Question about Traulsen 46 cu. ft. Commercial Freezer G22012
How many oz of freon does it need
How many oz of R-12 freon does it need
  • 523 Answers
It should be on the tag if not mabey 6 to 9 oz
Posted on May 06, 2010
I need help with a Delfield m# se-c5-9a, s#0807150000495. I think I have a restriction.but not sure. . I recovered the refrigerant and weighed in the 10 oz it calls for. Now my psi is 6.6 / 150.
If you recovered all the refrigerant how can you have a psi reading? Should be zero, yes? If unit is a refrigerator, proper freon levels are very critical for operation - no leeway as in auto AC's. Need to use accurate scale after using a vacuum pump to purge system and put in exact amount. Too much or too little is no good - have to be spot on.
Aug 28, 2017 | Delfield Freezers
How to refill R134 Freon
you have first put in a line tap. If the freezer system has been open it must be put in vac. to get moisture out. Then with interior coil exposed put in a few oz and start compressor. with compressor running add while watching interior coil/ you add slow til coil frosts to 3/4 then your done
Oct 26, 2013 | Amana 19.7 cu. ft. / 558 liter Upright...
Frost on the evaporator
watch this video I made. this is subzero with low level of freon (almost out). same situation on all refrigerators and freezers. you can see ice at the begging of evaporator. if there would be a little more freon evaporator might of frost up at the top might frost half of evap other half would be not even cold.
Jan 28, 2012 | Frigidaire 14.1 cu. ft. Upright Freezer...
The bottom shelf/coil does not seem to be working. The food at the back and bottom was molded and mushy. The top coil sits on the ceiling of the box, the second coil in the middle was coated with ice, and...
This is clearly a refrigeration problem:
this freezer uses very little freon like 9 oz. or so. if it leaked out even 2 or 3 oz. it is enough to affect performance. that is why it is not freezer like it did brand new. the leaks are hard to find. a refrigerator guy would charge you like $40 (if you can find a guy) to about $120 just to put a couple of oz. back into the freezer. but more is involved.
even if he did put the freon back in if he doesnt find the leak it will leak out and eventually go back to like it is now.. you can pay that not knowing how long it will last or just buy a new one (Samsclub for $150 or so) and get a extended warranty for $14.99 (i did)
rule of thumb: if you paid alot ($800 to $2000) for a appliance then might as well fix it (get the extended warranty if it is reasonable) dont pay $300 for a warranty you probably will never use.
hope this helps
Mar 16, 2010 | Haier 4.6 cu. ft. / 130 liter Upright...
Freezer temperature does not get below 10 degrees
this is something you can do now. Check this 1st:
make sure that the air vents are not blocked and that you didnt overload the freezer with food
there can be other things that will not bring the temp. below 10 (that temp. is not too bad as long as it doesnt spoil the food)
here are the possiblities:
t'stat is set too low
t'stat is not responding to zero degrees (all that means is it is shuting off the compressor too soon to reach zero)
dirty condenser
r-134a freon is a tad low (only takes like 9 oz. if lose 1 or 2 that is enough to affect performance)
the freon is the last thing to check cuase you have to call someone to do that for you...
Well hope this was helpful... check the temp often watch to see if it gets above 20 degrees cause that will spoil you food..
Mar 11, 2010 | Freezers
I replaced compressor for a hussman refrig and its hums loud
God day,
Some thoughts.
1. Are the evap fan motors running, and at full speed. That would give you abnormally low suction pressure.
2. Cap tube sized too small. or partial restriction in the dryer cap tube/dryer when brazing in the lines.
3. Low ambient. What's the temp the machine is running in.
4. Over sized compressor.
5. Moisture. God, 134A is touchy on that one.
6. Was original cap tube soldered to the suction line to create a heat exchanger. Needed on many apps. Definately would cause flash back on start up.
7. Superheat a little low, should be 12 to 15 degrees.
Jan 31, 2010 | Hussmann Freezer Gelato Pan Rack (For 12...
Have an old deep freeze that need to get rid of but it is to heavy to lift out of basement. want to take apart but freon lines are in the way...what can i do?
dont cut the freon lines inside your hause, it stinks!
all you can do it take off the door and any other bits inside it, its still going to be darn heavy, find a trust worth strong guy give him a drink to move it for you
Oct 23, 2009 | Amana 19.7 cu. ft. / 558 liter Upright...
I have a hotpoint deep freezer and it needs freeon. How and where do i put it.
First you need to know what kind of refrigerant it needs , and the amount of it in weight (oz,lb, gm ) If needs freon means there's a leak because all the refrigerations system are seal , so the leak has to be fixed and then recharged the unit using your manometers to check low and high pressures while you charging the system through the low pressure service valve (remember after fixed the leak to vacum the system and replace the dryer).
Aug 09, 2009 | Freezers
I have just bought an old kenmore freezer
could be freon to plugged freon lines probably not worth the cost of a service call and if it's that old it uses r-12 freon very expensive .Tom
Jun 15, 2009 | Kenmore 12.8 cu. ft. / 362 liter Chest...
Food thawing in freezer
You may have a small leak in the evaporator. You could try to get a replacement freon with stop leak from the automotive store and give it a shot. If it is a R12 unit then it is too old to repair. But it is worth the gamble to shoot it with freeze 12 or an equivilent before you condemn it.
Apr 10, 2009 | Freezers
Traulsen 46 cu. ft. Commercial Freezer G22012 Logo
67 people viewed this question
Top Traulsen Freezers Experts
Dennis Boxerman
Craig Butler
Craig Butler
Charles T Nevin
Charles T Nevin
Are you a Traulsen Freezer Expert? Answer questions, earn points and help others
