Question about Canon Office Equipment & Supplies
Canon DR-9080c scanner shows ''No Page was found in the feeder''
Running WinXP Pro sp3, when trying to scan with multiple scanning apps, we receive the Scanner Error of ''No Page was found in the feeder''. Tried a different scanner on that computer...same error. Tried the scanner on a different computer...same error.
3 Suggested Answers
mohanchennai
  • 490 Answers
SOURCE: Canon DR-9080c scanner not lifting error no page found in feeder
There is a paper sensor just under the rolers in the lifting tray. Clean the area thoroughly with a damp cloth. Keep some sheets and try ]count only'. If it works then the sensor is okay, then you can try your scanning. If it is not sensing paper, check the sensor or connections to the sensor.
S. Mohan, India
Posted on Jul 10, 2009
mohanchennai
  • 490 Answers
SOURCE: Paper tray at front of scanner will not lift.
Disconnect the scanner from the Comp, Try 'page counting'. If the papers go through, then you know feed mechanism is okay. if the tray is not lifting, then you have a problem. Use Qumatool software and check if the tray is lifting. If the scanner tray if lifting then the motor is okay, if not, the lifting motor may need a check.If the motor is okay, but tray not lifting means the sensor in the paper tray is faulty. Check this out.
S. Mohan, Chennai, India
Posted on Jul 28, 2010
Tray lifts to meet the rollers then drops back down. Error message 'No page was found in the feeder'
Clean the 'black dot' in the centre of the paper tray. There is an optical sensor under that. The tray will lift even without paper, but will go back immediately.
If the scanner stops after 3 pages, check disk space in your computer. If you are scanning in TIFF uncompressed, it takes lot of space. For color and Grey try JPG format, for mono TIFF G4 is the ideal option.
Mar 02, 2012 | Canon DR-9080C Path-Through Scanner
We have a Canon DR-9080C scanner. When scanning in Duplex on pages with data on both sides, the back side of each page is coming out unreadably faint. The header and any overall large blocks of black on...
The Canon DR 9080C is a 'contact' scanner. There is no optical lens, instead it uses a technology called "Contact Image Sensor' or CIS. The page to be scanned must be close to the glass for a proper image. This is achieved by a full-length rubber roller just above/below the scanning module. The roller is spring loaded and in case it gets stuck, there wont be enough pressure on the document to keep it close to the glass. ensure these rollers are moving smoothly and if required clean them. The rollers are on the opposite of the Scanning module.
Jul 29, 2011 | Canon DR-9080C Path-Through Scanner
Canon DR-9080C gives Low memory message
Duplex scanning, Color Scanning and high-density scanning (600 dpi) cannot go with long documents like 11x17. Change the scanning mode, try one side at a time or reduce the resolution.
Dec 11, 2010 | Canon DR-9080C Path-Through Scanner
Canon 9080C not scanning 11x17 pages
The problem is probably in your scanning software, you have to tell it if you want to scan legal size, and if you leave it set for legal all the time it might put dark bars under the letter size docs. It depends on the version of software on your computer.
Sep 03, 2009 | Canon DR-9080C Path-Through Scanner
Acrobat and Canon DR-9080C not working
You are right, it is driver related issue. Acobat 9 has more features that may not be compatible with the existing driver. may be you can use CapturePerfect and directly create PDF and then use the Optimising features of Acrobat 9. Ofcourse you have to do it twice, but you can use the 'batch' process and do it automatically.
S. Mohan
Jul 09, 2009 | Canon DR-9080C Path-Through Scanner
S. Mohan, India
Not scanning full page Canon DR-3080II/CapturePerfect
U should select 'Scanners maximum'  and try this. I have found this does not work midway, after some scans. So close and exit out of captureperfect, re-enter and try. This should work.
S. Mohan
Nov 19, 2008 | Canon DR-9080C Path-Through Scanner
"Skip Blank Page" but still inserts one
I have two of these scanners the only way that i have found round this is to scan the pages duplex then remove the unwanted afterwards!
Aug 26, 2008 | Canon DR-9080C Path-Through Scanner
Imprinter won't work on DR-7580/9080C
I have the same model Canon DR-9080C scanner which I recently acquired and I'm trying to figure out how used it is. I see many referrign to a counter. I see the big LCD on top front, but how do you know how many total pages have been scanned through it? I read somewhere there is a mechanical scanner. Is this true?
May 31, 2008 | Canon DR-9080C Path-Through Scanner
940 people viewed this question
old marine
old marine
