Repair parts likha how you doing. my question is about the horizontal out put for my rca truflat tv do you know where i could get this part and if is hard to change god i miss my tele  I'm maintenance technician do you thing i could do it  please let me know  greetings
  • 790 Answers
Hi
can you explain exactly what is the problem of your tv! and i can give you an repair advice!
Thanks!
Posted on Jun 22, 2008
TruFlat Tv turns on then off
Hello
Check the supply rail to LOT. If LOT [Line Output Transformer] is fauty, it will take tremendous current from the SMPS power supply output, and the overload sensor circuit will be energiised and the supply to the whole system will sut OFF. That is happening eith your TV now. Just desolder out the horizontal output transistor, the transistor that drives the LOT, and switch the set ON, and see whether it stays on or not. If stays on, check the collector to emitor resistoance of the horizontal output transistor. If there is any short with it, replace it and switch ON the set for a short time, say 5 seconds or so, and check whther the replaced transistor gets overheated. If it overheats, make sure that the LOT said above has damaged, and must be replaced with same type and number. If the fault is with the horizontal out put transistor, the set will work normally after replacing it.
The components can be bought from local electronic spare part shops at your town. OK.
Oct 24, 2011 | RCA TruFlat 27F520T 27" TV
The screen only shows the bottom half of the picture. I have a RCA TruFlat 27" TV and it has a horizontal line in the middle & only shows the lower half of the picture. I've smacked it a...
The problem of your tv is only a loosed solder.Remove the back cover of your tv but be sure to unplug it then try to look the solder part of your tv look for some loosed solder then try to resolder it using a soldering iron but be sure not to connect separated pin in the pcb.
Jul 05, 2011 | RCA TruFlat 27F520T 27" TV
On my RCA truflat tv there are solid white horizontal lines going across the top 5 inches of the screen? Do i need to get it repaired or is it a simple problem?
Hello
Your TVs vertical output section has the trouble. Electrolytic capacitors in that section, 8 numbers the most, should be replaced with new capacitors. Iit won't cost more. OK.
Jun 12, 2011 | RCA TruFlat 27F520T 27" TV
My RCA truflat tv won't turn on? It is only like
Could be a fuse in the unit or a bad powersupply i would have a estimate done on it before repair gets started as a newer tv would cost less if this was a major issue.
1. check fuse
2. check power supply unit
If you do not know how to do this would recommend you take it to the experts as there is serious high voltage that can be fatal inside, Please do leave postive feedback and ratings for your free answer today.
Oct 24, 2009 | RCA TruFlat 27F520T 27" TV
Wavy horizontal lines on bottom of RCA 36in Truflat TV
The convergance or y-sus board can become faulty. The capcitors do tend to burn out. It is about a $250 + repair for this. Not all parts can be repaired, but they can be replaced. A capacitor tester and multi-meter are about the best tools for the job. If the price you get is over $250, I simply would replace it instead of repairing it..
Sep 13, 2009 | RCA TruFlat 27F520T 27" TV
RCA 27 in has white horizontal line going through the middle
this symptons is caused by a breakdown in the vertical deflection circuit. hence, the trouble may be in the vertical oscillator, amplifier or output circuit. in most modern tv the vertical ic is usually composed of these said circuit inside. the ic have many pins, standing on a heat sink and smaller in size. try to check also the capacitors surrounding it. sometimes leaky capacitor may cause this problem. good luck!
Aug 16, 2009 | RCA TruFlat 27F520T 27" TV
Horizontal lines then picture starts to fade
The horizontal/vertical ic inverter is dead.
Needa new one.
Aug 02, 2009 | RCA TruFlat 27F520T 27" TV
Rca truflat 27"
You can take off the back of the tv. Look for the red wire at the top of the tube. Follow it down to the part that it goes into. On that part (transformer) there are 2 controlls. The one marked SCREEN, is the one you can turn up and watch the screen at the same time. If the tv shuts off, put that control back to the original position. If it brings up the brightness, then it is fixed. If not, take to a repair shop.
Jun 13, 2008 | RCA TruFlat 27F520T 27" TV
Unlock rca truflat tv with no remote
Buy a universal remote and program it for the TV. That's the only thing that will work.
Sep 19, 2007 | RCA TruFlat 27F520T 27" TV
Televison & Video Logo
54 people viewed this question
Top Televison & Video Experts
