Question about HP Compaq 6735s Notebook
Compaq 6735s wifi button is not turning on.. it will not turn blue.. the sound it makes when it should be turning on is not the same as when it does yet when i "turn it off" it says its disabled and i can remove the device. I went to bios and set my permissions to wlan and lan can switch (enabled) i downloaded new firmware for it and still the same problem persists. also worth mentioning the wireless menu where i can auto connect to different sources is not showing at all. I really appreciate anyone taking the time to read this and help me out.
  • 1 more comment
  • jmk987 May 06, 2010
    by wireless driver do you mean network adapters/marvell yukon 88e88042 pci-e fast ethernet controller? and if so then before i delete it how am i going to re install it if it is via cd these are the cds i have : os cd, supplemental software, app and driver recovery CD, app and driver recovery DVD. also mind you this is windows xp. And if you can go into detailed instructions that would make this a lot easier for me im not extremely savvy on computers... doing things like "go to: mycomputer/c:/whateverelse/etc"..will help me a lot more.
  • jmk987 May 07, 2010
    okay i did what you said (uninstall that driver re install the same from your link) to the "t" and it did not work the problem still persists exactly as it had before...
    did not resolve problem.. must get hardware fixed.
  • 4,281 Answers
First make sure that wireless driver installed and working fine.
Uninstall it and then reinstall.
You can uninstall it from device manager.
Also make sure wireless switch is turned on.
Make sure that wireless is enable in your router.
Check wLAN led if it is flah then your wireless is enable.
For check settings in router follow below .
Connect your router to computer with ethernet cable then you can access it with following default link.
http://192.168.0.1
or
http://192.168.1.1
If you are not able to access it with above ip then check your computers ip address gateway ip is your router ip try with it.
Then it ask for user name and password.
Type user as "admin" and password as "admin" or "password" or blank.
Then you can see configuration page of router.
Then check all wireless settings.
If you alreadt done above and upgraded your firmware and if still same issue then you need to repair your wifi lan on laptop.
Let me know if you need further assistance.
Thanks for using FixYa.
Posted on May 06, 2010
  • First download driver for your os from below link.
    Click here
    Then install that driver after uninstallin old.
    You can uninstall any driver from device manager.
    For that press windows key +R so you can see run .Then type in run "devmgmt.msc" without "" then press ok then you can see device manager then click on network adapter and uninstall your wifi driver.
    Also go to control panel->add remove programs then uninstall wifi driver fom there if it show.
    Then install driver from above link.
My ho 6735s orange light flashes 7 times when i plug it in but wont turn on ?
Hi,Thanks for using fixya,
Remove the battery, and unplug the A/C adapter and hold down the power button, for 40 seconds.Soon your laptop will reset,and run well.Now you will install all the accessories and start.
Hope this helps you.
Feb 01, 2011 | HP Compaq 6735s Notebook
Cannot find the wireless switch. Can you tell me where it is located?
The 2nd button is the wifi on off switch. The 1st button is the indicator
You need to be in a wifi enable environment to set this function.
Example: Library,Starbuck coffee shop,school,or know area with wi-fi service.
Jul 30, 2010 | HP Compaq 6735s Notebook
My hp compaq 6735s laptop does not switch on. I was using it and then it just switched off on its own. I used the charger adapter, the charger light comes on but the laptop does not still switch on. I have...
i think there is a problem with the motherboard.you need to call hp tech support and if your system is in warranty you can get the motherboard replaced by them.
Jan 19, 2010 | HP Compaq 6735s Notebook
Hewlett packard 6735s power up
Your battery is critically low. Didnt you recharge your battery? Try turning it on with the external power source connected.
Jan 14, 2010 | HP Compaq 6735s Notebook
HP Compaq 6735s battery light orange blinking
Have you tried another power cord? If you try another power cord, and it still does the same thing, then I think your laptop is having a power problem. You need to take is to a technician to fix the problem for you.
Best wishes.
Nov 28, 2009 | HP Compaq 6735s Notebook
Hp 6735s screen blank problem
If you use it from the power cable does it work better? There is a known issue with the 6735s and power management settings from battery.
Oct 02, 2009 | HP Compaq 6735s Notebook
HP Compaq 6735s Notebook Logo
770 people viewed this question
Top HP Computers & Internet Experts
Tony
Are you a HP Computer and Internet Expert? Answer questions, earn points and help others
