Question about PreSonus FIREPOD (673454000539) Audio Input
No power! The same thing has happened several times in the past and after opening it up to check the fuse and putting it back together it miraculously worked again. This time,,, no luck. Any suggestions?
Actually, the problem is the little white connector next to the fuse. Mine dead stopped turning on one day and I found the solution. You will need a appropriate sized phillips screwdriver, a head lamp or LED keychain that you can aim from your mouth, a slim flat head screwdriver, and some skinny needle nosed pliers.
-- unplug it.
-- Unscrew/remove the right side panel, on the side of the AC connector (I don't advise opening the entire box as it was a bit hard for me to get back together)
-- fire up your light source, you'll need it!
-- *looking at the now open unit form the open side* you will see the green mainboard horizontally across the bottom.
-- *key in on the near right corner next to the small clear tube fuse*
-- the part that is having problems is the wire lead that has a small white vertical plastic connector, (near right corner next to the fuse) (it will probably have a white "tab" coming from the connector that is slightly out of place)
-- take the needle nose pliers, gently grasping the plastic connector on the wire side, and disconnect the wires from the mainboard connector. (may help to use the slim flat head driver to help dislodge this).
-- once it is disconnected, use the slim phillips to realign that white "connector tab" and slowly (making sure to not bend the pins) re-connect that wire piece with the mainboard connector.
Plug the power in and try flipping it on. Hopefully this fixes it for you. I have had to do this about every 6 months over this last year, but its cheaper than buying a new card!
Posted on Aug 19, 2010
  • 1 more comment
  • mboxr Nov 11, 2010
    yes! helped for me!
  • johnsido May 14, 2011
    Thanks! This solution worked perfectly! I used a tiny flat-head screw driver to push in the pins through the two slots on the white plastic connector. This tightened up the connection, which when I replaced the white connector, turned out to be loose within the white plastic connector. I removed the connector again and held it with needle-nose pliers while pushing a very small flat-head screwdriver into each of the two slots on the white connector in order to tighten the socket. That firmed up the connection when I replaced the white connector to the main board again.
  • meisen
    meisen Nov 14, 2012
    Unbelievable! The power died on my firepod and there is no one I could find in the Los Angeles area to fix it. Guitar center said buy a new one, and the only option I had was to send it back to Personus in Louisiana to see if they could fix it. I followed these instructions and it worked immediately. Thank you! BTW, when I went into mine, the white connecter referred to in the instructions (just behind the fuse) looked brown like it got too hot. I think I left it on too much.
    Genius:
  • 1,027 Answers
Must be a mechanical crack on the circuit board.
Posted on May 06, 2010
Testimonial: "Thanks for the quick response! If it does have a cracked circuit board, is it fixable or worth it? It is 4 years old."
Djlightyear saved my life ah ha! followed the routine and power is back! don't really understand what i did - didn't really seem like i was doing anything that would make a difference but did it anyway and plugged it back in and have now got a firepod that works again and am well happy! thanks!
Posted on Aug 22, 2010
    Problem Solver:
  • 11 Answers
The power supply was burnt out at the connecting end on my firepod.
Posted on May 26, 2010
Miata fuse box - 80a now welded into the fuse block - HELP!
Pel, the 80 amp main is bolted into the fuse block. Disconnect battery, metric 10 socket removes the block by the 2 bolts on the engine side, same size bolts on both side of the block, remove them both have ring connectors, be sure to reconnect them when putting back together. I did this same thing last monday during a hail and rain storm.
Apr 20, 2014 | 1996 Mazda MX-5 Miata
No Power Door Locks, Drivers Power Window Not Working
I guess it's just me, but, I don't like taking battery cables loose. I know sometimes it works.
Did you check voltage at proper fuse circuits, use a testlite.
You may have to check proper wire colors in wire harness on hinge side of driver door. You open and shut the driver door so much, sometimes those wires break. I'm talking voltage and ground. The info I looked at was for two door version.
Apr 20, 2017 | 2006 GMC Canyon
The lock on light wont go off. We can not start the dishwasher. We have tried holding the noheat option for several seconds and have turned off the circuit box for several minutes and neither one made...
That is the correct button to push to turn the control lock off. You can try to reset the control by removing power for two minutes. If the dishwasher is doing the same thing, most likely the touch pad has a shorted button or a bad connection on the unit control board. To check touch pad connection you will have to open the console. You will want to turn the power off to the dishwasher first.
Open the console.Once the console is open, remove and install the ribbon cable a few times. Now put the door back together and restore the power. If the dishwasher works, it was just a bad connection on the ribbon cable. If the console is doing the same thing, it could be a console or a unit control faulty. I recommend the console first.
Aug 03, 2010 | Kenmore Dishwashers
1991 Ford F-250 (again!) 4.9 liter, dual tanks. Just replaced the ignition switch on the column, replaced a fused link that went open due to the old switch shorting out. had it all put back together things...
try resetting the inertia switch located on drivers side way up under the dash,with a red button on top,maybe you kick it or hit the body hard enough to kick it off,also check the fuel pump relay under the hood drivers side ,i think brown and black relay box over wheel( inner fender)..and check the fuse,and new fuseable link
Feb 16, 2010 | 1991 Ford F250
Changed bottom screen tested before putting back
Happens sometimes it is one of two things:
1) When you put the DS back together is the ribbon from the top screen wound to tightly as this can cause the ribbon to pull out slightly from the socket on the motherbaord causing the blackout.
2) I have seen this happen only once before! The plsatic of the shell had a small chip where the battery connectors from the motherboard stick through into the battery compartment. THis tiny piece of plastic was stopping the final connection between battery and DS. Drove me mad, did all the usuals checked battery connections etc. Worht a look.
Nov 19, 2009 | Nintendo DS Lite Console
Opened laptop to replace floppy , now won't turn back on
Reverse what you did and see if it works again,but before doing this check the floppy connections.
Oct 12, 2009 | Toshiba Satellite 2400-S201 Notebook
Toshiba 65H81 blinking power light
Hello
I have the same thing going on with mine. What it is the SLR main Reg. is bad. The only way you can fix it is you can't put just one part in it you have to replace one of the boards. When you open the back panel up you will see three boards in a roll the one that needs replacing is the power board you have to get the model number. My Tv is a 65 HD model 65h81 the board on mine has a part number of PD 7400 yours will have something like that. Well let me know how it's goes my E-Mail is kenjr1@iwon.com
Feb 14, 2008 | Toshiba 65H81 65" Rear Projection...
PS2 TROUBLE SHOOTING/ POWER
Hi, I think what probaly happened was when you were cleaning it you pulled out a wire or cable. When you clean you have to be careful, you should always go onto a website check how it is done. The best thing to do is to take it to someone who can repair for you.(It does not cost much) Hope it works again.
Jul 04, 2007 | Sony PlayStation 2 (PS2) Console
Computer not powering up intermittently - Abit IS7 mobo
I doubt it?s the dust causing your problem, more that likely you?re either: - brushing against a defective cable/component with an intermittent short OR - you have a failing component, sometimes it works, sometimes not. I would take a look at the following: -Check your power switch, it could be failing. Put a multi-meter on the two leads and watch what happens when you pre the button several times. -Check all your interior connections including cards, memory and processor. Also check to ensure your system board is grounded correctly. -Try swapping out your power supply. Let us know what happens and please don?t forget to rate this posting.
Mar 16, 2007 | Abit IS7 Motherboard
Open Questions:
See all PreSonus FIREPOD (673454000539) Audio Input Questions
PreSonus FIREPOD (673454000539) Audio Input Logo
580 people viewed this question
Top PreSonus Televison & Video Experts
Are you a PreSonus Televison and Video Expert? Answer questions, earn points and help others
