Question about Sharp Model: KB6025MK Microwave Oven
Model 26961 rated 13 amps. about how many watts would that equal?
I need to know how many watts of power of my sharp model 26961 is?
    Sniper:
  • 92 Answers
The unit has a rating usually on the inside label ior the door somewhere...
you know the voltage allready... 120... multiply the 13 amps x the voltage... and presto 1560...
you can multiply that by .707 and get the RMS value... 1102
so I consider the microwave to be a 1000Watt unit... pretty easy... bu8t you wonder where did I get the numbers... like .707...
It's to compensate the peak to thr RMS... root mean square... lets just call it "Average"
Posted on May 06, 2010
Microwave arching
faulty microwave module replace it
Apr 22, 2015 | Sharp R530EWT Countertop Microwave Oven...
My microwave is 25 years old, will it be working to maximum efficiency
If all the settings work and the door closes ok . why throw it out ?. It may not be quite as efficient power wise as a brand new one. the few cents extra to run it against the price of a new one, I would stay with old faithful.
Dec 31, 2014 | Sharp R530EWT Countertop Microwave Oven...
Sharp Carousel R530BK microwave won't cook unless light pressure is kept on the door button.
There are door switches and one of them is evidently out of adjustment or the little actuator arm on it is.
Nov 27, 2013 | Sharp R530EWT Countertop Microwave Oven...
On model mw8626w can i use it in my semi with a 1000 watt inverter?
Take a look at the oven's electric rating information. It should be on the label with the model and serial number, and it will tell you how many amps the oven needs. Power in watts is volts times amps, so a 1000-watt inverter is good for about 8 amps at 120 volts output. Some inverters also use a peak rating, meaning power than can be delivered for a short time. The continuous power may be less than that; you'll need to look at the inverter. As long as the power needed by the oven is within the inverter's ratings then you'll be able to use it. Otherwise you'll need to shop for one with more output power.
Jul 15, 2011 | Emerson MW8626W Microwave Oven
What is the wattage of model R-9H84B
That model had 900 watts of microwave power output, and the convection outpout was 1450 watts.
Jun 18, 2011 | Sharp R-9H84B Microwave Oven
I have a Sharp model R-3A52,old but still cooks well. How do I know how many watts it is? I need to know how many watts my oven is?
The power of the magnatron should be on the door it will be about 750 watts. You could check sharp website to get it spot on...
Apr 06, 2010 | Sharp R-1470 Microwave Oven
Microwave oven JVM1650SH01
I'm not finding it in the owner's manual, but there is a tag inside the cavity which should tell you either how many amps it requires or how many input watts it consumes.
If it gives you power in watts, just divide: #watts / 120V = current in amps.
If that tag doesn't tell you, maybe one on the back of the unit will.
It will probably be 13-18 amps, depending on whether its power output is 950 watts or 1200 watts.
There should be a "mini-manual" (tech sheet) hidden inside the unit behind the control panel or hidden on the left side behind the grille, which is very helpful when troubleshooting, testing, and locating components.
d:%5cele%5crepair%5cmicrowave%5cge_hotpoint%5cmini_manual_behind_grille_small.jpgdee77f7.jpg
At our Web site, we have a video available showing how to remove a typical over the range control panel assembly in under 5 minutes.
On that mini-manual, there should be a troubleshooting flowchart, and it will have a few different current measurement values on it. You should be able to decipher the normal draw from that.
If you're just trying to figure out how many amps the breaker should be on the microwave's power line, figure 15A for an oven rated at less than about 1000 watts output power, and 20A for an oven rated at over 1000W.
NOTE: The FixYa system is not currently notifying me when folks reply to my posts, so please contact me directly with your brand, model and symptoms for more FREE help & do-it-yourself advice.
Please include this URL, too:
http://www.fixya.com/support/t2931401-microwave_oven_jvm1650sh01
William E. Miller
prototech@usa.net
http://www.microwavedisplay.com
Sep 12, 2009 | GE Spacemaker JVM1640SJ Microwave Oven
Power level
The numbers DO NOT equal a certain power level Erin. They equal a percentage! This is very confusing. Even the factory reps. can't explain it adequately. I recently replaced my old 600 watt oven with a GE 1100 watt model. The 600 watt unit came with a great cookbook. (I searched the internet but couldn't find one for the GE oven and the factory was no help!) A chicken recipe in the 600 cookbook said cook on high for 30 minutes. Since 600 is approx. half of 1100, I cooked on high for 15 minutes. Result: Uncooked chicken...
The next time I cooked 30 minutes on 50% power (button 5) and It came out OK. I have since used 50% power with meats in cooking bags with good results. Remember to check for correct temp. with a meat thermometer when oven stops. Trial and error is your best test at this point I'm afraid. Also you may want to type "Microwave Conversion Chart" into your browser. You will get some additional information from this. But read carefully!
Ray
Nov 16, 2008 | GE XL1800 1100 Watts Microwave Oven
Amps for microwave
That should be stated on the model number tag.
If not, a typical 1000W microwave will draw 13-15 amps from a 110/120V line.
Model MW8104SS draws right at 13 amps, according to the owner's manual.
While that model is not available, you can download similar models' manuals here: http://www.emersonradio.com/owners/MWO%20manual/
We're happy to help and we appreciate your thoughtful rating of our answer.
Dec 26, 2007 | Emerson MW8107WA Microwave Oven
Sharp Model: KB6025MK Microwave Oven Logo
56 people viewed this question
Top Sharp Microwave Ovens Experts
William Miller
William Miller
Devabhakthuni...
Devabhakthuni...
Are you a Sharp Microwave Oven Expert? Answer questions, earn points and help others
