Question about Toshiba Satellite M35X-S163 Notebook
Toshiba laptop wont boot up
Ok i have had this m35x-s163 since new in 05 it has been very good.The other night it was working fine the next morning it would not boot.When i turn it on i can hear the heat fan run for about a second then stop and no noise at all.The blue power light just stays on until i remove the battery.All the power indicators in front are still working.The screen stays black has no picture on the lcd or the external output.I have removed the harddrive and checked it out on my pc and all is still in tact.This leads me to believe the motherboard or the cpu.I hate to get rid of this puter since i just put a new screen in it a few months ago and also got a brand new battery recently too.
  • 1 more comment
  • blizzted71 Mar 27, 2008
    OK chat i dont have a volt meter here but i did remove the battery and try to boot up only using the plug.The same thing happened the heat fan ran for a few seconds then stopped the blue power light comes on and stays on i have to unplug to turn off.All the power leds on the front are working fine when i plug it in and when i turn it on but after the no boot
  • James Lucas Apr 06, 2008
    Toshiba Laptop will not boot-up. fan start for a second and stop
    I removed the battery and used power cord and results were the same.
    Battery alone lapot is completely dead.
  • welton May 04, 2008
    ok i have a toshiba m35x and when i turn it on all that happens is that the fan run for 5 sec and stop nothing on screen are external moniter i realized that a lot of people online having the same problem please can anyone that have the same prob that had it fix please send me the reason why this iss happening and ddhow to correct itthanks
  • 20 Answers
It sounds more like your power supply isn't charging the battery.
I would first check to see if the power supply is working properly (you can do this with a regular volt/amp meter, or by taking to your local electronic repair shop). If the power supply turns out to be ok, then next have your battery tested, even new batteries sometimes go dud.
These are both inexpensive (if not free) things to check before you just throw it away or get into a motherboard/processor.
Let me know if this works or not.
Posted on Mar 27, 2008
  • 3 Answers
I am trying to fix a M35 and it has the same problem, only if you take the power cord and adjust it just right. The laptop will stay running. It may have a loose connection on the motherboard.
Posted on Jul 03, 2008
Missing windows 7 drivers?
FREE - http://www.csd.toshiba.com/cgi-bin/tais/support/jsp/modelContent.jsp?ct=SB&os=&category=&moid=1039005&rpn=PSA72U&modelFilter=M35X-S163&selCategory=2756709&selFamily=1073768663
BRITISH $9.95 http://www.user-guides.co.uk/os/Toshiba-Satellite-M35X-S163/#ToshibaSatellite-M35X-S163win7driverdisk
Sep 20, 2012 | Toshiba Satellite M35X-S163 Notebook
I have a Toshiba-M35X-S163 lapyop which worked fine for years, now when I try to boot up, the hdd light comes on, the fan turns on, but after 2-3 seconds, the computer shuts down. The battery, power supply...
Hi having hard time with your Toshiba laptop conserning your HD.
let me help you.... First wile you turn on your laptop press and old F8 Key then on the screen choose safe mode that will start your laptop on safe mode., to perform a disk cleanup... Also check your bios battery see if it dead.. again you re start your laptop this time you press and hold F1 or F2 key that bring you on the bios of your laptop., now look carefully in your bios .. press on default setup that will reset your bios for now.. then restart your laptop
then at the begining it will ask you wich mode you want ...then chose last good start.. If that solution dont work ..Then you may have to re install your windows again in your laptop, due to missing file in your startup windows., To install a new window,, again.. insert a valid windows with a serial key into your laptop.. wile your start your laptop press and hold F12 then wait for instruction...
good luck
Oct 20, 2010 | Toshiba Satellite M35X-S163 Notebook
I have Toshiba satellite M35X-S163 when press power cpu fan start and hdd run for 2-3 seconds then gose off nothing on the screen internal or external ; in addition no battary charging . battary and the...
in the pic that is not m35x that is m30 ... if u have m35x ...and no display open the laptop near the power jack there is maxiam ic ... jsut heat that ic.. hope that will work .. if not let me know thanks
Oct 08, 2010 | Toshiba Satellite M35X-S163 Notebook
I cant find audio driver for m35x-s163
http://www.drivershq.com/Drivers/TOSHIBA/SATELLITE/M35X-S163/4183/9941/10772/44239/ModelDrivers.aspx
Aug 23, 2010 | Toshiba Satellite M35X-S163 Notebook
My usb flashdrive is not recognized on any of my usb ports on my Toshiba satellite m35x-s163, can you help?
Test usb port with another device,
check in my computer for the drive,
Test usb flash in another Pc,
Manufacturers website for a possible driver.
if still not working then it's faulty,
Regards
Rpf
Apr 14, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba m35x-s163 will not boot
Hi there, you will need to go into the BIOS page (usually the Del key or an Function (F) key at the Toshiba logo). You will need to change the boot order from network/lan to the Hard Drive. Its pretty straight forward mate.
Cheers
Chris
Apr 04, 2009 | Toshiba Satellite M35X-S163 Notebook
Is the cpu in a toshiba satelitte m35x-s163 laptop upgradeable ?
hi
You need to check if the model of your motherboard and the specs, that will tell you if you can.
Good Luck
Mar 27, 2009 | Toshiba Satellite M35X-S163 Notebook
Toshiba Satellite M35X-S163 wont start
send me ur email and I'll send u software to repair hard disk.
it seems your hd has bad sectors.try to install new copy first(xp)may give you more insight.
many reasons for no screen from worse case scenario proccessor fried to damaged hd.
Feb 03, 2009 | Toshiba Satellite M35X-S163 Notebook
Frozen Computer
If you know some one with a xp disk you can use it as a tool to boot up. Once it is booted up it will write a log file and it should work
Jan 12, 2008 | Toshiba Satellite M35X-S163 Notebook
No backlighting
You need to repalce the backlight/Screen altogether, or have someone do it for you. If the backlight has cracked then no amount of reconnecting will get it to work. Try one of the many Laptop repairers online to get a quote
Dec 28, 2006 | Toshiba Satellite M35X-S163 Notebook
Toshiba Satellite M35X-S163 Notebook Logo
180 people viewed this question
Top Toshiba Computers & Internet Experts
pankaj rautela
pankaj rautela
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
