Question about Vidal Sassoon VSCL828 Hair Trimmer
Hey, my clippers vibrating extra hard, what's wrong with it?
    Problem Solver:
  • 6 Answers
I had the same problem with a pair of Wahls (professional use). I had broken a small bit of plastic on which the two metal blades sat against. The Shaver Shoppe were able to fix mine for me at a very reasonable price.
Posted on Aug 13, 2010
How do I get my clippers to cut?
Try giving the blade an extra 1/2 a turn of tension, done by turning the red knob 1/2 a turn clockwise. It sounds as though the blades are jamming up which could be a lack of tension.
May 01, 2014 | Andis 68035 Progress Cattle And Horse Hair...
What's the role of the "power screw" ????
To adjust clipper/trimmers to run to their voltage needs. If clipper/trimmer rattles or over vibrates it may need adjustment to the line voltage in your area. Before adjusting, make sure the clipper/trimmer is clean and blade is oiled. Then turn the SMALL power screw clockwise on the side of the clipper until the noise disappears.
Mar 14, 2011 | Andis 01690 Hair Trimmer
I have oster 6550 series a clippers, i installed new blades but they hardly clip any hair, when I loosen the tension the blades "move quicker" but vibrate with a loud noise
the tension should be pre set from the factory, if its more than one blade your having problems with then its likely there is a problem with the clippers.
Mar 04, 2011 | Oster Golden A5 2-Speed Universal Motor...
How to position the clipper blade while u sharpening?
Hi!
I'm not sure about the nature of you question. Firstly if you mean, position the comb (with the adjusting lever on your clipper because your blades wont work, then:)
1.
If you move the comb downwards using the lever on the side of your clipper you will get a shorter cut, if you move it forward you will get a slightly longer cut. If your clipper makes a horrible noise, I believe there is a plastic adjuster on the side that you adjust with a flat head screwdriver. This adjusts the springs inside the clipper which effects how central the cutter moves from side to side. Adjust this while the clipper is running. You want your blades to be as central as posssible. If they still do not work, you may need your blades sharpened. This costs £5.90 incl. VAT & Postage www.sheareaseltd.com You could send your clipper to them as well and ask them to re align your blades after sharpening and they'll just charge the extra postage. (extra £5)
Hope this helps!
2.
If you mean how to hold the clipper with the blade relative to what you are clipping. You need to hold the clipper so the teeth are not pointing into your project, but not pointing away from it either. Keep the comb parallel to your project. With human hair, cut against the grain, with an animal cut with the grain!
Hope This Helps!
Jun 18, 2010 | Wahl Magic Clip Clippers Hair Trimmer
Oster clippers model 274-69 seems to be frozen...
need oil internally gears etc... will fix problem (dry)
Dec 05, 2009 | Oster 76076-010 Hair Trimmer
Oster Golden A5 Clippers will not cut
If the clippers are new, it is not likely that the problem is internal. Sometimes, when the blade is put on the clipper, it needs an extra little push to clip firmly behind the blade catch (you can hear a little click). Try that.
Aug 23, 2009 | Oster Golden A5 1-Speed Universal Motor...
Loud buzzing on Wahl "Designer" model clippers
There is a "power screw" located on the side of the clipper opposite the switch. This may need adjusting. Take a screw driver or coin....and with the unit running......turn the screw back and forth until the clipper stops making noise. The proper position for the most power is to turn the screw intil it makes a loud noise, then turn it back just enough to get rid of it.
Jul 03, 2009 | Wahl Designer 6 (8355100)
Can get it right
Jun 11, 2009 | Oster Golden A5 2-Speed Universal Motor...
Innovage benfini salons professional style clippers
Return it back to store as fast as you can, show these complaints and request an immediate refund from a seller.
Jul 11, 2008 | Health & Beauty
Vidal Sassoon VSCL828 Hair Trimmer Logo
285 people viewed this question
Top Vidal Sassoon Health & Beauty Experts
Anglia Clipper...
jasiel murphy
Jerry Greenberg
Jerry Greenberg
Are you a Vidal Sassoon Health and Beauty Expert? Answer questions, earn points and help others
