Question about Mag Innovision LT776s 17" LCD Monitor
Sound There are what seem to be speakers on the front, bottom portion of my monitor. However, I have no idea how to make them work. Can't find a manual...Know computer basics only...Two cords...One to the outlet...One to the computer...No sound! HELP! Thanks!
  • 286 Answers
Check where the cables go into the back of the monitor.
You will either find a small empty hole for a miniature stereo jack, or you will find a similar plug dangling from the monitor cable where it plugs into the back of your computer.
If it's a newer monitor, the jack will be colour coded green.
If you have just an empty jack hole in the back, you need to get an audio cable (miniature jack on each end)and plug it into both the monitor and the back of the computer. This cable will either be in the monitor box, or available at your local computer store.
If there is a miniature jack dangling off the monitor cable where it plugs into the computer, simply plug it into the back of the computer. You will have to figure out which port it for the speakers, as there can be 2 speaker ports, 1 microphone port and a line in/out port. The jack will fit into any of them. They may be labeled or colour coded. If so, plug into the port that is green, or that has an arrow pointing out, or says speaker. If they're not labeled, you can try them all until you find one that work. This won't damage the computer.
Posted on Mar 27, 2008
No audio. no manual.
how is ur sound output from the computer box is conencted....is there an external speaker thru which u listen sound ?
if so that cable from the sound output slot on the PC need to shift to the monitor speakers thru some cable that goes into the monitor from the CPU box....
Jan 04, 2010 | Computers & Internet
I have a syncmater 2333 HD and after connecting to my pc, i seemed to have lost all sound. when connecting speakers and earphones, there is still no sound. thanks
Did you plug in the audio cable to the back of the computer? If so, this may have disabled the front audio connections (or vise-versa). Try unplugging the audio cable from the computer (that is connected to the monitor) and see if your headphones work. If so, there is the solution to that problem.
Check the audio connection on the back of the monitor and double check that it is plugged into the correct port on the back of the computer. If the monitor has amplified speakers, it would be a good idea to connect to the 'line-out' connector on your computer. This would avoid disabling your front audio panel.
Lastly, check the volume on your monitor's built in speakers. This monitor can double as an LCD television, so it most likely has a separate volume control (that defaults to 0).
Oct 04, 2009 | Samsung SyncMaster 2233BW 22" LCD Monitor
Front drivers door speakers stopped working
IN THE HEAD UNIT CHECK THE PLUG FOR FRONT SPEAKER IT SOUND LIKE LOOSE CONNECTION ON FRONT CHANNEL IN HEAD UNIT OR IF U HAVE AMP CHECK IT
Aug 26, 2009 | Metra Chevy Truck 88 94
I have a Sceptre X7G Komodo II 17" LCD monitor/built-in speakers
You would need to connect the speakers to your computer. There should be a little jack on the back of the monitor marked audio. This will need to be connected to your soundcard jack for front speakers. Once this cable is connected you should have sound from your speakers. Hope this helps.
Aug 15, 2009 | Sceptre X7G Komodo II 17 in. Flat Panel...
No sound from speakers
Ok newer monitors come with a HDMI connector and would need a compatable HDMI video card that has the ability for sound. The older monitors have a 3mm plug like a head phone jack you can plug this directly into the GREEN portion of the sound card that is installed in your system!
Thanks please rate
May 02, 2009 | HP Compaq W17q Monitor
I have acer al1917w A monitor but no sound
There is no sound driver, they are speakers, they work off of the audio output jack on the back of your PC, on the motherboard. If you have the sound drivers installed for the motherboard, and no sound, then you have plugged the monitor audio cable into the wrong jack on the PC, or you have the settings wrong just as MIKE said above.
Jan 09, 2009 | Acer AL1917W LCD Monitor
RELISYS MONITOR How do I get the speakers to work please ?
Hey...Dude,
To check if there a built-in speakers... look under the monitor and look for a audio jack usually located next to the VGA and power connections. If you got one, then you need a audio cable to connected to from your monitor to your pc audio output jack.
Nov 21, 2008 | Computers & Internet
Powerpoint 2007 get sound from one monitor to another
Some monitors have speakers built-in, some don't. The sound never travels through the 15pin d-type VGA connector. If the monitor has sound, there will be a small 1/8 inch stereo jack in the back or bottom of the monitor. Most all laptops have a headphone output jack (again 1/8 inch stereo) which is perfect for patching to external amplified speakers or to a monitor with speakers built-in. This patch cable can be purchased at Radio Shack, Best Buy, etc etc.
Oct 25, 2008 | Toshiba Satellite A135-S4527 Notebook
Liquid Video monitor - no sound
I have no solutions, but I'd love to hear from someone who knows what to do...I have the same problem...only my speakers on my monitor USED to work. I moved and now that I've set it back up, there's no volume. I wonder if I am missing some kind of audio wire and if so, where I can get it from.
Dec 18, 2006 | Liquid Video E15LCD1 15"
Pc hook-up/sound issues
on the bottom of the monitor there is a audio input. you must connect you pc output(green) to the monitor input with a male to male audio cord. you can also use a rca cord with two adapters.
Oct 24, 2006 | ViewSonic N2750w 27 in. HD-Ready LCD...
Mag Innovision LT776s 17" LCD Monitor Logo
91 people viewed this question
Top Mag Innovision Computers & Internet Experts
William Miller
William Miller
Rommel Balcita
Tony
Are you a Mag Innovision Computer and Internet Expert? Answer questions, earn points and help others
