Question about Brother MFC 7420 All-In-One Laser Printer
Printer install error
I keep getting a "IS028 - SetupFaxPrinterDriver - 1" error. I turned on the spool function and still get the error. I lost the printers when my drive memory got extremely low and all kinds of havoc occured, The erroe message tells me to reinstall "MFL-Pro suite", but when it updates the registry it come up with the above error.
Soulvisitor
  • 1113 Answers
SOURCE: MFC 7220
Are you using vista or xp?, download correct version of full driver and software package from brother web and reinstall after unistalling previous attemps (there is uninstall tool on brothers web as well)
Disconnect printer untill software asks to connect.
Posted on Nov 04, 2007
SOURCE: MFC 440cn, lost mfl pro suite
there is no mfl pro suite on brother com. please correct your advice.
Posted on Mar 27, 2008
scrodamoon
  • 659 Answers
SOURCE: Can't download my MFL-Pro suite for Vista
please go here
http://welcome.solutions.brother.com/bsc/public/us/us/en/dlf/download_index.html?reg=us&c=us&lang=en&prod=mfc240c_all&type2=-1&os=74&flang=English&dlid=
for the vista drivers for the 240c I have the same unit good stuff download the Full Driver & Software Package
Posted on Aug 04, 2008
  • 124 Answers
SOURCE: lost driver from new MFC-290C NEED MFL-Pro Suite
Here's what you need to download:
http://www.brother-usa.com
Upper right side, downloads and support, click Downloads/FAQs/Help and more.
From the drop down in the middle of the page, select:
Multi-Function Center (MFC and DCP series)
Select model MFC-290C, click View Support Information
Then click MFC-290C Downloads on our Online Solution Center
Select Drivers, pick your operating system, then your language, then Search.
Download the Full Driver & Software Package and you should be good to go. :)
Posted on Feb 20, 2009
SOURCE: I have an error message - ControlCenter2.0 -
...so re-install the software like it says, or try a system restore to a few days ago when it was still working:
in XP:
"Start"
"Programs"
"Accessories"
"System Tools"
"System restore"
"Restore My computer to an earlier time".....
Vista:
Type "Restore" into the "start menu search box", select it, and follow the prompts.
Posted on Jun 11, 2009
Printer given barcode missing install new ribbon
There are two styles of P7000 a spool ribbon style and a cartridge ribbon style. You are getting a barcode error then your printer is looking for a ribbon spool not a ribbon cartridge.
Cartridge Ribbon:
PRINTRONIX 255048 402 P7000 EXT LIFE CARTRIDGE RIBBON New
Spool Ribbon:
PRINTRONIX 179499 001 ULTRA CAPACITY RIBBON 6 PACK New
Jan 03, 2016 | Printronix Office Equipment & Supplies
Tip
How to clear printer not spooling error on windows xp system.
this error comes in many terms on the monitor screen as such
" printer spooling error"
" printer not spooling"
" printer spooling service"
if any of such message shows up on your monitor on windows xp operating system.
to make spooling work its necessary to make it work
this is the procedure .if you do this it will work properly. till it is not done it will just ignore printing
1)click the start in the left side of your computer screen
2)go to control panel
3)click performance and maintenance
4)click system
5)click data execution prevention
6)turn on DEP for essential windows program and services only.
7)click the spooling services a tick mark sign will appear beside that means it has enabled.
now your printer will work properly.
on Dec 02, 2009 | Office Equipment & Supplies
Printer spooler
If you are receiving SPOOL.SVC or PRINT SPOOLER ERRORS when trying to uninstall/reinstall your printer, or when trying to print a document or access the printer properties, please follow the steps below.
The following are examples of some of the messages you may be receiving:
Spool.svc is not running. Make the service active and try again.
Printer Properties cannot be displayed. The print spooler service is not running.
Printer cannot be removed. The print spooler service is not running.
Windows cannot print due to a problem with the current printer setup.
(When clicking Add Printer) Operation could not be completed.
NOTE: Only these types of errors warrant the troubleshooting steps clearly defined below.
Resolution:
SPOOL.SVC is an operating system function which carries files through the operating system for printing. It must be STARTED (active) to be able to print or access any printer's functions. This file usually starts automatically with Windows, however operating system issues may cause it to become stopped. You cannot uninstall or reinstall a driver while this service is stopped.
Please try the following to start the service again:
1) Click on START, right click MY COMPUTER, left click MANAGE.
2) On the left column, double-left click SERVICES AND APPLICATIONS, then click SERVICES.
3) Locate and highlight the PRINT SPOOLER on the list of Services.
4) Click START THE SERVICE.
If errors occur and the service cannot be started, there is another issue within the operating system itself.
Mar 13, 2011 | Canon Office Equipment & Supplies
Changing paper on HP Designjet 5500 Plotter
Step 1. Install a roll of paper on the spool, and install the spool on the printer. The fixed end of the spool should be on your right side as you face the printer. The paper should come off the top of the roll.
step 2. open the window and support it with the built in support. Lift the blue handle, located just to the right and above the spool adjacent to the black roller.
Step 3 Pull out about a yard of paper and feed it in front of the black roller and in back into the printer. You really don't need to be precise, the path will accept the paper. Keep pushing the paper until it comes up the the top, then pull the paper from the top.
Step 4 If the edge of the paper is cut square just line it up with the front edge of the printer and on the right there is a blue edge guide mark. If the paper has not been cut square then pull it out far enough that it reaches the spool and line the left and right edges up with the roll and also the blue line.
step 5 Lower the window and the handle. The printer will attempt to install the paper. Respond to the questions that appear on the screen and you should be good to go.
I can walk you through it by phone if you need more help.
Jan 28, 2009 | HP Designjet 5500 (42 in.) InkJet Printer
Print Sooler not installed
HI
Resolution:
Nov 08, 2008 | Dell Inkjet 720 Printer
Cannot access scan function
Hi , did you try a manual copy thru the printer operator panel to make sure that there are no issues with the hardware , if it is copying manually then its an issue with the software , you need to uninstall the printer drivers through the Printer Disk ****make sure to disconnect the printer cable from the computer before uninstalling the drivers **** once the printer drivers are uninstalled restart the computer and get into the Safemode (**keep tabbing F8 when the system restarts for safemode**) and delete the following Folder " SPOOL " it is located under C:\WINDOWS\system32. after deleting the Spool folder restart the computer and install a fresh copy of drivers it will resolve your issue.
Do let me know once you perfrom these steps.
All the Best.
Jul 10, 2008 | Dell 922 All-In-One InkJet Printer
SPOOLER SERVICE IS NOT RUNNING
Resolution:
Pls Rate as Fixya if this helps, Thanks!!
Jun 26, 2008 | Dell A940 All-In-One InkJet Printer
Printing Error
Try this:
1. Power off the printer
2. After re-boot: click start, control panel, printers & faxes and delete the printer.
3. Re-install the printer with the original driver disc.
There are many suggested solutions to spool problems but try this first. If this does not work we'll go to the other solutions.
Mar 30, 2008 | HP Compaq Presario SR1300NX (PP195AA) PC...
Printer does not print
I think trying the solution i gave on this post should solve your problem also http://www.fixya.com/support/t122427-printer_printing_wierd_things_not
Nov 11, 2006 | HP DeskJet 722c InkJet Printer
Brother MFC 7420 All-In-One Laser Printer Logo
159 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
