Question about Zenith VCS442 VHS VCR
VCS 442 Zenith
I have only a blue screen at this point. I am trying to add all the channels that I had 15 minutes ago before I had to unplug it to move it. Can you tell me how to do this.
Also, do you have the speaker arrangement for the Alesis 5.1
    Sergeant:
  • 291 Answers
One way is to connect an antenna to INPUT of VHS, place a tape, press play, STOP and switch VCR\TV switch to TV. u should be able to change the channels from the VHS. If that don't work, u may have switch problems.
If this works, tell the boss..........FixYa.com
P.S. The 'blue screen' means that you don't have a signal to the antenna inpur\TV protion of VHS.
Posted on May 13, 2008
SOURCE:
My mother's Grundig TV doesn't get 2 channels she wants. They only display a blue screen. All the others work.
Try a reset to this set, and then check. There are two methods to reset TVs. The first is simple to do; a Hard Reset. The other is somewhat skilled; is a Factory Reset (System Reset). To make it a hard reset, just unplug the TV from AC mains wall socket, and re-plug it back after 15 minutes or so. If you do this by overnight is better. This procedure will make it a hard reset. If you want to make it a system reset [Factory Reset]; you have to enter its service mode option, and select the factory reset option. If you wish to get some details; check the site linked here. Pull up older posts. http://electronicshelponline.blogspot.com/
Service mode entry, adjust and exit procedure to many popular brand TVs are given. Never forget to exit the service mode, after all adjustments have been done.
Jun 05, 2016 | Grundig Televison & Video
Hi, we have a goodmans GTVL27W23HD that was left on standby for 6 days, now will not show the digi-box channel, just a blue screen, sound only on scart 1 any suggestions anyone? something re-setting...
Try to unplug everything and plug it back in at the correct order(without power). Then plug the power and into the items in the correct order and let them power on for about 5 minutes. With the blue screen that may take about 15-20 minutes.
Apr 19, 2008 | Televison & Video
Zenith XVB422 DVD VCR comb
Hi skielty58...I just saw your post, so I haven't done any research yet. However, IF should you see this post prior to my, or any other contributors forthcoming updates which should contain a certain resolution, I would like you to try something during the interim. Play a dvd, and although showing the blue screen, allow to play for about a minute. Now, using your remote, press and release STOP, and within 1 second, Press And Hold Stop for 10 to 15 seconds. This trick is reliant upon the timing sequence, so, you may want to try it more than once. Another trick that I'd like to suggest is that again, after allowing a dvd to play for a minute, simultaneously press select and stop on the player...Please update your post whether positive or negative so other potential contributors have the benefit of ongoing history...good luck my friend
Jul 31, 2007 | Zenith XBR413 DVD Recorder
Scanning for channels
make sure you set the settings for catv (cable) not air (antenna). If any other boxes are connected to it first put them on channel 3 then scan.
Nov 20, 2013 | Televison & Video
Emachine 442 laptop dead red led blinks no blue led. laptop computer
You can try to unplug it and take the battery out for about 20 minutes then try again.
Oct 22, 2013 | Computers & Internet
Hi we have lost all channels of our hisence tv just blue screen saying no signal please help had channels yesterday
Nothing to worry, You change to AV mode to TV mode and wise verse,
If nothing happen then call the service center, It only two months old.
Jul 23, 2012 | Hisense LCD1504 15 in. Television
My zenith D52WLCD has a blue haze going diagonally
This a Normal Intensive Use Defects, this a Screen Burnout. Sorry
Oct 31, 2009 | Zenith Televison & Video
I am stuck on channel 2
some tv's default to channel 2 after being unplugged.since it is a older tv ,the buttons on the remote and the tv maybe worn down.on the tv itself try pushing the buttons down a liitle harder. if you have aux or line in/video inputs,scroll down on the channel button to log into a aux channel for the dvd player.as for the remote try buying a cheap universal remote to see if that works.
good luck
wg
Feb 02, 2008 | Zenith A25A23W 25" TV
LCD TV picture is green
I just called Vizio and they said to unplug the TV, then physically hold in the power button on the TV for 2 minutes.
Nov 19, 2007 | Vizio L37 Television
Pink screen
When the "pink screen" happens on my Polaroid FLM-1911 TV, I unplug the power cord from the back of the unit, wait 30 seconds, and replug it. This fixes the problem.
Oct 23, 2007 | Televison & Video
Zenith VCS442 VHS VCR Logo
79 people viewed this question
Top Zenith Televison & Video Experts
matt martin
matt martin
Jaime Hernandez
Are you a Zenith Televison and Video Expert? Answer questions, earn points and help others
