I have a 42 vizio plasma tv only 3 years old but some times it makes a hummmmm sound when i watch a movie or just tv, i do not have cable or game systms on the tv justb a cheep antenna, this has never done it befor, i called a sevice guy thay said its going to pop meaing its no good no more and i would have to get a new tv ????
  • 1 more comment
  • dcrazyfeathe May 06, 2010
    I have a 42 vizio plasma tv only 3 years old but some times it makes a hummmmm sound when i watch a movie or just tv, it goes off and on but it drives me crazy what is it and what to do about it. does this happen to tvs and if so why ?? what makes it do this ?
    thank you for your help with this but now it stoped so what does that mean ??
  • dcrazyfeathe May 07, 2010
    so how would i remove them and how would i put the new ones on ??
  • 11,800 Answers
The humming can originate in two parts (both caused by drying capacitors):
1 - the audio final amplifier autooscillates - definitely not terminal, actually quite easy to repair; easy to identify - the humming dissapears if you put the volume at 0.
2 - the power source is malfunctioning - this is serious, left unfixed it can destroy the tv; but it can be fixed, all you need is a better service guy.
In desperation you can try to fix it yourself. Open the back case and look for deformed/bulging capacitors and replace them. Also look for darkened part on the motherboard, it's a sign that there is a stressed part so test it and replace it if necessary.
Luckily this is only the beginning of the problem, fixing it now will be a lot cheaper than after failure.
Posted on May 06, 2010
  • Azrael SRL May 06, 2010
    A capacitor is nothing more than a damp piece of fine paper in between two fine foils of aluminium. When the paper dries it insulates less so a part of the current is flowing thru it. This extra current makes the power source work harder hence the buzzing.  That extra current flowing thru the capacitor also makes the water decompose thru electrolysis, accelerating the drying. The gases, especially hydrogen, are a good isolator so when they are generated in large quantities they raise the insulating properties of the paper so the current flowing thru the capacitor goes down to a lower level putting less strain on the power source so the noise dissapears. But gases escape and the entire process begins again.
    Find the failing capacitors and replace them now, while they are cheap, when they will fail they are going to take other parts with them and you'll end up with a hefty bill .
  • Azrael SRL May 07, 2010
    They are soldered on the board. But since you have asked that you clearly don't have the experience needed to work on them. Ask a friend with at least a basic experience in electronics to help you, you can damage more it you don't really know what you're doing.
  • 712 Answers
It is not that serious problem. If the problem started only a while ago, your t.v can easily be used for some more YEARS. But this sound will persist. There is no need of repair and replacement now if you are okay with that sound. I don't think you will appreciate a repair as it may be expensive. I assure you that you can use the t.v at least a couple of years more, if the sound is not that severe.
I have an element 42" plasma, we were watching a
staceydesjar
Try unplugging the receiver from your electrical outlet for 10 seconds and plug back in. This will cause the receiver to reboot and re-acquire the satellite signal. After this, you should get your picture back. I hope this helps.
Ray Calo
DISH Network
Dec 30, 2010 | Element Electronics PLX4202B 42 in. Plasma...
Vizio 42 LCD... Roughly 3 1/2 years old, Watching TV and it goes black and no sound as well. Have to turn off by unplugging. Did test through surround sound system and signal was still going to the...
After 3 years, more likely to have power supply problem just like the rest of all the LCD TV and LCD monitors out there.
See my photo albums.
If you are going to DIY and have proper tools, electronics knowledge, and know safety precaution then please read on:
Please see my basic troubleshooting guide here:
http://www.fixya.com/support/r5093881-lcd_flat_panel_tv_troubleshooting_guide
http://s807.photobucket.com/home/budm/allalbums
http://en.wikipedia.org/wiki/Capacitor_plague
Aug 21, 2010 | Vizio VW42LF 42 in. LCD HDTV
I HAVE A VIZIO LCD TV AND WHEN WATCHING ANYTHING THROUGH THE hdmi INPUTS LIKE BLUERAYS THE SOUND GOES STATICY AFTER 30 MINS. AND TO RESET IT I CHANGE THE IMPUT CHANGES THEN BACK AND THEN ITS FIXED. WHAT...
This problem happen to all the HDMI inputs?Only one HDMI input,that one properally is shorted.Might even the HDMI cable is old,and worn out.U have about 6 HDMI inputs on ur tv,rent about 3 DVDs movies and watches test out all ur HDMI ports out.
Mar 25, 2010 | Vizio VW42LF 42 in. LCD HDTV
My Vizio LCD TV screen fades to dark. Sound stays on.
I w having this same issue when watching a Blu-Ray disc. I found it to be dependent upon what picture mode the TV was set to. By this I mean certain picture modes would cause the TV to dim during dark scenes of a movie. Changing the picture mode helped a lot.
Feb 28, 2010 | Vizio VW42LF 42 in. LCD HDTV
Sound but no picture on Vizio WS42L TV
did you ever get it resolve? I am having the same problem. my tv is a year and and 1 week old. I am so upset.
Jul 19, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio problem
Those vizios have problems with certain internal components which often cause the problem that you describe.
It can be repaired for a reasonable cost by a competent technician,
www.mcveyelectronics.com
May 03, 2009 | Vizio P2 42 in. HD-Ready Plasma Television
Vertical lines on screen
1. Frist on the BURN MODE.
2. Check whether same
Vertical lines on screen ?? 3. If yes ..?
4. Then change the LOGIC BOARD or PDP
Jan 11, 2009 | Hitachi 42HDS69 42 in. Plasma Television
Vizio P2 42 in. HDTV-Ready Plasma
Search Google "Screen Burn-In."
Mainly Plasma screens are affected by it.
Sep 20, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Vizio plasma hd 42
Sounds like you hit the PIP (picture in picture) button on the remote. Hit it a few more times and it should go away.
Jun 16, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
Televison & Video Logo
Top Televison & Video Experts
