FixYa.com
Tags:
Acer Aspire 3000  PC Notebook
Acer aspire keboard replace ment
posted by lee4king on Mar 27, 2008
thank you for your help!
This Problem has been added to the Share Your Expertise Page under "My Work Queue".
Solution #1
posted on May 14, 2008
Not Rated (0)
rickatnight1
Rank:Guru Guru
Rating: 85%, 40 votes
What is your question? Do you want to know how to replace the keyboard or where to find a replacement keyboard?
This disassembly guide might help you out: http://www.eserviceinfo.com/download.php?fileid=16546 but the pictures are pretty small. Essentially you need to remove a few screws from the bottom of the laptop which will let you carefully pry the panel above the keyboard up and off. Then you will see the two screws holding the keyboard in place. After you remove them you will see where the data ribbon from the keyboard connects to the motherboard. This can be removed by carefully popping the small plastic tab up; the ribbon will slide right out. The replacement keyboard can be installed via the same method.
You can find replacement keyboards on ebay: http://search.ebay.com/search/search.dll?from=R40&_trksid=m37&satitle=aspire+3000+keyboard&category0=
Was this solution helpful? Show your Appreciation by rating it:
Can you Help with these PC Laptops problems?
PC Laptops
laptop's power cannot turn on...
my laptop worked fine one day... Answer This...
Acer Aspire 3000 (AS3004WLCI) PC Notebook
facebook
Hi , Hope u can help me to open... Answer This...
Acer laptop
unable to use left mouse . ? Answer This...
ACER ASPIRE 3000
hi i change the video settings... Answer This...
acer aspire 3000
change the video settings on... Answer This...
Repair Service
Find PC Laptop Repairman Near You:
FixYa does not evaluate or guarantee the accuracy of any information provided through its proposed solutions, posts, or Expert Assistance Sessions. By entering this site you declare you read and agreed to its Terms. You may NOT copy or distribute the content that appears on this site without written permission from FixYa Inc.
© 2005-2008, FixYa, Inc. or its affiliates
When the original poster rates a solution that was given to his own problem, that rating is locked!
X
Are you sure the solution content is Inappropriate?
Tech buddies can communicate directly to answer questions. Become a Tech Buddy and have direct access to your favorite expert for FREE!
