Question about Cameras
I have kodak easy Share C330 Digital camera that brings up the code error 14 wen it is powered on and the lens not extending outwards as it should. If it do extend it would just extend a small portion. What is the problem?
    Brigadier General:
  • 7,191 Answers
Please elaborate your problem providing us with more details and whether the camera was dropped accidentally.
Thanks for using FixYa.
Posted on May 14, 2010
I Dropped my camera model c330 and the lens will not return. I get lens error codes 22 and 12 and the camera will shut down.
Lens errors are fairly common. Usually it's sand or grit interfering with the lens extension mechanism. Or the camera's been dropped with the lens extended. Or the camera has been powered on, but the lens had been blocked preventing its extension. Or the battery ran down with the lens extended ... Unfortunately, many cameras that fall prey to this can only be corrected by professional repair. But, here are some things that you can do that may correct it. They only seem to work for less than 40% of the lens errors, but if the camera is out of warranty, they're worth a try.
Jan 02, 2011 | Kodak EasyShare C330 Digital Camera
My kodak c330 turns on thens says lens error 12, and the lens door will not open. what does this mean and how do i fix it?
Dec 24, 2010 | Kodak EasyShare C330 Digital Camera
Error45 Kodak easy share Ls743 LENS will not retract
Oct 17, 2010 | Kodak EasyShare LS743 Digital Camera
Need a operating manual for koday easy share C330 camera
go to www.kodak.com/go/manuals
look for the C330 Camera and click on extended users guide "PDF"
when it is opened
you can save it on your computer
by going up to file > save as
and select where you want the pdf saved....
Sep 23, 2009 | Kodak EasyShare C330 Digital Camera
The screen keeps saying lens error 14 then its says lens error 22
pls tap the bottom of camera and see if it works i mean tap hard it might come out or not it is stuck with dust and sand or something like that or the GEAR might be broken then i will suggest buy a new one dont waste time in replacements
consider FUJIFILM.com they are good in cameras
Pls rate me WELL !
Regards
Zohail
May 28, 2009 | Kodak EasyShare C330 Digital Camera
Kodak C330 [lens error 14]
Hi Jesse, thanks for coming to FixYa.
The problem your having is that sand and/or dirt gets in the lens mechanism of the camera. When the little cog inside gets sand in it, it prevents it from moving. It is what causes 95 percent of all lens errors. The other 5 are when the retaining pins get misaligned and don't go back in the holes. Mis aligned pins happen alot of times when you drop it with the lens extended, so let's go with the easy one first.
Take an air compressor (or borrow a friends) and put the nozzle up to the space in between the lens and and the camera. Blow it out real good. It may take a couple of tries, but it should free it up.
Let me know if that helped, and feel free to rate my answer.
Rob
Mar 04, 2009 | Kodak EasyShare C330 Digital Camera
Kodak Easy Share C330 lens error 14 and lens error 22
This is probably THE most common failure among digital cameras. There's a halfway chance of fixing it yourself, described here: http://camerarepair.blogspot.com/2007/12/fixing-lens-error-on-digital-camera.html
Oct 08, 2008 | Kodak EasyShare C743 Digital Camera
TECHNICAL SUPPORT AND ADVICE FOR MY KODAK EASYSHARE C33O
Bring your camera to the nearest service center. maybe program errors on it.
Dec 26, 2007 | Kodak EasyShare C330 Digital Camera
Lens won't come out,lens error 14,kodak c330
same thing happened on my camera. think it got dropped. lens only comes out part way. pull out with fingers and then lens works fine.
Nov 27, 2007 | Kodak EasyShare C330 Digital Camera
I bought two of these on clearance and gave one to my in-laws. She suspected that one of her kids may have dropped the camera or pushed in the lens. I don't remember which lens error number had shown up, but I dis-assembled the camera to find out what the deal was. If I remember correctly, there is a way to manually turn the gears to put he lens back out. I left the lens out and turned it on and it worked perfectly. Fair warning though. It is VERY IMPORTANT not to touch the contacts for the flash EVEN WITH THE BATTERIES OUT!!! God did it hurt like hell... unfortunately it is fairly easy to do and I must have accidentally done it about 4-5 times while messing with it..
Sep 05, 2007 | Kodak EasyShare C330 Digital Camera
Cameras Logo
Top Cameras Experts
Are you a Camera Expert? Answer questions, earn points and help others
