Question about Dayton Kitchen Ranges
Can a Dayton hood model 4c399c handle a charbroiler? Air balance report indicates the cfm's is 1627. Hood canopy is 5' x 3' charbroiler is table top model and is natural gas
SOURCE: Light bulb socket replacement for a really old Air Fare kitchen hood
The chances are that your range hood light socket was fully impacted with grease from cooking. Shut the power off to the range hood or, in many applications, simply unplug the power cord. Remove the socket. Get a spray can of electrical parts cleaner and saturate the socket through the tiny pin holes you may see at back of socket. shake out all of the cleaner fluid. Somehow hang the socket up with bulb base facing up all night. Hook it up. That might solve the problem.
It worked for me very recently on a 20 year old range hood.
DON'T USE ANYTHING OTHER THAN AN OFFICIAL ELECTRICAL PARTS CLCEANER. Most hardware stores, etc., have it.
Posted on Oct 24, 2008
SOURCE: Kitchen Hood Broan Nutone RM5200 Hood won't pull air.
There is definetly somthing blocking the air from escaping, either the duct is blocked or the installer did not remove the metal plate which opens the fan up for it to be able to evacuate.
Posted on Feb 08, 2009
  • 38 Answers
SOURCE: can't open hood
if you can still get to the little steel cable, a extremely tight pair of vise grips and a moderate amount of force will do the trick.
Posted on May 12, 2009
manhandy
  • 146 Answers
SOURCE: JENN AIR RANGE HOOD JXT8136ADS
make sure the fan blade not touching anything. make sure are clean the grease sticking to the blades can make the fan go out of balance
Posted on Jul 05, 2009
smartr10U
  • 1305 Answers
SOURCE: engine hood wont open hood pull handle pulls out but wont release
Try pulling on the hood release, while someone else lifts the hood. If this doesn't work. You can access the underside of the hood release by taking the front grille out. If you look closely you'll see the retainer screws that can be removed from the front. Once the grille is out or loosened enougt to get your hand in behind, you can release the hood latch from the underside with a screwdriver and then repair the hood latch after you've opened it.
Posted on Dec 09, 2009
Noisy range hood
Kit-aid sells blowers that are near silent, call 1-800-422-1230. Have your model number ready and they will get you what you need
Jun 02, 2012 | KitchenAid 36 in. Wall Canopy Range Hood
Need to Replace Door Handle for KitchenAid Over Range Microwave Hood Combo KHMS147KSS
can u send me the pic of door and the handle of ur oven at khader_abu@yahoo.com........
Jun 01, 2008 | GE Advantium SCA1000H Convection /...
How to detach maclaren stroller hood
To remove the canopy/hood from the stroller:
Go to the bottom of the canopy where you will find the black resin piece that wraps around the chassis/body.
You will see a vertical tab sticking out abou 1/4 of an inch
Press out (3:00 on a clock) and down to release the tab
Do the same on the other side
Voila! You are ready to handwash and let dry!
Oct 23, 2010 | Maclaren Techno XT Standard Stroller
We have 10 hp Motor with centrifugal fan fitted with 5 TR Cooling compressor? We want to know the cfm of air?.
You need to either get the specifications from the fan manufacturer, or take air readings with a manometer or flow hood
Apr 27, 2010 | Cfm Klimaire KSWG009H113 Split System Air...
Have an Chrysler Corporation central station air
Owner found the original set of design drawings. Added up the total cfm of the outlets, and modelled the duct system to find the design static pressure. At this stage of it's life, we're limiting the AHU to only 3/4 of design load.
Nov 14, 2009 | Heating & Cooling
I have a dayton kitchen exhaust blower mod no. 4hz65, 1/25 hp, 1550 rpm, 115 volts, 1.5 amps, 8 inches. it does not seem to do the job, do i need a stronger one?
Remember air will only move as fast as the size of the exhaust pipe in relationship to the fans ability to push. Make sure yours is the proper size for the fans volume.
Jul 07, 2009 | Dayton Exhaust Blower to vent your grow...
What is the height of britannia omaggio 90 cooker hood?
Here are the dimensions that relate to your cooker hood. The measurements are in mm.
Width 980 front 578 rear
Depth 480
Minimum height 1015
Maximum height 1170
Main canopy height 750
(excl chimney)
Chimney section width 436 main body/340 sliding section
Chimney section depth 170
Mounting height 650 - 750
Regards
Alan Hood
ami-man
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750 Width 960 front, 578 rear Depth 480 Minimum height 1015 Maximum height 1170 Main canopy height (excl. chimney) 750 Chimney section width 436 main body / 340 sliding section Chimney section depth 170 Mounting height 650 - 750
Jun 16, 2009 | Kitchen Ranges
Eddie Bauer Travel System - Removable Hood??
Took me awhile to figure this one out...
There are two bars attaching this hood to the stroller. The rop bar is obvious and removed by taking out 2 phillips head screwdrivers.
The bottom bar seems much more tricky as it seems "permanent".
Upon closer inspection, the lower metal "hood bar" goes into the side of a round clip. This round clip has a button snap in the middle of it. This round clip can be removed by pulling on it (not intuitive at all). It is not bolted on. It turns out it only encircles the metal bar it is attached to 3/4 of the way like a c-clip and will stretch to come off. You cannot remove the bar from inside the hood, but you can toss it all in the washer! Good luck!
May 24, 2008 | Eddie Bauer Lightweight Travel System...
Bugaboo Cameleon - 2 problems (Canvas Hood/Canopy and Shaky/Loose Handlebar
hi there
hope this makes sense....
the handlebars on all bugaboo cameleons are 'loose'... it is a safety feature, designed that if one or more wheels are off the ground the stroller will not fold.
You will notice when you take the seat frame off the chassis to fold it, it will only allow you to do so if you release the locks somewhere in between the tow positions of 'give' (if that makes sense)
it is basically so that IF someone does not have the seatframe on properly, thus not locking it into the starlock, and they accidentaly press the lock/unlock switch when goin off a kerb etc, that the chassis will not fold. its not a fault, just a design feature.
As regards the hood, this is difficult to explain online, but basically it sounds like the two clamps that attach your hood to the seat frame have the 'teeth' in different positions than each other.
they have to be symetrically aligned. ie if the plastic skeleton part that goes through the hood is further back on one side than the other, the hood looks 'floppy'
i appreciate this probably makes no sense, like i said its hard to explain online. if you cant sort it yourself check the bugaboo website for your local stockist, and go in. they will be more than happy to fix the hood for you.
This is really why companies like bugaboo like customers to buy strollers from retail stores, instead of having a box delivered and assembling yourself, as they can take you through it all, assemble it, and give you a decent demo of how it works.
cheers
Jan 04, 2008 | Baby Gear
No Power - Problem locating fuse
I have repaired many Gaggenau extractors before. On this model you were correct to remove two top screws from duct. The top and lower duct slide inside each other, and should be removed as 1 unit, by lifting the lower duct UP and then away from the wall. Sometimes there are two further screws holding the bottom duct to the canopy. Remove the filters and check for screws from inside canopy. Once ducts are removed you will see the a box, metal or plastic. Remove lid and you will see the pc board. There is a 10A fuse on there. Some models do not have fuses, and the whole board should be replaced! Good luck! C.
Nov 26, 2006 | Gaggenau AH 400-701 Kitchen Hood
Kitchen Ranges Logo
103 people viewed this question
Top Dayton Kitchen Ranges Experts
Dan Webster
Dan Webster
paulcarew
Are you a Dayton Kitchen Range Expert? Answer questions, earn points and help others
