Question about Dryers
My ge electric dryer model number fse747ges1 wont start. i replaced the start switch. still wont start.
  • riza18 May 09, 2010
    door switch tested out ok. makes a click sound when turning start switch. seems to be coming from direction of control board
  • 11,896 Answers
Check the door switch. If it is bad, loose, or faulty, the machine won't start. You can test the switch with an ohmmeter. They are a common problem causer, especially in a no-start senario
Posted on May 06, 2010
  • Nate Stansfield
    Nate Stansfield May 10, 2010
    That could be a relay clicking. Do you get any water flow at all? Hopefully you don't have the common control board failure.
Why doesn't the dryer stay running when I let go of the start switch?
Hi, There is only one reason I can see the dryer stops after you let off on the start switch is the motor because GE motors has start switches either built inside the motor which is non removable or built outside the motor which can be replaced .
Its called a motor start switch and the way to locate it is to remove the front panel on the dryer and remove the drum and belt and then write down the motor model number and look at all the wires that go into the motor which is your motor start switch that is held in by two screws but before you remove it don't forget to copy the wire down on piece of paper of how you remove them .
If you don't see a black switch to the motor then its built in and the motor needs to be replaced.
Oct 23, 2014 | GE DWSR483EBWW Electric Dryer
How to replace start switch on ge dryer
Hi tamalac
Go to this webpage and you will see how to disassemble your dryer for repair.
It is not the same model as yours, but will disassemble about the same
Please take time to rate me
Bud
http://www.youtube.com/watch?v=yIPnnUqJ6Ds
Oct 17, 2012 | General Electric DBXR463EGWW 6.0 Cu. Ft....
My gallery dryer fse747ges1 does not always start to tumble or will stop after it reverses direction. If I give it a push on the fins and restart it will start again. Could this be a capacitor problem? Are...
There can be many reasons why your dryer will not start or turn...
The most common causes are the belt breaking or jumping off, or the motor goingbad...
Here are a couple of tips that I wrote will help you to figure out why yourdryer will not run...
Dryer Repair - The Dryer is not Turning
Dryer Repair - The dryer will not start
heatman101
May 10, 2011 | Frigidaire GLER642A Electric Dryer
My ge dryer wont heat up
Hi, If you have a gas dryer2_bing.gif.
The most common problem with a gas and no heat is the ignitor going bad...
Here is a tip that I wrote about that problem...
Gas Dryer2_bing.gif not Working Gas Dryer2_bing.gif Not Heating
http://www.fixya.com/support/r4398592-gas_dryer_not_working_gas_dryer_not
If your dryer2_bing.gif is electric2_bing.gif..
There could be a number of different problems...
Check out this tip that I wrote about this problem...
Dryer2_bing.gif Troubleshooting2_bing.gif Electric2_bing.gif Dryer2_bing.gif won t Heat
http://www.fixya.com/support/r3866345-dryer_troubleshooting_electric_dryer_won
heatman101
Jul 08, 2010 | GE DWSR483GB Gas Dryer
The dryer starts without using the start knob when you open and close the dryer door during a cycle. The dial is also not advancing during the dry cycle and the clothes are taking a long time to dry.
Assuming that you have GE dryer DBXR463ED0WW,
Sounds like there is a couple of problems there:
  1. The start switch is stuck and needs replacement/repair, part number WE4X881
  2. The clothes taking too long to dry may be due to a) clogged dryer vent; b) one or both heater coils burnt out; part numbers: WE11X10007 for restring coils only or WE11M23 for whole heater assembly c) problem with temperature selector switch, part number WE4M407
  3. There might be a problem with timer (WE4M271), but before replacing it I'd suggest taking care of the long dry problem first. In some models, timers are wired that way so the timer advances only when there is heat, so check the schematic.
There should be a schematic diagram inside the control panel, use it to for diagnosing the problems you described.
Good luck,
Vlad
First Choice Appliance
Apr 10, 2010 | GE DBXR463EDWW Electric Dryer
GE electric dryer wont start
The first thing I would do is check your door switch. When the door closes it hits a switch to tell the machine it's safe to start.
Hope this helps!?
Jun 19, 2009 | GE DBL333EBCC 5.7 cu. ft. Electric Dryer
Non-existent model number
That Sounds More Like A Serial Number. Can you Maybe Locate A Part Number On The Switch?
Also Why Did You Determine Its The Switch?
Jan 18, 2009 | GE DVLR223 Dryers
My ge dryer wont start
Hi thanks for the question. You could have a problem with the door switch, On that dryer theres a belt break switch.check that
Dec 16, 2008 | GE DWXR483EBCC Electric Dryer
Tub wont and start switch wont hold
Hi! msbjs
Sound like this could be a motor problem. Is there a lot of lint inside the dryer and around the motor?
InMrFixIt
Oct 30, 2008 | GE DBSR453EBWW Electric Dryer
Ge dryer wont stay running
start switch is bad,it is stuck inside,get the model number inside dryer door or on top panel,call local appliance parts store to get new part,only a few bucs,replace and you should be allright,let me know-mike
Jun 15, 2008 | GE DBSR453EBWW Electric Dryer
Dryers Logo
138 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
