Question about Craftsman 675 Torque 190cc 21" RearBag Push Lawn Mower ()
Mower's engine seems like it's missing, and is not running as strongly as it was. White smoke is belching from exhaust. I cleaned the spark plug and have always used Stabil in fuel. Oil level is good.
    Novelist:
  • 152 Answers
May be you to clean/replace air filter.
Posted on Jun 09, 2010
Husquavarna 150 mower,. Seemed to flooding,. Pulled plug,. wet,. Checked for spark Put back in after cranking motor to dry out.,. Same result,. . Is the timing possibly off? Used either once too
assume is a 4 stroke engine
what size engine is fitted
pull cord or electric starter ?
any smoke at all out the exhaust
or a popping when trying to start ?
spark plug has spark so assume coil ok
possibles
clogged air filter
carby flooding clean or adjustment required
valve clearance adjustment .....check
Jun 23, 2016 | Cars & Trucks
What would cause 19 horse kohler in cub cadet to belch white smoke
answered already look at charles beach answers mower belched white smoke
Sep 02, 2014 | Cub Cadet 42 in. 19 HP Kohler Courage...
Mower will start but runs rough & stops
Is the carb flooding?is there black smoke coming from exhaust when running, if so it could be the carb over filling with fuel. Is there petrol leaking out of the carb? If not check the fuel pipe is in good condition
Jul 22, 2013 | Briggs & Stratton Lawn-Boy Insight Series...
Exhaust smells like coolant
That's the symptom of a leaking head gasket. Is your coolant level low?
Jul 19, 2017 | 2002 Suzuki Vitara
Craftsman lawn tractor 42in w/briggs 22hp -low power up hill and cutting
white smoke is more than likely a water issue. Oil usually has a bluish tinge to it but is some cases, it could be white. Drain the gas a fill with fresh to try and eliminate the possibility of water in the gas. Watch the oil level to see if it changes after using the mower. it may take a few times but if it is burning oil, the spark plug will look "wet" and oil soaked, with possible black soot type build up.
Aug 13, 2017 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a briggs and stratton ride on lawn mower 14hp model 287707. engine pumping oil through breather into carburettor when running, its working but burning oil.
The float is getting stuck open which will cause the engine/sump to fill with oil and thats why you see oil comming out carby/air filter clean ya plug drain your sump turn motor over with plug out a few time to clean out check float/needle and seat in carby refil oil clean ya spark plug and off you go it will blow heaps of white smoke don't worry it is just buring th oil out if the exhaust/engine hope this helps some one
Mar 26, 2010 | Poulan 38-Inch Steel Deck 15.5 HP Briggs &...
My Toyota Corolla XL 1996 model is belching heavy white smoke. I have just changed the oil and also the spark plug. What do you think is the problem?
white smoke usually indicates the engine is burning oil or its burning coolant. when the engine is cold remove the radiator cap and start the vehicle, if it immediately begins to blow air and or coolant from the radiator you most likely have a blown head gasket, if not then remove the oil cap and feel for air coming out. if it blows kinda like a hair dryer then you most likely have a piston ring issue and you are burning oil. either way you may be looking at major surgery to repair.
Dec 10, 2009 | 1996 Toyota Corolla
My power mower blows white smoke out the exhaust. It seems to run ok, but there's a little falter in its idle periodically.
its most likely just unburned gas. try changing the spark plug and air filter.
Jun 05, 2009 | Garden
Saab 9-3 (2000) misses and white smoke from exhaust
check spark plug wire they may been put back
in the wrong firing order
Apr 08, 2009 | Saab 9 3 Cars & Trucks
Craftsman 675 Torque 190cc 21" RearBag Push Lawn Mower () Logo
544 people viewed this question
Top Craftsman Garden Experts
Wade Mobley
Wade Mobley
Jim Parker
Jim Parker
Dennis Key
Dennis Key
Are you a Craftsman Garden Expert? Answer questions, earn points and help others
