Question about Best Data Products Best Data BizView BV200 Graphics Card - ATi RV280 240MHz - 128MB DDR SDRAM - PCI PCI Graphic Card
Help? on my monitor only appears mode not supported when I'm trying to run may online games rohan
    Genius:
  • 1,027 Answers
Two things; one, the display card may not support the modes needed by the game, or (two) you need the latest DirectX version.
Posted on May 07, 2010
Input not supported acer x193w
Hello Shaul
Hints:
1) Change to Plug and Play monitor driver
2) try changing the screen resolution on the PC, and driver.
3) try changing to 60Hz the refresh rate of the monitor on driver section or options on the monitor driver.
Carl
Apr 05, 2016 | Acer X193W LCD Monitor
Graphics problem, internet explorer and online games cannot be open at the same time
How many monitors do you have? some online games needs to be run in full screen mode. If you only have one monitor then you would have to switch between the game and the browser.
You can also try running the game in windowed mode if it has the option so you can see them both.
Hope this helps!
May 19, 2011 | Computers & Internet
Warcraft 3 problem with monitor (turning to sleep mode)
Hello
If only monitors turns off it means that game is in higher resolution than monitor can support.
However, warcraft is preety old game and such things shouldn't happen.
Possible sollutions:
1. Download lastest Video card drivers from producent website
2. Install lastest DirectX
3. If still problem occurs:
Click Start->Run...
enter "regedit" -> press enter
open following directories: HKEY_CURRENT_USER -> Software -> Blizzard Entertainment -> Warcraft III -> Video
doubleclick on "resheight" -> check "decimal" and enter 640, apply with OK
then doubleclick on "reswidth" -> check "decimal" and enter 800, apply with OK
Run game and see if it helped.
Cheers,
Mike
Apr 21, 2010 | Blizzard Entertainment WarCraft III: The...
Acer al1716 monitor input not supported
You get the message because the game try to run at the PC video resolution that you monitor cannot display/support. You need to run your game at native resolution of the monitor.
Mar 25, 2010 | Acer AL1716 17" LCD Monitor
When I start my game, monitor goes black and out of range appears
I suspect the game is trying to run in a resolution that is either not supported by the monitor or your video card. If there is a setup/configuration for the game please run it to choose a different resolution.
You can tell the resolution your are currently running by looking in control panel, display, settings.
Your monitor supports a max resolution of 1280x1024, so if the minimum requirements of the game are higher then the monitor simply will not work with the game. If the monitor meets the requirements then lets look at the max resolution of the video card you are using.
Please let us know if this has solved your problem or if you would like further assistance.
Sep 16, 2009 | ViewSonic VX910 19" LCD Monitor
My viewsonic vx2835wm has developed vertical pixilated lines
First thing you need to do is figure out where the problem is originating from. The monitor or computer?
When the lines appear, try the following:
1. Press the [1] on the monitor to bring up the menu. Do the lines appear on top of the menu?
2. Change the input. Do the lines appear on a different input?
If you answered "yes" to any of the question above, then your unit will need to be serviced.
If you answered "no" then test the monito on a different PC and verify if the problem follows the monitor. Also, try using a different video cable to rule out a bad cable.
Do the lines only appear when you are playing a game? Does it only appear on certain games? What resolution and refresh rate do you run the monitor at?
Jun 22, 2009 | ViewSonic VX2835WM LCD TV
Mode not supported
I have the same problem, but it happens with Battlefield 1942. Yesterday it was running without any problems at all, and today the screen gives the "mode not supported" message.
Jun 20, 2008 | Belinea 19" LCD Monitor
Wavy lines, goes black during video games.
It sounds to me like the monitor's refresh rate is too low to support your current settings, and the demands of the game. Have you tried adjusting the refresh rate? If I'm right, you should be able to fix the wavy lines that way. I'm not sure how much control over the refresh rate the game takes, but if you can fix the wavy lines and the game still doesn't work, I think you're not likely to get the game to work on this monitor.
Aug 28, 2007 | Proview PL926WBi 19" LCD Monitor
Best Data Products Best Data BizView BV200 Graphics Card - ATi RV280 240MHz - 128MB DDR SDRAM - PCI PCI Graphic Card Logo
37 people viewed this question
Top Best Data Products Computers & Internet Experts
David Payne
David Payne
Are you a Best Data Products Computer and Internet Expert? Answer questions, earn points and help others
