Question about Intex Easy Set 530 Gallon Swimming Pool Filter Pump
When i plug in my model 603 filter pump it wont start it doesnt even make noise
My Mitsubushi Space Star Car won't Start. What can I try?
spark plugs are deep in the head yet you should get all the the old fuel out first, stale fuel wont ignite and will also clogg fuel filter. you need a mix of atleast 70% new fuel even then its not good for the injecters. If its a manual gearbox a tow start is a quick fix although no go for auto's. cant be much wrong if car was fine when parked, plugs-fuel-filter and possibly fuel pump for sure. If that doesnt fix take plug out put in lead and crank engine to be sure you have spark even just put any plug you know works in lead leaving your plugs in engine just to check for spark y turning over engine looking for spark on plug good spark will be blue but any spark is good.
Jun 16, 2012 | Mitsubishi Cars & Trucks
I have a intex model 603 filter pump that keeps tripping the reset on the plug... it seems that when i first hit reset it will work for a few mins but then trip.. i can hit reset again and it will work...
Have you tried running an extra duty extension cord to another plug, not in that circuit?? Your GFCI may be bad?? Pump drawing too many amps and the breaker not rated for those amps.. Bad pump??
I would try another plug first and work from there...
Aug 24, 2011 | Intex 603 Krystal Clear Filter Pump 530...
My model 603 filter pump leaks at the top under cap
It could be the o-ring on this model. There is a seal on these pool filters that looks like a rubber ring inside the lid. You might need to replace this ring if your pump is leaking here.
Apr 30, 2010 | Intex 2500 Gal Easy Set Swimming Pool...
93 volvo 850 glt changed the fuel pump now car wont start. Engine cranks, fuel pump working, fuel getting to the motor but it wont start. The car had trouble starting sometimes so i changed the fuel...
Check your fuel pressure to ensure proper pressure to the block, also did you replace the fuel filter.
On a side note: 3 things a automobile needs to run
AIR-make sure you have a clean air filter and your MAF (mass air flow sensor is plugged in) if you pulled your breather to innspect anything, there is a possibility that it came unplugged or you unpluged it and forgot to hook it back up, a car wont start without it being plugged in if equiped
SPARK-Make sure your car has juice to the plugs, if the plug doesnt fire the car wont run, if you have to pull each plug and ground them to the engine block to see if they arch. If not trace the problem down (if you changed the fuel pump you have some mechanical skill and should be able to troubleshoot a spark issue)
FUEL-Check for proper pressure, dirty fuel filter(s) and if your system has a return line, make sure your hoses didnt get crossed cause this will damage the engine and regulator.
Hope this helps Thanks for using Fixya.com
Jan 22, 2010 | 1994 Volvo 850
Car wont start maybe a bad fuel injector
Try cleaning the fuel filter. listen for a whirring noise from the fuel pump when you turn the key.
Dec 16, 2009 | 2002 Oldsmobile Alero
Engine is cranking, but it wont turn over
Good for you as you already have an idea.
Check your battery and the starter. It's a minor issue.
Please rate this...
Mar 20, 2009 | 1989 Ford Bronco II
Intex Easy Set 530 Gallon Swimming Pool Filter Pump Logo
450 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
