Question about Lands Phones
Need USB driver for UTStarcom CDM7076PP. Windows ID's it as ''C7076''. Want to connect it to a Windows XP PC for flashing.
SOURCE: Cannot connect my PDA to PC
Normally for when you connect any device to pc using USB port, windows detects it. Sometime it may take time.
Few initial things you may check....
1) You must have your PDA in ON condition
2) If PDA is not getting connected on port, try connecting to other USB port (assuming that pc normally have more than one USB port)
3) Make sure the cable that you are using between PDA to PC is working properly (normally you can check this by using other cable)
4) If you have intalled some anti virus program on your pc then check the settings of same.
5) last but not least check the settings of window's firewall (part of OS)
If everything of above is fine then either USB ports of pc or of PDA might not be working.
All the best!!
Regards,
Av
Posted on Dec 10, 2008
pgmadhav
  • 145 Answers
SOURCE: MT 6225 usb modem driver
Dear Dev,
I am giving you the links from where you can download these files. Please don't forget to rate me.
http://www.2shared.com/file/4046162/b6da4eb5/MTK_CPU_USB_Driver.html
http://www.2shared.com/file/4046227/a09ac167/China_PhoneSuite.html
It will be good if your phone has IMEI number, otherwise after some time Indian Government is going to ban the phones which don't have IMEI numbers. You can check this by pressing *#06#
Please rate me appropriately if you are satisfied with my answer,in case, if you want any clarification please get back to me.
Posted on Dec 30, 2008
SOURCE: How to upload recorded movie to PC using USB
Do I need a driver so that Windows XP recognize my JVC GR-D850 when I connect it thru USB port? If I need, where can I get it?
Posted on Apr 10, 2009
SOURCE: PC does not recognize Lumix DMC-TZ5 as USB device
I contacted Panasonic and here is what they told me to do and it worked.
"No additional drivers are needed as it runs off the USB drivers imbedded in
your Windows OS. That being said though, it is not that the USB ports on the
front of your computer are faulty, just that they are in fact a HUB and not
the port which is located on the back of the PC. Windows does not
traditionally like reading external Hard drives (your camera becomes one when
PC connect mode is selected) through a HUB. In this case I would still
strongly recommend connecting to the back of the PC."
Posted on Jun 30, 2009
SOURCE: USB Driver for Windows Vista
I am currently running Windows XP on my PC and upgraded it to a Windows Vista operation System does a USB driver exist for Windows Vista that will allow me to connect to my Panasonic KX-TDA 200 Phone System.
Posted on Jul 01, 2009
Keep getting 0x0000007b (0xf78d2524, 0xc0000034, 0x00000000,
So, where did you get the Windows XP drivers for the controller? Are you sure that they are XP compatible?
Is the USB floppy even being recognized and read by the setup program?
The Windows Setup program only supports a handful of USB drives for F6 driver installation method, that is explained here:
A connected USB floppy disk drive does not work when you press F6 to install mass storage drivers during the Windows XP installation process
Adding the standard Microsoft USB storage drivers to the txtsetup.oem file on the floppy diskette usually resolves this problem, see here: http://www.intel.com/support/motherboards/server/sb/CS-026606.htm
Adding the USB floppy's vendor ID should also fix the problem, see here for an example:
http://blog.mreza.info/archive/2007/09/19/windows-f6-driver-and-usb-floppy.aspx
None of my business but why not use Windows 7 on the new laptop, instead of going through all this trouble installing an operating system that is 10 years old and that is living on borrowed time?
Jan 19, 2013 | Dell OptiPlex 330 Desktop Desktop Computer...
How do i create a bootable usb flash drive from a windows bootable disc? basically my daughter has messed up her netbook and it now requires a fresh install, i have a windows disc but the netbook has no cd...
I have just done this and USB is OK, there is a link below. http://wiki.eeeuser.com/windowsxpusb
But I assure you it is much easier to get a USB to DVD dongle attach a DVD, Using a SATA DVD, works great. set to Boot from USB-DVD and it will be simple, also download the EEEPC XP disk, it install a special XP for the EEEPC and has all drivers.
There is the torrent links for the ISO, download and burn to DVD If you already have it then it is all moot.
http://www.torrentreactor.to/torrents/download/1585860
http://dl5.torrentreactor.net/download.php?id=1732907&name=Windows+XP+sp3+Lite+for+ASUS+eee+PC
Feb 11, 2010 | ASUS Eee PC 901 Notebook
NEED DRIVER FOR PNY 8GB USB ATTACHE
If you're using the drive on a PC with Windows XP or Windows Vista, you don't need a driver - just plug it into the PC and Windows will recognize it and install USB drivers automatically.
Dec 07, 2009 | PNY 8GB USB 2.0 Flash Drive - Blue/Black
No drivers came with the 4GB HP usb flash drive v125w I just purchased. I can not find them on HP web site. Need for Win Xp. Help
Windows 98 has no support for newer USB flash-drives.
Windows XP has full support for newer USB flash-drives -- if it cannot find the driver on your 'C:' disk, it will access the Internet to download the drivers from Microsoft's web-site, automatically.
Nov 05, 2009 | Microsoft Windows 98 for PC
No connectivity
usually windows doesnt detect external modems except when they are connected through usb port which is plug and play. i guess after connecting the modem with lan port of pc try configuring the settings in windows and modem for internet connection to work. if the led of lan on modem is stable it means the modem is connected to pc well.
Aug 08, 2009 | Computers & Internet
Usb Driver For Huawei SmartAx Mt882 for win XP professional
Windows XP Professional doesnt require USB Drivers, these Driver built in Windows XP professional
or there already present in ur system..........
so go ahead connect anything to ur usb port(like digital camera, mouse, pen dirve, flash driver , memory card reader,..portable harddisk , digital cameras)
when u insert any of the component(for eg: pen drive) in to the usb port OS will automatically detected these devices and install USB Drivers.... dont worry... about this  and be rest assured....OS will do the work for u...............
Thanking You
M. Sridhar
Dec 26, 2008 | Computers & Internet
Baixing TV200 Mobile USB not connected to PC
I Have the same from, my phone baixing tv200 cannot connect to my pc help me with drivers, plz.
Aug 26, 2008 | Siemens M56 Earbud Hands Free Headset
Lands Phones Logo
1,362 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
