Question about Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph
I need what the horse power is on krystal clear model 633t filter pump
  • Rich May 11, 2010
    Can you tell me the amperage and voltage rating of the motor from the name plate information? Thanks
MOTORWIZJ
  • 1383 Answers
SOURCE: how many horsepower does the krystal clear model
IF YOU PLAN TO REPLACE THIS PUMP , LOOK FOR A HAYWARD 1/2 HP SUPER PUMP. THERE CHEAP AND TUFF . USE YOUR OLD FILTER.. THAT MOTOR IS AROUND A 1/2 .. LOOK AT THE AMPS IT USES, ITS ON THE MOTOR . SAY 15 AMPS IS A 1HP AT 115 VOLTS
Posted on May 25, 2010
SOURCE: Intex Krystal Clear Filter/Pump Model 635
my intex 635 pump impeller is broken i need a replacement part. i do not have the money for a new pump.
Posted on Jul 15, 2010
jharwell668
  • 640 Answers
SOURCE: Brand new filter pump leaking
If it is brand new and leaking, it sounds like your pool filter has a connection problem. Check your connections to make sure that they are tight and sound and that you do not have any hairline cracks.
Posted on Sep 08, 2010
  • 8404 Answers
SOURCE: how many kilowatts per hour does the Krystal Clear
The simple answer is not many. I don't think your pump is that hungry to use kilowattS per hour... lets see "Kilo" is one thousand. At this site you will find the several formula for getting to your answer. Ohm's Law applies ... http://www.powerstream.com/Amps-Watts.htm
I am presuming your pump is 115 Volts and it probably plugs into a 15 amp circuit. IF IT USES 15 amps (I doubt it uses the entire value) Volts X Amps = Watts or 1725 watts or about 1.7 kilowatt. I couldn't find the amp rating for your particular model pump. I think it probably operates near 6 to 8 amps @ 115 Volts AC. If your pump runs at 6 amps that is 690 watts, 8 is 920 and 10 would be 1150. There are other factors that determine the actual amount of power consumed - load will increase the use - partially clogged filter would be an example of increased load, age of the pump could be another factor.
Here is another nifty place to convert: http://www.supercircuits.com/resources/tools/Volts-Watts-Amps-Converter
Here is a rule of thumb: If a device can run on two different voltages, the higher the voltage, the lower the amps. For example 115 volt @ 12 amps would use 1380 watts. The same device running at 230 volts would run at 6 amps and use 1380. This is the correct math answer. However, in actual use, the device would run slightly more efficient (use fewer watts). Electricians and science teachers and math teachers will all tell you different stories depending on their discipline. Heavy use devices do run more efficiently at the higher voltage (stove, dryer, furnace, hot water heater, well water pumps, swimming pool pumps)(Do not go looking for a 220 Volt pump for your above ground pool in an effort to save money. The higher voltage device will cost more and there are other practical and safety related issues in this kind of installation.)
If you lived in my area, (please don't say where you live) you would pay about 12 cents (US dollars) per kilowatt hour. If your pump runs at 10 amps 115 volts - that would be just over 12 cents per hour to run the pump.
I trust this answers your question? Thank you for your interest in FixYa.com
Posted on Mar 07, 2011
  • 8 Answers
SOURCE: I need to reset the timer on my 633T Krystal Clear
You know the timer can only be programmed once and it is 24 hrs after the last time it ran. So turn it on at the exact time of day you want it to run every day, set the dial to how many hours to run and walk away. It should start up automatically 24 hrs later each and every day (as long as you have the on switch set to the timer position)
Posted on Jul 12, 2011
How much horsepower does my intex Crystal Clear Model 635T filter pump have? I'm looking at a hth vacuum that requires at least 1/2 horse power. thanks
If the unit does not have the horsepower rating, but has the AMP rating, try this formula found in Answers.com
"Amps are a factor in calculating power, and so can be used to determine horsepower, but only when other factors are present.
Given other factors, you can find the horsepower. The easiest way is to determine watts by multiplying amps X volts. Next multiply watts by .00134 and you have horsepower.
If: amps (A)= 20 and volts (V)=120 then
A X V =2400 watts (W)
2400 watts X .00134 = 3.216 horsepower"
Hope this helps you???
Aug 14, 2011 | Intex Krystal Clear Model 635 Pool Filter...
I need to reset the timer on my 633T Krystal Clear pump as we have unplugged the power and we can't get the timer to work.
Jul 12, 2011 | Intex Krystal Clear Model 635 Pool Filter...
24'x52" Pool is 1 week
sounds lik air is trapped or you need a seriious backwashing. If it was running without a basket in the pot by the motor then you could have a clogged impeller. motor runs but not much happens right what is the pressure gauge reading when pool is running?
Jun 30, 2011 | Intex Krystal Clear Model 635 Pool Filter...
Manuel neede for a intex krystal clear pump model 638 with skimmer basket
Below is a copy of the users manual for the krystal clear 635. It should have everything in that you need to set up your pool filter.
http://www.pooltoysource.com/images/pdf/RVR006.pdf
Nov 15, 2010 | Intex Krystal Clear Model 635 Pool Filter...
We purchased the Intex 633T pump. We want to know if this pump can be ran with saltwater pool?
Unless the manual specifically says otherwise there should be no problem. The salt level in salt water pools is very minimal, so it's really no different than using mineral additives. Do pay attention to salt system though as far as using other mineral additives such as copper or silver algaecides as they can damage the salt system.
Sep 19, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Filter/Pump Model 635 replacement parts for the pump
Jun 30, 2010 | Intex Krystal Clear Model 635 Pool Filter...
Intex Krystal Clear Model 635 Pool Filter Pump 1500 Gph Logo
170 people viewed this question
Top Intex Pool & Spa Experts
avionik99
Level 1 Expert
Jay Finke
Jay Finke
Mike
Are you an Intex Pool and Spa Expert? Answer questions, earn points and help others
