Question about NetGear WGT624 Wireless Router
Cant get my computer wireless
I already talk to a teck a weekago and was up and running wireless
now its not wireless again the rougter shows low signal what can i do
my computer works with the moden,i test the router and it says its 100% get back carol witt
  • 2,069 Answers
You could try changing the location of your router and see whether signal strength improves, check also its antenna then restart every thing.
Posted on May 17, 2010
I reset my router but what is new password is my rougter?
here is the manual - there should be non but if this is a device from a telecom, it will be their default password and username.
http://www.westell.com/docs/support-documents/327w11_06_ug.pdf
Apr 12, 2014 | Westell Versalink 327w Wireless Modem...
Cant connect wierless
For wireless printer like these you need to make sure that it is connected and configured already to your existing wireless network. If not yet better connect the printer to your computer via USB and then run the setup disc and follow the setup wizard to setup the wireless.
Oct 14, 2012 | Lexmark X2600 InkJet Printer
Purchaced used on line. Is off warantee period so disc won`t allow install. Called Linksy`s teck dept. If I pay them a $30. fee they will talk me through the install. With what I paid, plus fee I could...
The disc for these routers usually holds nothing but a configuration wizard, and I've never before heard of one being time-limited. In any event, the configuration wizard doesn't do anything that you can't do by hand (and in fact have to do by hand on a non-Windows machine, right?) You can find the manual for this product here:
Linksys WRT54G2 Wireless Router Manual
Follow the installation and configuration instructions there.
Jun 17, 2010 | Linksys WRT54G2 Wireless Router
I have a wireless rougter by netgear and cant get it to work with my i pod and lost the booklet as well
Please try the below steps::
-- open the netgear setup page using www.routerlogin.com
-- check the wireless settings--
-- security should be WPA_PSK(TKIP)
-- passphrase can be anything that u want
-- apply the wirless settings..
And then
-- go to the I-pod touch Wireless settings of the I-pod
-- scan for available networks..
-- And when u find ur network name.
-- try to connect using WPA_PSK
(TKIP) passphrase ..
-- And the it will show u connected
-- and u will be able to go online wirelessly using I-pod
For further queries please revert back as soon as possible..
Jan 13, 2010 | Apple iPod touch
Same BS wifi problem as everyone else
Have you tried restoring the computer back a couple of days to see if that clears up the hardware hiccup? You can also go to device manager and uninstall the device and delete the drivers. Turn the laptop off, take the wireless card out. Start the laptop back up and boot it fully....After a few, shut down again. Install the wireless card and restart the laptop. When asked to install the drivers for new device found, say ok, make sure you are online with an ethernet line so windows can go online and load the newest drivers unless you have them on your C drive already.
Aug 30, 2009 | HP Compaq Presario F730US Notebook
Linksys Wireless NIC PCMCIA card
From what you described, and it sounds like you were thorough and know what you are doing, I would try another card in your laptop. If it is enabled and there is no green light then the USB port(or card slot) has failed or the unit is bad. The LED will be on regardless of detectable networks. I hope it is under warranty or you can find another cheaply. I think you have done the best job anyone could do to troubleshoot the system. Again, my best advice is to try another known working card. This is the final step of your root cause analysis. I am sure you already know this so please don't give me a bad rating.
Aug 24, 2009 | Linksys (WMP54GS) 802.11g/b Wireless...
Says my linksy adaptor is inactive. would not go to setup wizard after files downloaded from startup disc.
You can try first removing all the Linksys software from the computer and then after that unplug the LInksys adapter from the computer and restart the computer.when the computer is already up you run again the setup CD and follow the steps again and you can already connect the Linksys adapter before running the setup so the computer will detect it already...
Aug 15, 2009 | Linksys Wireless-G WPC54GX (DHWPC54GX)...
Cant conenect netgear dg834g to talk talk to set up wireless
Make sure that the wireless settings set in the Netgear router are properly configured in the computer. Check the wireless adapter status from Device Manager and see to it that it is working properly.
Nov 08, 2008 | Computers & Internet
My computer keeps dropping the signal i have already talked with a tech i need help the signal keeps on fading and i cant get on the internet with my laptop computer.
you should try checking the wireless security & channel.
make sure if your network requires a security you should check that your typing the right one cause this is case sensitive.
make sure also to check the wireless signal of your router or Access point be sure to set that on channel 11.
Sep 18, 2008 | Belkin Wireless G Plus MIMO (F5D9230-4)...
Open Questions:
See all NetGear WGT624 Wireless Router Questions
NetGear WGT624 Wireless Router Logo
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
