I have an IPSO commercial washing machine. It keeps showing an error code:A4. Still washes, but instead of taking 30 minutes, it now takes more than an hour. Sometimes 90 minutes. I can't locate a manual for this particular model to look up the error code. model # IP060PHQ1001U01
SolutionGuy
  • 331 Answers
SOURCE: My neptune was 30 min for a quick wash and is now 55 min
Terri, you may need to contact Maytag on this one. Here is service bulletin that was released in June of 2002... "Date: June, 2002 No: TDL0008A-S, MAH5500BWW, MAH5500BWQ Issue Software Improvements: A software improvement was introduced to the machine control board. The improvements focused on.  Reducing the number of wet clothes loads, spinning and draining complaints.  Modifications to the time estimation displayed toward the end of spin cycle. Display will no longer fluctuate erratically, time remaining.  ?dO? is no longer displayed when the door is open. Warranty See specific product for warranty information. Action This board modification was phased into production without a series change. Inventory at the National Parts Center was purged and replaced with the new control board." Hope this helps.
Posted on Aug 01, 2007
AlmostBob
  • 550 Answers
SOURCE: maytag commercial washing machines/dryers that
push in slide coin acceptor,b48b65c.jpg requires different slide
multi coin single slot acceptor, ee120a2.jpgneeds new program
Posted on Oct 28, 2008
JR JR
  • 116 Answers
SOURCE: Kenmore Elite he3t model 11045972404
POSSIBLE COMMUNICATION PROBLEM BETWEEN MAIN AND MOTOR CONTROLLER
Posted on Nov 30, 2008
SOURCE: WCVH6800J GE Front loader timer keeps resetting
The clock timer might be faulty.Need to Replace it.Since the machine is new, it must be under warranty and can be subjected to replacement.Problems with clock timers is common with any washer.Its better when detected early like in this case.Good luck.Please do post your comments.
Posted on Jan 16, 2009
  • 3 Answers
SOURCE: I need a wiring diagram for a ipso we-181 washing
most washing machines have wiring diagrams tucked or taped in the control area of the washer look for a folded paper this may help
Posted on Oct 23, 2009
I have an Ipso washer and had to cancel a load because the water was frozen. Now the green lights that say “door” and “wash” are blinking, and I can’t get it to start.
there's no way help as a correspondent in a forum, you will need to contact a washing machine repair person and get him to take a look at it eric
Jan 02, 2018 | Washing Machines
Kleensmaid heavy duty washer by speed queen, washes but shuts down on what seems to be overspeed on the spin cycle
Amazon.com: Customer Reviews: Speed Queen 3.3 Cu. Ft ...
www.amazon.com/Speed-Queen...Washer/.../B004ZO...
Amazon.com, Inc.Find helpful customer reviews and review ratings for Speed Queen 3.3 Cu. ... If you need more water in the tub you can hold down the reset switch until the machine ... I tried the delicate wash and spin cycle, but the clothes retain too much water and ..... It takes time to correlate the number of turns and the direction to turn it.Missing: overspeed
Commercial Washer and Dryer Problems
www.affordablelaundry.com/commercial-washer-and-dryer-problems
The water should shut off once it reaches wash level, if it doesn't, and water level hasn't... (these are the glass type fuses) be sure to turn power off before checking them. ... If you have the voltage in, but not out, it's the contactor. .... We repair: Speed Queenwasher, IPSO washer, Milnor washer, UniMac washing machines.Missing: overspeed
[PDF]View document in PDF
Dec 19, 2015 | Speed Queen Washing Machines
My indesit washing machine WI121 is taking several hours to complete a wash cycle on quick wash which should take 30 minutes
Reading the error code
The fault on the appliance is signalled via:
1. the continuous rotation of the selector knob
2. the action, for the first 4', of the electrovalve and the drain pump
3. the door becomes unlocked
4. the led flashes:
the number of flashes indicates the fault code; the code should be read as follows:
· each fast flash (2/3 flashes of the led very close together) represents one code value
· the fault code is evaluated by counting the number of flashes occurring at 3/4" intervals from one another
· stop counting when the washing machine waits the equivalent of approximately 8/9" between flashes
· the procedure is repeated by the appliance cyclically
Dado
Sep 14, 2015 | Indesit Washing Machines
How do I fix a loose or locked up drum that generates LE errors?
you sure it is not and upside down 'F' instead of an L? that would be a hall sensor(motor position sensor) error. easy fix. check out appliancepartspros.com or repairclinic.com for both parts and videos that show how to repair. very easy with common tools. about 20-30 minutes. basically take back cover off, remove motor cover, remove stator, replace part.
Aug 30, 2015 | LG WM2016CW Front Load Washer
When I run the 59 minute wash it ends with Error E14 code, short washes end OK.
WOW 1 cycle is 59 minutes sounds like a big waste to me .most of ours on a non computerized machine might take 30 hour total
Jan 28, 2015 | Washing Machines
Wa75t65gw1
After 2 minutes does the machine throw up an error code. Starts beeping and shows a weird pattern of lights?
If so that error code can help us diagnose what your problem is.
If it does give you an error code take a photo and post it back on here so I can see what it is.
Jul 04, 2017 | Fisher and Paykel Washing Machines
Washing Machines Logo
451 people viewed this question
Top Washing Machines Experts
