compressor?
these units have a condensor cooling fan in the rear it appears that yours may be seized up.
Regards
Advisor
Nov 10, 2007 | Danby DWC283BLS Wine Cooler
Danby DWC283BLS Wine Cooler Logo
529 people viewed this question
Top Danby Furniture Experts
Charles T Nevin
Charles T Nevin
Dennis Boxerman
jdthefixer
Are you a Danby Furniture Expert? Answer questions, earn points and help others
