Question about Epson Stylus Photo R320 InkJet Printer
Only prints 4x6
I have a epson r320 printer, for some reason it will only print out 4x6 prints even though it is set for 8x10, how can this be changed? do i have to download newer driver software?
Check the printers console settings for correct page type and size.
Posted on Apr 01, 2008
6ya staff
SOURCE:
Print set up in the program
You do not specify what Epson Printer you are using. I have an Epson WorkStation. The Document Format in the Principal (Main) tab of the printer parameters lists among other format, a personalized (custom) format where you can choose the dimensions in mm or inches.
Nov 22, 2013 | Arts & Letters Arts and Letters Express
I need to change my dpi to 96 but don't know how.
DPI (Dots Per Inch) is an output specification, used when printing photos. As such, it has no meaning to the camera when taking photos. You can make 4x6 and 8x10 prints of the same photo and they'll have different DPI settings even though they're exactly the same photo.
The camera provides no means for setting arbitrary DPI settings. You set it when making a print. In addition, many photo editing program will give you a means of setting the DPI value without having to print.
Aug 04, 2013 | Casio Exilim EX-S12 Digital Camera
When I insert the 4x6 paper portrait it won't advance it to print.
You are probably using a glossy paper or photo paper 230gsm or above, some printers are having a hard time feeding with those kind of papers, try using lower than 230 gsm.
Jan 11, 2010 | Epson Stylus Photo R320 InkJet Printer
The color on my photo is blue on Epson printer R320
This is a common issue when printing using windows software, especially XP since SP2, my advice is always use the Epson software to print. Hope this helps
May 27, 2009 | Epson R320 CD / DVD Printer
Printing 4x6 photos on photo paper
Sorry but your question seems to be unclear.
Here are the solutions that I see:
- try fixing the orientation of your paper on the printer:
-- go to printer "properties" then select "paper" then set it to
landscape or portrait. You might just have to cut the extra
papers
- try changing the paper size on the printer "properties" if it has
no 4x6 then choose "custom size"
Jan 19, 2009 | Samsung CLP 300 Laser Printer
Epson Stylus Photo R320 - How to print to inside hole of DVD
In Epson Print CD program go to File ->Inner/Outer Diameter Settings. Set the inner diameter to the size you want.
Nov 22, 2008 | Epson Stylus Photo R320 InkJet Printer
Removal of border on bottom and right side of 8X10 print of color slide.
well this could be caused by a couple of things that i know about.
1: there is a line of dirton the drum, which may need to be cleaned to clear it.
2: there is a shadow set up when it prints now.
May 30, 2008 | Epson RX620 All-In-One InkJet Photo...
Stylus Photo R320 "printer driver dealing with CD printing...
I had the same problem and was able to get my EPSON Stylus Photo R220 to print a CD using the following procedure. This should work for other Epson Photo printers as well.
1.     Open EPSON Print CD
2.     When CD is ready for printing do the following:
3.     Select Print from the File menu
4.     When “The EPSON printer driver dealing with CD printing is not installed” is displayed – click OK and select Manual Print
5.     Set Paper Size to A4 and click OK
6.     In Layout select Print Settings
7.     In Media Type select CD/DVD
8.     Then press Print
Th
May 24, 2008 | Epson Stylus Photo R320 InkJet Printer
Epson R320 prints REALLY SLOW!
That printer is known for being slow. If you believed a salesperson, they may have not done research either. But the printer is known for acceptable output for a really good price. Heres a review:
http://www.compukiss.com/populartopics/photoprintinghtm/review409.htm
Apr 08, 2008 | Epson Stylus Photo R320 InkJet Printer
Printing
seems that y´all experiencing various paper feeding issues
check first for recommended paper type
that printer should handle 4x6´s up to 8.5x11´s
and if it can´t feed a particular size - hardware issue & check your warranty status with the manufacturer
Dec 24, 2007 | Epson Stylus Photo R320 InkJet Printer
Epson Stylus Photo R320 InkJet Printer Logo
149 people viewed this question
Top Epson Office Equipment & Supplies Experts
Inky Fingers
Inky Fingers
Clive
Clive
Alun Cox
Are you an Epson Office Equipment and Supply Expert? Answer questions, earn points and help others
