Question about Dell Inspiron 1501 Notebook
LINES ON SCREEN
HOW TO REMOVE 3 VERTICAL LINES ON SCREEN?
    Problem Solver:
  • 14 Answers
IS IT PERMANENT WHILE YOU ARE WORKING IN ANY APPLICATION, ONLY DESKTOP, OR ANYTHING, THEN IT IS PHYSICAL PROBLEM IN LCD SCREEN OF LAPTOP.
IF IT IS IN WARRANTY PERIOD, TAKE IT TO IT'S AUTHORIZED SERVICE STATION TO GET REPAIRED FREE !!!
OTHERWISE GET IT REPAIRED BY PAYING SERVICE CHARGE. IT WIIL COST YOU $50-$100.
Posted on May 06, 2010
Testimonial: "thank you"
Why are there vertical colored lines all over screen?
Thin vertical lines cover screen on Samsung LCD - AVS Forum ' Home ...
www.avsforum.com/...lcd-flat-panel.../1127410-thin-vertical-lines-cover...
Mar 7, 2009 - 30 posts - ‎25 authors
I have read there could be ribbon cable connection issues so I plan to .... I have a VizioVW22LHD TV,I hooked it up using a HDMI cable to my Toshiba satellite laptop. ... If you have thin multi-colored vertical lines on your tv panel, that do ... my TV on the thin vertical lines come all over the screen and the TV ... my VIZIO E470i-A0 LED has vertical colored lines on ...
Nov 18, 2013
Vizio SV370XVT lines throughout entire display. Not ...
Aug 3, 2012
Thin vertical line on LCD tv
Dec 29, 2007
More results from www.avsforum.com
Vizio P50HDTV Display Problems - Colored Vertical Lines .
Dec 30, 2015 | Vizio Televison & Video
How to fix LG TV Vertical lines.
If you wish to get some details; check the site linked here. Pull up older posts. Surf the site with patience. http://electronicshelponline.blogspot.com/
Line, faults & possible causes to LCD screen are given with illustrations. You can get an idea about the fault to an extent.
Nov 30, 2015 | LG 47LA6200 47" 1080p 3D Smart TV 120Hz...
Green vertical lines across screen
It will be best to contact the authorized service center for Samsung in this case. They only can provide the component.
Nov 30, 2013 | Samsung LN-S4695D 46 in. LCD HDTV
My compaq presario m2000 lcd screen have vertical lines in different colors, how can i remove this vertical lines?
Take out battery from laptop and disconnect power cable. Keep the power button pressed for 30 seconds and then plug the power cable. This will remove static charge from laptop and should resolve the display issue,
Nov 20, 2011 | Compaq Presario M2000 Notebook
Lcd screen has lines in the middle area (3" wide
Laptop screen display problems occur for many different reasons. Some issues need professional attention, but others can be repaired by the owner. A screen that displays vertical lines often means that there is a problem with the video cable connection to the LCD screen, or the cable itself. In order to repair this problem, the display screen must be disassembled. If you feel confident that this task is within your realm of expertise, follow the steps below to remove your laptop's LCD panel and fix the vertical line problem on your laptop screen.
1. Remove the rubber seals covering the screws on your screen's outer frame using a flat-head screwdriver. Remove the screws, then carefully pry the frame from the screen using your fingers. Release the plastic latches holding the framing in place, then remove.
2. Remove the screws holding the screen to the support brackets. You will see the video cable, which is attached to the back of the LCD screen. Try unplugging and reconnecting this cable, making sure that it is seated properly. If the problem was the connection, this may solve the vertical line issue.
3. Turn on the laptop. Move the video cable around a bit, without moving or touching the screen. Check the screen to see if the display image changes at all. If it does, the problem may be with the cable itself.
4. Move the laptop screen around to see if this affects the display. If so, the problem is most likely with the LCD screen itself, not the video cable. Replacing the screen will be necessary.
I hope you find it very helpful. Best regards.
Aug 17, 2011 | Acer Computers & Internet
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Yamaha YPG625 screen shows only vertical lines
I brought the keyboard into a local service technician. He told me that he had to remove about 50 screws but the solution was simple. He unplugged and reconnected the ribbon connector. It apparently was not making good contact.
Oct 02, 2008 | Yamaha Full-Size Keyboard
Ep716 has vertical line
IF THERE IS WHITE VERTICAL LINES IN YOUR PROJECTION THEN REMOVE THE MOTHER BOARD AND REFIT THE BOARD OR U CAN JUST PRESS IT FROM UPPERSIDE THE PROBLEM WILL SOLVE OUT
CHINTAN.A.SHAH
INDIA
Jul 23, 2008 | Optoma EP716 Multimedia Projector
Vertical lines in screen
Are the Lines Symetrical in distance and space? Makes a diferernce..
Jan 21, 2008 | Sony BRAVIA KDL-46S2000 46 in. LCD HDTV
Dell Inspiron 1501 Notebook Logo
97 people viewed this question
Alun Cox
