Question about Canon LV-S3 Multimedia Projector
Svga problems svga dont show the image, instead the composite is ok the cable is ok and the pc also, what can i do? please tell me help about this problem
  • 36 Answers
The problem may be that the native resolution of that projector is probably 800x600 try lower resolution on computer it maybe to high for projector, and if you have a laptop make sure you enable output port and lower resolution too. Best of luck!!
Posted on May 07, 2010
Sony kvj21mf1ak
It sounds like either the TV or the device is trying to do S video instead of composite video.
see if you can change the output type of the media player and make sure that the TV input is not set to S Video.
Nov 19, 2013 | Cell Phones
When I Connect My Aiptek 8100 camera to the PC, they show a message "USB device not recognized." Is this because I did not install it's driver? If so please tell me where I can find the driver?
Usually usb device not recognized is due to damaged usb cable or usb port..use a different usb cable and connect it to your pc, if your usb cable is ok then connect it to a different usb port. if the problem in not with the usb cable or port install driver from the cd you got with camera. if you dont have that cd download driver from the device manufacturer site.
Oct 03, 2012 | PC Mall 8100 (MODEL 8100) PC Notebook
Can I change the Presario 1200-XL103 Laptop video mode from VGA
U just went to ur brand site.. and there u enquire about ur problem.
Sep 29, 2009 | Computers & Internet
Can I go from VGA to SVGA?
If the question is can I convert my composite video output to a super video input then the answer is NO,
The composite is coaxial (2 wires) the S-Video uses 4pins and there is no S-Video output on a Presario 1200 laptop.
You can however use a Multi-AV SCART adaptors with Input/Output signal switch where you plug in the composite video output into the top video and 3.5 mm jack stereo audio into the mono audio connections on top.( via a stereo to mono cable)
http://upload.wikimedia.org/wikipedia/en/thumb/a/a7/Multiconnector-scart-chti.jpg/200px-Multiconnector-scart-chti.jpg
Hope this is the answer you are looking for !
Sep 27, 2009 | Compaq Presario 1200XL103 (155726-163) PC...
I INSTALLED MY ATI RAEDEON 128PCI VIDEO CARD AND IT HAS S VIDEO OUT AND COMES WITH THE SVIDEO TO RCA CABLE BUT I CANT GET THE IMAGE TO DISPLAY ON TV
The S-video to Composit adaptor tells me that you wish to connect to the Composit input of the TV
Connect the TV , set the TV to ( Composit input ) Composit 1 , or Composit 2 , NOT A CHANNEL
restart the computer , this will help the video card and software to detect that the TV is now on and connected.
When you come back to windows you should be prompted to perform the television setup wizard
if not
go to your display properties
Advanced tab
and manualy configure the video card for television output.
Selah.
Sep 15, 2008 | Computers & Internet
Infocus lp640 lcd projector
check vga cable(cable between computer and projector)-try fn key with combination of f4orf5 orf6 or f7 or f8-confirm that input source assigned to pc.
Jul 08, 2008 | InFocus Office Equipment & Supplies
Poor picture quality on my samsung HD TV
Hey xf1racer,
Based on the description that you provided, it sounds like you are using a bundled composite video cable to connect your cable box and TV. Composite video cables generally consist of three color-coded cables: one yellow, one red and one white. While the yellow cable is typically used to transmit the video signal to your TV, the red and white cables transmit the right and left audio channels respectively.
Red/green/blue bundled cables however, are often referred to as component video cables - each of the three colored cables is used to transmit a different portion of the same video image from one device to another, and require a second separate cable (typically red/white) to transmit an audio signal.
The primary benefit of using component over composite cabling is that many users may report a cleaner, more brilliant image on their TV as a result. Please keep in mind however that this is not a guarantee that changing from your current set-up to component cables will improve the picture quality on your TV, as picture quality is often based as much on personal preference as it is the actual configuration and settings of the equipment used.
Additionally, many retailers may suggest changing your current configuration to one using HDMI cables instead to improve picture quality even further. Unlike composite and component cables, standard coaxial cables, and S-Video cables which transmit analog signals, HDMI cables are designed to instead transmit uncompressed digital signals. This typically means that more information is available for your TV to process in terms of color hue, color intensity, as well as image resolution. Again, remember that any perceived improvements will be based on both personal preference as well as your home theater configuration.
Should you have any questions or lingering doubts, I would strongly suggest speaking with a Magnolia Home Theater agent at your local Best Buy™ store for more information. Most stores will have similar TV's on display using more than one type of connection, and sales associates are always able to provide additional suggestions if desired.
Hope this helps you out.
Sincerely,
Aaron
Go Ahead. Use Us.
May 10, 2008 | Samsung PCL545R 54" Rear Projection...
Need Drivers
Hi Jess
Is your PC's image splitt ?
Right click on your desktop and go to properties - then click on settings and then advanced settings.
You'll see a block with two screens on it. If only one is activated - activate the secondary screen as well.
If you are using a Notebook also try holding in the Fn ( Function ) button - just left of your spacebar and in your F-row buttons at the top there should be one with two screens on it - Differs from brand to brand of PC's.
Hope this helps you !
Mar 26, 2008 | ASK Proxima Proxima DP2000S Data Video...
Screen flickers
Computer Video Card Support and Help The below image is an example of a screen running at 640 x 480 which means 640 ... Refresh rates below 75 Hz can produce an often-imperceptible flicker.
Monitor Help ... you may encounter a flicker or a noticeable steady line scrolling from the ... While new monitors (VGA / SVGA) do not have this issue.
Good Luck , Please dont for get to Vote/Thank You.
Dec 22, 2007 | Acer Aspire 3610 Notebook
Panasonic PT-AE900U displays black and white only
sounds like bad cables, or wrong setting on projector you may have it set to compoent instead of composite,, you don't tell how you are hooking it up. (what type of cables you are using)
Oct 25, 2007 | Panasonic PT-AE900U Multimedia Projector
Canon LV-S3 Multimedia Projector Logo
54 people viewed this question
old marine
old marine
